555 countdown timer design question
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    #81
    Re: 555 countdown timer design question
    Originally posted by eccerr0r
    Darn, if it were configurable for per-channel latching or momentary, that would simplify things.
    Yes I know - I had already thought of how to accomplish that rather easily.
    Haven't really looked into how that IC operates, so yes, it seems complicated, just like when I originally started working with the 555, but I eventually got it down....a micro would make things more flexible, albeit the complexity would then lie in the code and not at all in the circuit itself.
    Wattevah...
      • 31151
      set the module to momentary,
      then cut the tracks of the ones you want to latch between the mcu and transistors and put a 74ls/hc74 in series.
      if you wire it right, it acts as a latch.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        .. or the 4027, or the 4013, or ... lots of FF that will work
        Oops I just noticed that I drew the wrong FF, it used another IC when the second FF in the 4013 would suffice... bad kicad! :p
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          #84
          Apparently what my fellow suggested was an Attiny85, just to clarify.
          Wattevah...
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            most of them will work just fine.
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              #86
              Yes, you're right. The application is so basic and simple, prolly any micro will do....it's just a matter of whether they use the same Arduino code I'm "familiar" with...and I put that in quotes because I obviously have very brief knowledge and it's a good opportunity to brush up on my C
              Wattevah...
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                And dang, the encoding of pseudocode to AVR-C is taking longer than expected... *sigh*
                  • 31151
                  well if your going the AVR route the programmer is cheaper.
                  a USBasp is about the same as a decent beer.
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    #89
                    TBH, I think I'll stick to the "lazy" and more convenient arduino Mini route...I already have a CH341 usb to serial adapter I use all the time for TVs so it should be easy to setup.
                    Wattevah...
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      then there's arduino vs baremetal avr.
                      I've never done arduino before... I just program them directly.
                      Are PICs tied in with the dev software/hardware? I was quite disheartened when Atmel got bought out by Microchip.
                        • 31151
                        pic's need a dedicated programmer.
                        not saying you cant make one - everybody did in the begining - the DAVID TAIT design was common.
                        software, you can use MPLABX - which is very nice, and free
                        http://www.microchip.com/mplab/mplab-x-ide
                        or a 3rd party thing like these:
                        https://www.mikroe.com/products/#compilers-software <<< not free, but trial is
                        http://gcbasic.sourceforge.net/Types...index.php/Home <<< free
                          • 31151
                          just to add,
                          i'v always used MPLAB,
                          i tried GreatCow once and made a "blinky" program just to see if it worked - it did.
                          surprisingly good software actually.
                          i tried the Mikroe suite but it wouldnt run properly under Linux - so all i can say is it "looks nice"
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            I've only used tavrasm and gcc (and hence also gas) for atmel. My preferred platform is atmel because of gcc. I use uISP with a parallel port SPI interface for chip programming for Atmel. I still have a pile of 90S2313 and 90s4433 I need to burn, along with a few mega8s... Supposedly I also chanced on an Arduino board with a mega328 on it... Might end up reflashing it to something else, and yes that AVRTransistorTester could get targeted to one of these AVRs.
                            For PIC I've only used the 16C/F84 and 16F627, and only used the Linux gpasm tools... it's a shame if now one is required to use their tools now. I forget what chip programmer design I used, was a serial port chip programmer for PIC, again for Linux.
                              • 31151
                              that's probably the programmer that's just a couple of transistors and some resistors & diodes.
                              i build a couple of those for people once.
                              good for old chips like the 12c508
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                #95
                                Found THIS which comes close to what I'm trying to accomplish. It will require tweaking of course, but gets me in the ballpark....my skills are very rusty, so I'll have to take it step by step by first turning the light on/off with an actual pushbutton, then replace that with the remote module (since it outputs 5v directly), make sure it still works, then slowly try to implement the "hold" feature....
                                Wattevah...
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  Oh good I won't have to finish mine then
                                  Funny, I was debating whether to rip out the serial code from the template I always start with... alas the serial code template eats up a good chunk of the 2K of flash in a '2313
                                    • 31151
                                    2k?
                                    if it was a pic you would be using a few hundred bytes at most.
                                    that's the thing about pics, the assembly is compact but the chips arent the most endowed when it comes to timers,uarts etc.
