All new ten IGBT transistors bad or am I measuring wrong?
  • caphair
    • Nov 2011
    • 1249
    Recently purchased 10 RJH30E2 IGBTs from china. I go to measure them and none measure properly in diode mode + on C - on E then touch G with + while leaving - on E I still read OL
    In about 4 of them I measure the protection diode from C to E
    Are all of them bad or do they need more of a bias voltage that my meter doesn’t provide? It uses a 9v battery
    Here’s the datasheet for the IGBT: https://www.scribd.com/mobile/docume...709293/RJH30E2
  • paulstef
    • Dec 2013
    • 724
    Re: All new ten IGBT transistors bad or am I measuring wrong?
    I would think you don`t have enough voltage from your test leads. Use a power supply a couple of resistors to test them, drive some current through them.
    Why would you want to test new IGBTs though? You won`t find out if they are fake this way (at low voltages/currents)
    • caphair
      • Nov 2011
      • 1249
      What about only 4 of them giving a reading of the protection diode but the others no? Does it mean they’re bad?
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8116
        wouldn't be the first time. A while back I had ordered 10 rare transistors from Ali and they were all fake.
        • caphair
          • Nov 2011
          • 1249
          Originally posted by caphair
          What about only 4 of them giving a reading of the protection diode but the others no? Does it mean they're bad?
          What about this?
          • petehall347
            • Jan 2015
            • 4426
            just get some genuine ones ..i have had cheap fets from china that lasted about 20 seconds in an inverter then bang . it caused so much more damage the unit wasn't worth repairing afterwards .
            • caphair
              • Nov 2011
              • 1249
              Couldn't find any anywhere else
              • petehall347
                • Jan 2015
                • 4426
                not cheap ...http://nikkoe.com/catalogsearch/result/?q=RJH30E2
                • petehall347
                  • Jan 2015
                  • 4426
                  http://www.ohmsupplies.co.uk/RJH30E2-IGBT-TO220
                  • caphair
                    • Nov 2011
                    • 1249
                    Thanks for the links.
                    So the ones I have that I don’t measure the internal diode does that mean they’re bad?
                    • petehall347
                      • Jan 2015
                      • 4426
                      i would say they are bad .
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        I had to buy two lots of these from Ali, the first were fake and blew again immediately.
                        The second looked nicer and have lasted.
                        • caphair
                          • Nov 2011
                          • 1249
                          Did you try measuring the fake vs the real?
                          • msilvap
                            HP Compaq NC6400 - Wrong temperature measure
                            by msilvap
                            Hello there
                            I am trying to recovery my old HP Compaq laptop, and this time the problem is: using HWMonitor on Windows or sensors on linux, the temperature measures are shown in the picture, but when I touch the heatsink I would say the temperature is above 100ºC!!! what do you think is the problem?...
                            05-20-2025, 01:54 PM
                          • mikkele86
                            Power amplifier SMPS IGBT keeps blowing - Artcoustic PDA1000
                            by mikkele86
                            hello.
                            I have two power amplifiers, both having their IGBT blown on the PSU.
                            The original mounted IGBT where marked with IRGB20B60PD1PbF and the gate driver is a IR2156STRPBF.
                            I looked at mouser and digikey and could not find any available IRGB20B60PD1PbF and somehow ended up using a Bourns BIDW20N60T.
                            I replaced the gate driver, the gate resistor and both IGBT. But as soon power is turned on, both IGBT shorts out completely (gate, emitter, collector) and the fuse on the AC line gets killed.
                            So I though i missed a capacitor or diode. I removed...
                            01-06-2024, 06:45 AM
                          • dicky96
                            Dynacord PowerMate 600 Powered Mixer - Protect Light On
                            by dicky96
                            Hi guys
                            I'm trying to repair this powered mixer. Sorry this is a bit long but I want to give as much info as possible to help get an answer,
                            As soon as it powers on the protect light comes on. There are relays that connect the speakers to each channel of the amplifier but they never click. If I connect a 60W light bulb in series with the mains supply it comes in bright then goes to maybe 30-50% brightness - it seems to dim a little further over time
                            I have power to the amplifier, I think it was as about plus/minus 50-60V for the main amp, and plus/minus 15V...
                            05-22-2022, 04:36 AM
                          • ohren
                            Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                            by ohren
                            Hello!
                            I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                            Measured voltages with no load:
                            After rectifier diodes
                            12V: 6.17 V
                            5V: 5.67 V
                            Secondary transformer pins AC measurement (really don't know if this says anything)
                            12V: 2-2.5 V
                            5V: 1.04 V
                            I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                            03-18-2023, 10:33 AM
                          • Francesc V.
                            Technics SA-AX530 in protected mode. Overload message
                            by Francesc V.
                            I got a request from a friend of mine to have a look to his amplifier. When switching on "OVERLOAD" was displaying, however from time to time, message disappears and protection was removed.
                            I took some time in visual inspection (no bold caps, no solder joins, no burnt components neither hot burnt areas). I took some time to measure transistors and diodes. Everything seemed ok.
                            I realized that when OVERLOAD was on, pin 13 on IC601 (RSN307M44A-P) measured 5V. From time to time, when Amplifier was not protected pin 13 measured the right -1.5V
                            (Pin 13 goes through...
                            11-18-2024, 12:39 AM
