FLUKE 179 problems
  • retiredcaps
    • Apr 2010
    • 9271
    Re: FLUKE 179 problems
    Originally posted by bwilliams60
    I started tracing the circuit from the beginning and found a bad connection between the inductor and the board.
    Just like I referenced in post #16. The measured value of the inductor is also in that thread in post #16 as measured my Modemhead.
    --- begin sig file ---
    --- end sig file ---
    • retiredcaps
      • Apr 2010
      • 9271
      I am going to compare it to a couple of other meters just to see how they compare but we are further ahead today then we were yesterday
      Calibration will likely be within specification +/- 1 count. They can take a lot of abuse and still be within spec.
      • bwilliams60
        • Aug 2014
        • 109
        Thank you to Redwire and Retiredcaps for your help. It was indeed because of that article that I took a closer look. I also noticed on one of the pics I snapped, that the connection didn't look good but I put it off to lighting at first. When I finally checked the pathway, it all made sense. So I took a pick and easily pulled the inductor off the board. I will try it for the next few days before I am convinced that is all there is. For now, a sigh of relief. Simple fixes are best
        • jondoe
          • Nov 2016
          • 547
          I was given a Fluke 187 which didn't seem to work correctly, turned out to be the input jacks, they were cracked at the PCB, but you couldn't easily see it, replacing the whole jack assay fixed the meter and it passed calibration
          • CapLeaker
            Leaking Member
            • 8290
            Originally posted by stj
            there is a "supercap" in some fluke meters that leaks - check that out.
            I think that was on the 289 / 287. The 179 doesn't have any memory etc...
            • retiredcaps
              • Apr 2010
              • 9271
              #26
              Here is the very long thread at eevblog.
              https://www.eevblog.com/forum/testge...unt-coin-cell/
              • retiredcaps
                • Apr 2010
                • 9271
                #27
                Yes, we have seen bad input jacks over time. See
                http://mrmodemhead.com/blog/fluke-80...embly-rebuild/
                The 187 is one of my favourite meters.
                • CapLeaker
                  Leaking Member
                  • 8290
                  Thanks retiredcaps!
                  • jean luc ferre
                    laptop hp g72 b52sf screen problems
                    by jean luc ferre
                    on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                    the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                    i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                    i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                    06-07-2025, 03:27 PM
                  • Hondaman
                    USB problems?
                    by Hondaman
                    Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                    (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                    I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                    08-12-2024, 03:26 PM
                  • Khoja
                    Fluke 123 no image on the screen
                    by Khoja
                    Hello experts,
                    I recently purchased a used Fluke 123 Industrial Scopemeter from an online Japanese auction site (jauce.com). It has now been delivered. Unfortunately, I overlooked the fact that the seller neither guarantees its working condition nor accepts returns.
                    When I power it on, the backlight comes on, but there is no image on the screen. After opening the device, I noticed clear signs of previous soldering in several areas (photos attached). It seems someone attempted repairs before.
                    At this point, I'll have to try and fix it myself. Has anyone here...
                    04-10-2025, 09:24 AM
                  • clabr
                    Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                    by clabr
                    Need help to solve some problems with this laptop.
                    After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                    After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                    Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                    Before this had happened I observed some other problems:
                    When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                    12-02-2021, 08:09 AM
                  • jean luc ferre
                    display screen problems after changing motherboard
                    by jean luc ferre
                    First on my laptop i had a motherboard with a pentium 6100 processor. Installing w11 i was blocked on the 23h2 version...impossibility to upgrade toward 24h2 because the SSE4.2 functionnality of the cpu was missing. About displaying and screen looking all was perfect.
                    I changed of motherboard with an intel I3 processor...and now i don't find the previous aspects of the displaying.
                    Now i have a veiled screen and pixels are missing though the graphics parameters have not changed.
                    Desinstalling and reloading the drivers in the same time on the graphic card (intel hd...
                    09-11-2025, 10:28 AM
