555 countdown timer design question
    • 31159
    Re: 555 countdown timer design question
    btw, the ch341 adapters/chips are the best IMO, so tell your m8 to fuckoff!
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      #122
      Originally posted by stj
      isp needs a dedicated programmer - preferably a USBasp
      Dumb question, but if they don't work for the purpose of programming the arduino, what are the MISO/MOSI etc pins on the CH341 adapter for ?
      Caps ? Yeah I do (that would be 0.1uF right ? I suck at these )...I knew it from the start there's something fishy about that reset pin and even read something along those lines....
      Yes, no question about it - that CH341 "crap" helped me a lot in the past years, ever since I became more confident in using it and discovered it can do many other things besides programming SPI chips (which might actually answer my first question right there), so I too didn't agree with him.
      Wattevah...
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        #123
        The schematic you posted also confirms I got the pinning right: TX to RX and vice versa, instead of RX to RX etc.
        Wattevah...
          • 31159
          oh, you have the black eeprom programmer?
          yes, that can do isp - if you use the right software.
          (or maybe avrdude does that hardware - never looked!)
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            #125
            Well it's not really black, but sure It's this. Still, I wanted to keep it as simple as possible, so I'll push on with the serial method since ISP seems tough to achieve with the arduino IDE...or at least I THINK so.
            Back to that cap you asked about: should it go between RST and GND or something ? This programmer doesn't have a RST pin so I'm guessing that's the issue....
            Wattevah...
              • 31159
              on the serial adapter it goes to one of the handshake lines.
              your adapter is a bit lacking so you may need to solder to the chip pin.
              what's the exact part number of the chip on that adapter?
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                #127
                I'll have a look...soldering won't be a problem, but can I continue to use it like normal like I have been so far even with that "cap hack" in place ? I don't want to "commit" the programmer solely for programming the arduino. I understand where you're going with this and I'm sure it'll eventually work, but I don't claim I 100% know what to do
                Wattevah...
                  • 31159
                  no answers till i know what chip it uses - some dont have the extra signals
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    #129
                    It is a CH341A and here are some pics up close...damn I need a macro lens for my DSLR >_>
                    Wattevah...
                      • 31159
                      you need to connect the 100n cap between your programmer pin20 which usefully appears to connect to the green socket, to the reset pin on the arduino.
                        • 31159
                        btw, second picture, lower left.
                        5.1ohm resistor looks burned - did you try to power something big through the programmer, or short something??
                        • Dannyx
                          CertifiedAxhole
                          • Aug 2016
                          • 3912
                          #132
                          Yes it does look like sh!t, I agree....never even noticed now that you mention it. No, I don't believe it got overloaded in any way and the resistor checks fine on my meter, so it's not faulty, plus the programmer works.
                          So I should place the cap between pin 20 and the reset pin ? Dumb question again, but what does the cap actually do ? Why not a piece of wire for instance ? Is a ceramic capacitor with 104 on it the right one ? I suck at these, I told you that
                          Wattevah...
                          • Dannyx
                            CertifiedAxhole
                            • Aug 2016
                            • 3912
                            #133
                            Ok, works perfectly now: that cap between pin 20 and the reset pin did the trick. Big shoutout to STJ for the help...here's the setup: the gray piece of wire stuck into the ZIF socket corresponding to pin 20 of the CH341 on the bottom goes to the cap and then the other end of the cap has another piece of wire stuck into the breadboard on the RST pin. A CD ROM audio cable came in very handy for fashioning a "programming cable" because I could just insert it straight into the TX/RX male headers on the CH341 without having to run individual jumpers and make a mess of wires everywhere
                            Wattevah...
                              • 31159
                              the real question is why you got this:
                              https://www.ebay.co.uk/itm/181894982202
                              instead of this:
                              https://www.ebay.co.uk/itm/191773759569
                              it's worth the extra 60c for the onboard programmer!
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                #135
                                Space is at a premium and I'm trying to keep the whole project as small as possible, even if it meant a more complicated setup...there's actually something satisfying about having a functional mess of wires on your worktop
                                Wattevah...
                                • Dannyx
                                  CertifiedAxhole
                                  • Aug 2016
                                  • 3912
                                  #136
                                  Started messing around with the code and adapting it to my needs, but I'm only able to follow up to a point. Just a quick question: whenever an IF.....ELSE statement occurs, I'm having trouble following which "else" belongs to which "if", for instance here:
                                  if (digitalRead(button) == HIGH) {if (buttonActive == false) {buttonActive = true; buttonTimer = millis();}
                                  if ((millis() - buttonTimer > longPressTime) && (longPressActive == false)) {
                                  longPressActive = true;
                                  relayState = !relayState;
                                  digitalWrite(relayOUT, relayState);} }
                                  else {if (buttonActive == true) {if (longPressActive == true) {longPressActive = false;}
                                  else {LED2State = !LED2State; digitalWrite(LED2, LED2State);} buttonActive = false; } } }
                                  The two elseS at the bottom: which one belongs to which of the IF statements above...if that makes any sense ? Sorry for posting a wall of text
                                  My idea is the following: If the press is longer than "longPressTime", the code does one thing (turn on the light permanently) and if it's shorter, the Else should take over and do something else (in my case activate the 60s timer which I haven't implemented yet because I don't know where to drop it), so my guess is that the second Else belongs to the IF statement which checks the press time.
