OK to replace inductor with solder blob?
  • Agent24
    I see dead caps
    • Oct 2007
    • 5008
    • New Zealand
    Picked up some stuff that came with a Leadtek WinFast A250 LE TD.. That's a GF4 Ti4200 for those who can't decode Leadtek model numbering...
    Anyway, I was told it "only worked sometimes" - Tried it and it did nothing. black screen but no beeps.
    On inspection I found a leaky GSC which I replaced with a Nichicon, but still we had nothing doing.
    Closer inspection revealed that L809 was missing... Couldn't think of anything else to try so I just replaced it with some solder.
    The card now appears to work fine (Or at least in live Kubuntu 8.10 anyway)
    Do you think what I have done is OK? I'd try and find a replacement if I knew what value it was - but that might be just a little bit tricky..
    -David VanHorn
  • Wizard
    • Mar 2008
    • 2296
    Re: OK to replace inductor with solder blob?
    What kind of inductor it is? wound bobbin? Or just a "bar of dark grey" with solder on ends?
    Cheers, Wizard
    • Agent24
      I see dead caps
      • Oct 2007
      • 5008
      • New Zealand
      Going by the size of the pads and the other Lxxx components on the board, I assume it would be a bar of dark grey like the rest, with no markings.
      I don't have the original inductor, I got the card with it missing (and I presume why I was told it didn't work properly)
      -David VanHorn
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        Does the card give you stability issues when it's under stress? If not, then it's likely to be fine.
        Of course if you wanted to, you can always find a copper wire as thick as in the other inductors (or thicker if you want), wind it a few turns around something round (roughly about the same size as the other inductors), remove the copper wire from it carefully and solder the two ends of the copper wire to the PCB. It wouldn't be as good as the other inductors, but it's better than a jumper/ solder blob.
        • Agent24
          I see dead caps
          • Oct 2007
          • 5008
          • New Zealand
          The card has been running seemingly 100% stable so far all day (I'm just about to test it by replaying Prince of Persia - Sands of Time for a while)
          it would be impossible to wind my own inductor of the correct value
          As you can see from the photos I have attached - you can get an idea of the size by looking at the smallest one in the first picture - the 2nd picture shows by way of x-ray how these are constructed...
          -David VanHorn
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            got a air2pc atsc tuner card for $1 at a hamfest.
            had a inductor like that knocked off.no +5 to the broadcom nic chip=no workie.i took a similar part from a junk mobo and its working fine now.
            • Scenic
              o.O
              • Sep 2007
              • 2642
              hm..
              i bought a winfast A250 LE on ebay a while ago (still hasn't arrived yet -.-)
              i could look up the original component if you tell me where it is (and the card arrives *argh*)
              • Wizard
                • Mar 2008
                • 2296
                Got any junk stuff with those SMD inductor? Take one and solder it in.
                Cheers, Wizard
                • Tarot Superstars
                  What LED's to Buy To Replace Backlight LED's and What Solder with LED's
                  by Tarot Superstars
                  Hello.
                  I changed the led strips on my Hitachi 32 inch.
                  The TV is now ok since I have already replaced any capacitors that needed replacing.
                  I have also bought a spare set of LED strips for the tv also.
                  I want to be able to replace singular LED's in the LED strips if I need to, but I am not sure what value LED package to buy from Ebay in the UK.
                  The LED strips I bought were:
                  Replacement Backlight Array LED Strip Bar For Hitachi 32HB6J61U 32HBT41U 32" TV
                  On ebay I have a choice of singular LED's with voltage and...
                  09-02-2023, 02:44 PM
                • acedogblast
                  by acedogblast
                  11-02-2024, 05:13 PM
                • corrize
                  Best way to solder LVDS connector for beginner (and qfn) ?
                  by corrize
                  Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                  I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                  I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                  See the test :
                  https://youtu.be/bNAzC-EvqHs?t=1767
                  With hot air from bellow the board, that's...
                  03-09-2023, 02:57 AM
                • Bartoloni
                  Lenovo S145 -15iwl vcore inductor warm.. looking with oscilloscope there is a spike.
                  by Bartoloni
                  Hi, i have a Lenovo S145 that after 20 seconds shutdown and restart (it's working correctly on thse 20 seconds)
                  everything seems ok, but on Vcore inductor ( this is an i3 with just 1 switching power supply for CPU)
                  there is an output to teh CPU with a spike.. seems that inductor can't handle the input...
                  replaced the capacitor (330) and the inductor (R15) without any change
                  any idea? very thank you!
                  input of the inductor seems as usual... only strange thing is that the upper/lower voltages seems to be 21V (main power line is 19.3) ... but not sure this...
                  12-09-2024, 12:42 PM
                • myth77
                  UV solder mask - high temp resistent, recomendation?
                  by myth77
                  Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                  Is there any solder mask...
                  03-28-2022, 04:04 AM
