Failed Motorola 10261 ... transistor?
This topic has been answered.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Failed Motorola 10261 ... transistor?
    since we are cutting transistors this may be of interst.
    http://sound.whsites.net/counterfeit.htm
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Damn, self necro after I found my own post researching repair of an old linear PSU.
      I just ran into another 10261 (and three 10262) on a power supply I recently got to do some "solar panel emulator" so I can test at night.
      The PSU only makes sense if the 10261 and 10262 are all NPN as the circuit looks like they're darlington connected emitter follower. All collectors are tied together. One emitter connected to three bases and three emitters connected through resistors to output.
      The 10261 and 10262 behave like NPN (or dead...) based on a diode checker DMM. However I saw some sites where 10262 is ... PNP ??? This can't be right.
      • truclacicr
        • Apr 2019
        • 331
        • australia
        https://www.sourceresearch.com/StoreWork/CrossList.cfm
        10261 = NTE130 -- NPN 100V 15A TO-3 Audio Power Amp, Medium Speed Switch
        10262 = NTE219 -- PNP 100V 15A TO-3 General Purpose Amp and Switch, complement to NTE130
        https://web.archive.org/web/20220814...pdf/nte130.pdf
        • truclacicr
          • Apr 2019
          • 331
          • australia
          https://antiqueradios.com/forums/viewtopic.php?t=70011
          I have a pair of old linear 5 volt power supplies. One is up and running in a supply for 20's radios the other is not working.
          They use Motorola 10261 (ECG 130) and 10262 (ECG 219) transistors.
          The 10262 is supposed to be PNP and tests bad as such. What confuses me is that it tests perfect on my Sencore Tansistor Tester when tested as a NPN transistor. The 10261 tests OK as NPN.
          I see several listings for SGS versions of the same 10261 and 10262 transistors. This suggests that they may be the house numbers of the PSU manufacturer.
          https://i.ebayimg.com/images/g/pJYAA...fq/s-l1600.jpg
          https://i.ebayimg.com/images/g/D8wAA...q/s-l1600.webp
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            NTE/ECG used to be real good at dealing with custom numbers as well as indicating part manufacturer. But it still stands, my Motorola 10262 and 10261 both could only be and are NPN.
            BTW the PSU is made by Power-One which has been bought out by Bel Power. And I substituted a 10262 with a 2n3055, and no magic smoke came out yet...
              • Jul 2011
              • 6057
              Back in the day this was a very popular part number you still find surplus electronic stores that specialize in obsolete parts I still see them around
              • truclacicr
                • Apr 2019
                • 331
                • australia
                #27
                It seems that NTE/ECG went to a lot of trouble to supply a matched complementary pair. This suggests that there must exist a genuine PNP 10262, but obviously not the same one as the OP's. Maybe there is an audio power amp that uses these same numbers for different parts?
                NTE219MCP is a matched complementary pair containing 1 each of NTE219 (PNP) and NTE130 (NPN).​
                • CapLeaker
                  Leaking Member
                  • 8286
                  2N3773 or some MJ15015 or something similar..
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    If it was a popular part...why is there no documentation about it and why are some wrong...?
                    hmm...calculating backwards I need a transistor that can handle 4 amps... and already in my spare parts bin...
                    Then the other question is if I had a pile of darlingtons, do I rewire the PSU to use discrete darlingtons instead of using its discrete transistor to be the predriver of the darlington...
                    • CapLeaker
                      Leaking Member
                      • 8286
                      While some Motorola parts are documented well, others are not. NTE / ECG is not 100% correct. Why I don't know, but had a run I'm with a Motorola MSR2000 power supply where the pass transistor failed. One of my friends used the NTE part suggested and I used a different part that I chose by my own judgment. His went and mine was fine. I sent him some of my transistors and all was fine. That was back then when you still could buy NTE.
                      I hate the Motorola parts numbering scheme. Some are easy to identify others are just about unidentifiable. Crazy. I still have plenty of old equipment running that uses TO3 style transistors and still got plenty of NOS at work. Unless you find an old techie that's was used to repairing these 50 year old things…you're just about SOL. I got old Motorola paging units that go on to a VHF radio for hospitals and fire departments, some of them I had to junk, because of one unidentifiable I.C. I think there is a post about it around here somewhere. See… even I don't know all of them Motorola equivalents.
                      Sometimes you're better off to find a device that uses this part. Then study the schematic and see what that circuit does and go from there. Problem with that is that not everything has a schematic available anymore because they are that old.