                                  Wattevah...
                                    • 31159
                                    the shortest distance is the first pair.
                                    if that makes sense.
                                    and the first "if" and last "else" are the second pair.
                                    • Dannyx
                                      CertifiedAxhole
                                      • Aug 2016
                                      • 3912
                                      #138
                                      Ok, but I believe the very first IF, the one that checks the button being pressed, doesn't have an else, since it doesn't expect to do something else if the button ISN'T pressed.
                                      Wattevah...
                                      • Curious.George
                                        • Nov 2011
                                        • 2305
                                        • Unknown
                                        #139
                                        WAY overkill for what this thing needs to do
                                        But you've really not indicated exactly what it must do.
                                        What does "60 seconds" mean? 60 +/- 0.5 sec? 60.0000 sec? "About a minute"?
                                        Will it always be "60" or will you later decide that you'd like it to be 70? Or 120?
                                        Getting reliable, repeatable long delays from an RC delay is tricky. What are teh tolerances on your components? Operating temperature range? etc. Do you plan on "select at test" -- or, worse, adding a trim pot? -- to tweek the delay to the desired accuracy?
                                        While a < $1 MCU might seem like overkill, it can give you the benefit of a highly repeatable and alterable design. What if you want to inhibit the light from being retriggered within 37 seconds of extinguishing? What if you want to start your 60 second interval when a button is released instead of when it is initially depressed (or vice versa)? Or, if you want to adjust the duration of the period based on how long the button is held depressed? etc.
                                        • Curious.George
                                          • Nov 2011
                                          • 2305
                                          • Unknown
                                          #140
                                          Originally posted by eccerr0r
                                          And another reason why microcontrollers are preferred, if you're using a crystal oscillator, it can be accurate down to parts per million, and even using the onboard oscillators in some even newer microcontrollers they have errors of only 1% or so. Using 5% resistors and +80-20% electrolytics, know knows what your real time constant will be
                                          You don't need a crystal (adds cost). Use the AC mains as your timebase. Crudely rectify it and count 50 cycles for each second of delay that you want. In this way, you don't care how "fast" the processor clock happens to be.
                                          • DeanWy
                                            WD Sentinel DS5100 (NAS) boot issues
                                            by DeanWy
                                            I have a Western Digital Sentinel DS5100 NAS system which has stopped working. It has dual BIOS. I bought the system second hand with an already broken primary BIOS (it rebooted multiple times until second BIOS was used).
                                            It worked until recently. The system was idle in Windows Server 2012 and a BSOD occurred, I think it was 'critical process died'. Thereafter it didn't boot, it just sat there with no video output and fan speed at 100% (there's a proprietary Windows driver by WD which controls the fan, outside of that it always runs at 100%).
                                            There...
                                            07-30-2024, 04:13 AM
                                          • survivalbloke
                                            Acer Predator Helios 300 - will not power up if battery is CONNECTED
                                            by survivalbloke
                                            This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
                                            06-25-2025, 12:20 PM
                                          • beogeek
                                            820-2915-A Wont power on with battery connected
                                            by beogeek
                                            Ok so this doing my head in and hopefully someone more knowledgeable will be able to assist.
                                            I've got a MacBook Pro 820-2915-A it will power on without the battery connected, but when the battery is connected it will do a 2,3-second fan spin when pressing the power button and then nothing.
                                            After measuring and probing around I found that R7051 was bad, reading high instead of 2.2Ω so I replaced it. Still the same issue, I have the green light on the charger but it won't power on or charge the battery.
                                            So to cut the long story short I've replaced U7000,...
                                            02-26-2022, 01:29 AM
                                          • muhuruu
                                            PS5 too many USB devices connected
                                            by muhuruu
                                            Hello. I have a problem with a PS5 console that I bought to learn electronics repair. The auction description indicated that the console had been dropped. The HDMI port and USB ports were damaged. The HDMI port was replaced by the previous owner, and after his repair, the console worked for 2 days and then became dead. After receiving the console, I replaced all the USB ports. After replacing them, the console started to turn on. On the logo screen, it displays "too many USB devices connected". My further attempts to fix the error involved replacing the Southbridge, 4 TPS2001D chips,...
                                            05-19-2025, 07:14 AM
                                          • versionlab
                                            Weird problem, laptop stays on when connected to another pc
                                            by versionlab
                                            Hi, I want to ask for advice about an interesting issue I've been having with a sony vaio laptop.
                                            Client came and said that "a desklamp touched the back of the lid while laptop was operating normally and it caused the office's circuit breaker to trip. Laptop had never turned on since".
                                            After taking the laptop apart (checked dc adapter everythin ok), I found a faulty MOSFET on the motherboard which I replaced. Laptop managed to turn on. However, while booting it shut down. Nothing else seemed faulty and thermals were ok. Shutting down was coming at random...
                                            10-26-2022, 03:43 AM
