Test old MFM hard drive
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Test old MFM hard drive
    The epson PX-16 has jumpers that need configured else the drive won't spin. Are there any here?
    Follow the white rabbit.
      • 31025
      good read,
      so it's st506 with the data lines converted to ttl.
      • federalhouse
        **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
        by federalhouse
        I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
        **Background:**
        I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
        **What I've Tried So Far:**
        1. I accessed
        08-01-2024, 07:03 PM
      • tmcw
        PC case - Hard drive rails
        by tmcw
        A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
        So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
        I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
        Now, the case is a CiT Gaming Case, and...
        05-22-2022, 12:04 PM
      • madura2010
        DAY11AM6E0 hard disk drive and optical disk drive not detected
        by madura2010
        Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
        i checked the connectivity of ribbon=good communication with hard and motherboard
        changed hard disk and checked=3f0 error persist
        sata power=+5v available
        Then checked data capacitors=all good
        Then checked data lines path connectivity to pch=all good
        reflashed...
        03-12-2023, 09:09 AM
      • ash91
        Hp pavilion 15 not detect hard drive
        by ash91
        Hello gentelmen .... this is my first post and sorry for my bad english,
        so my proplem is my laptop keep losing hard drive even if i but the
        hard disk in the cady (the box that can replace the dvd rom with hard disk)
        when i turn the laptop on the massage that said no boot media found pop on
        the hard disk is fine and to be sure i try another hard
        i also update my bios to the last update
        the 5 volt is present on the hard connector on the motherboard
        the dvd rom work fine when i but a windows dvd in it
        also when i boot from flash...
        06-07-2023, 01:45 PM
      • ChaosLegionnaire
        bug of the month: write caching setting for the hard drive in device manager
        by ChaosLegionnaire
        i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
        so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...
        10-06-2019, 01:39 PM