                      I still have NOS ECG packaged things by boxes full.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        Yeah I ended up tracing the pcb a bit and realized that the circuit indeed was a series pass emitter follower circuit.
                        I might have to rethink this a bit, after trying to run the PSU at ~120 watts output, the 2n3055 started heating up a bit while the actual 10262 felt a bit cooler. Unfortunately I don't have any 2n3773's to try, and the pins of the 2n3771 I have are way too short (since it was a pull from a direct PCB mount with no heatsink), may have to add on some prosthetic pins and see if it will still fit and work...
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          and yeah, if the 10262 is more like a 2n3771 then yeah, the 2n3055 is probably not a proper sub. Then again perhaps the 10261 is a 2n3055 sub. Argh, whole point of the exercise is to find specs :\
                          Still haven't tried putting prosthetic legs on the 2n3771. Hmm. To start sacrificing other psus for parts or not...
                          • CapLeaker
                            Leaking Member
                            • 8286
                            What else you got on transistors?
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              most of the TO-3 pile I have are germanium PNP or Darlingtons for some reason. Have a few HOT NPNs (i.e. high voltage) and the 2N3055's.
                              I suspect the SCR and MOSFET TO-3's will never work...
                              • CapLeaker
                                Leaking Member
                                • 8286
                                Stick with the 3055 then.
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  The 3055 didn't like being paralleled with the 10262's... Not sure I want to burn all my 3055s by replacing them all so that the paralleled transistors match in type...(apparently the emitter resistors aren't sufficient to allow the 10262 and 3055s to be paralleled?)
                                  Aoso have a whole bunch of transistors that I have never identified fully... Have one typed "7652" though it too has cut leads and would need prosthetics to fit in the socket vacated by the 10262's...
                                  Also have PMD1702K and PMD1602K's ... and some of the 2n605x series. These are all darlingtons which I'd have to redesign the circuit somewhat to use...
                                    • Jul 2011
                                    • 6057
                                    Here is one place that you can find hard to find parts I have used them several times in the past
                                    https://www.questcomp.com/?gad_sourc...BoCxg4QAvD_BwE
                                    They have the 2n3055
                                    https://www.questcomp.com/part/4/2n3055/44231628
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8701
                                      Has 2n3055 officially been EOL'ed?
                                      • CapLeaker
                                        Leaking Member
                                        • 8286
                                        No. these are very much so alive just like some other real old transistor numbering.
                                          • Jul 2011
                                          • 6057
                                          Thet also have this one as well
                                          https://www.questcomp.com/part/4/2n3773/44234681
                                          This is not a complete part number “10262” according to Quest electronic website it shows that they are connectors of some type
                                          They have this one
                                          https://www.questcomp.com/searchresults.aspx
                                          They have this one
                                          • ahmedtou
                                            HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                            by ahmedtou
                                            help me please
                                            I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                            When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                            I will share all the details with you, including the disc information.
                                            Code:
                                            HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                            Current Profile: BD-R
                                            Disc Information:
                                            Status: Empty
                                            State of Last Session: Empty
                                            Erasable: No
                                            Free Sectors: 12,219,392
                                            Free Space: 25,025,314,816 bytes
                                            Free Time: 2715:27:17 (MM:SS:FF)
                                            Next
                                            08-27-2025, 08:49 AM
                                          • CoinCoin88
                                            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                            by CoinCoin88
                                            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                            09-15-2025, 03:36 AM
                                          • vikivng
                                            guys..i need help with this lcd display used on ebikes pls.
                                            by vikivng
                                            This is an lcd display used on ebikes.
                                            long story short, there was condensation inside the unit.
                                            I opened it and thoroughly cleaned the pcb with isopryl.
                                            The board had no visible corosion.
                                            It powered on fine and was tested for an hour or so.
                                            However when connected to the bike,,it did not power on at all.
                                            I took it home and reopened it to take a look. There are no shorts based on MY testing.
                                            However,,when I probe the transistor and the mosfet gate in diode mode or contuinity mode, (one probe on transistor collector and one probe on mosfet gate}the unit...
                                            09-16-2025, 12:56 PM
                                          • rabbituk
                                            Sony HCD BX7700dbi CMT flashing standby
                                            by rabbituk
                                            I have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
                                            So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode...
                                            02-11-2025, 05:05 PM
                                          • magneh
                                            Behringer Eurolive B205D repair - help identifying transistor
                                            by magneh
                                            Hello
                                            Got this speaker from a friend , defective. Power led comes on and off , in a loop.
                                            Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
                                            After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
                                            I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
                                            Still, I need to replace this transistor....
                                            06-18-2025, 02:34 AM