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8701
                                      It was my own serial template, which is a full CLI for the AVR. That's why it uses a good chunk of space... Since it was a CLI it used a good amount of RAM too (based on the meager amount of RAM in the 2313) to buffer the command line, and all that code needed to process that RAM...
                                      Note that 2K of flash is 1K of instructions (since AVRs are 16-bit instruction, 8-bit data). I think my CLI takes about 512 words or so of instruction memory (thus 1K bytes or so) but I never calculated it, all I know all those strcmps() I had to reduce the compare strings down to save a byte here and there to squeeze it all into memory...
                                      • Dannyx
                                        CertifiedAxhole
                                        • Aug 2016
                                        • 3912
                                        #99
                                        Another good one here which pretty much nails it and requires even less tweaks. One thing I WILL want to add is a buzzer which gives off a very brief beep when the light is latched on and perhaps lights up an LED as well to know which mode you're in. The only thing it requires is reversing the HIGH/LOW values for the buttons, since my remote output is active HIGH, so it pulls whichever pin I connect it to VCC rather than GND like in the example.
                                        Got my Mini ordered today, so I'm officially into this
                                        Wattevah...
                                        • eccerr0r
                                          Solder Sloth
                                          • Nov 2012
                                          • 8701
                                          Always faster to find a solution already made instead of building one yourself!
                                          I had made a mistake in my pseudocode so I gave up on it for now, I thought that the 2313 supported interrupt on both edges but looks like you could only choose one or the other; back to the drawing board... but I guess I don't have to bother. Maybe I should finish anyway because it's something I can burn these arduino-incapable 90s2313s on in case I need similar functionality someday...
                                          • DeanWy
                                            WD Sentinel DS5100 (NAS) boot issues
                                            by DeanWy
                                            I have a Western Digital Sentinel DS5100 NAS system which has stopped working. It has dual BIOS. I bought the system second hand with an already broken primary BIOS (it rebooted multiple times until second BIOS was used).
                                            It worked until recently. The system was idle in Windows Server 2012 and a BSOD occurred, I think it was 'critical process died'. Thereafter it didn't boot, it just sat there with no video output and fan speed at 100% (there's a proprietary Windows driver by WD which controls the fan, outside of that it always runs at 100%).
                                            There...
                                            07-30-2024, 04:13 AM
                                          • survivalbloke
                                            Acer Predator Helios 300 - will not power up if battery is CONNECTED
                                            by survivalbloke
                                            This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
                                            06-25-2025, 12:20 PM
                                          • beogeek
                                            820-2915-A Wont power on with battery connected
                                            by beogeek
                                            Ok so this doing my head in and hopefully someone more knowledgeable will be able to assist.
                                            I've got a MacBook Pro 820-2915-A it will power on without the battery connected, but when the battery is connected it will do a 2,3-second fan spin when pressing the power button and then nothing.
                                            After measuring and probing around I found that R7051 was bad, reading high instead of 2.2Ω so I replaced it. Still the same issue, I have the green light on the charger but it won't power on or charge the battery.
                                            So to cut the long story short I've replaced U7000,...
                                            02-26-2022, 01:29 AM
                                          • muhuruu
                                            PS5 too many USB devices connected
                                            by muhuruu
                                            Hello. I have a problem with a PS5 console that I bought to learn electronics repair. The auction description indicated that the console had been dropped. The HDMI port and USB ports were damaged. The HDMI port was replaced by the previous owner, and after his repair, the console worked for 2 days and then became dead. After receiving the console, I replaced all the USB ports. After replacing them, the console started to turn on. On the logo screen, it displays "too many USB devices connected". My further attempts to fix the error involved replacing the Southbridge, 4 TPS2001D chips,...
                                            05-19-2025, 07:14 AM
                                          • versionlab
                                            Weird problem, laptop stays on when connected to another pc
                                            by versionlab
                                            Hi, I want to ask for advice about an interesting issue I've been having with a sony vaio laptop.
                                            Client came and said that "a desklamp touched the back of the lid while laptop was operating normally and it caused the office's circuit breaker to trip. Laptop had never turned on since".
                                            After taking the laptop apart (checked dc adapter everythin ok), I found a faulty MOSFET on the motherboard which I replaced. Laptop managed to turn on. However, while booting it shut down. Nothing else seemed faulty and thermals were ok. Shutting down was coming at random...
                                            10-26-2022, 03:43 AM
