Shaded pole motor failures?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    I'm trying to debug a dehumidifier and found that the blower wasn't working.
    Taking it apart, I find... a shaded pole motor.
    These things usually don't fail?
    Anyway, it's apparently a 2-speed with three wires: black red and orange.
    Orange apparently is common, and the speed is changed by applying 120V to red or orange. Black appears to be "high", red is "low".
    I see about 7 ohms DC resistance from black-orange, 11 ohms from red-orange, and about 4 ohms from red-black.
    There does not appear to be any overheating indication on the plastic covering the windings and the shaft seems to turn freely when power is disabled.
    With 120VAC from Black-Orange, the motor seems to try to turn but won't turn, I feel a bit of magnetic reluctance to turn. Spinning the rotor by hand, it still refuses to continue - always slows to a stop. When power is removed, the spindle turns freely once more. It seems to spin fewer times to stop when power is applied.
    I don't get why this thing won't spin? Seems really odd here...shorted winding? But it didn't overheat?
    I suspect I'm in the market for a new motor most likely but this is baffling.
  • rievax_60
    • May 2012
    • 897
    • australia
    Re: Shaded pole motor failures?
    I know with ac induction motors, the rotor's squirrel cage bars can lose contact with the end rings. The one I saw wouldn't start form certain resting positions. Im not certain if it is possible for the copper ring on the shaded poles to fail.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Interesting. I just was wondering about the possibility of that happening after doing some more research. Any ideas how many percent of rungs need to be broken before the motor stops running?
      Now is it possible to repair these disconnects, perhaps soldering the bars back to the rings, or are the welded because of possible heat/vibration issues?
      After taking apart this failed motor, solder does not seem to be an option... or at least I'm not sure how it can be soldered... Now how was this thing assembled in the first place?
      • redwire
        • 3907
        I wonder if any of the shading coils are open circuit?
        With the rotor pulled out, could try put a screwdriver in and feel for the flux dead spots maybe.
        The stator coils are usually "impedance protected" so they don't care much if the motor is jammed, as long as the inductance is ok.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          I think rievax_60 got the answer. Call it poor QC for this chinese motor. I tried "banging" the ring closer to the bars and got it to temporarily work again, but not 100% sure. Either way, pulling the rotor and putting it back sometimes got it to work again.
          I think I'll need to get a new rotor, if I can't get a whole motor.
          • joshnz
            • Feb 2011
            • 969
            • New Zealand
            Is the short loop open?
            My pc
            CPU : AMD PHENOM II x4 @ 3.5Ghz
            MB : ASUS M4A89TD PRO USB3
            RAM : Kingston ValueRAM 16gb DDR3
            PSU : Cooler Master 850W Silent Pro
            GPU : ATI Radeon HD 6850
              master hoarder
              • May 2008
              • 12170
              • Bulgaria
              Interesting failure mode. So looks like the shaded poles are open? Or perhaps shorting to the case?
              The only bad shaded pole motor I saw was from a small duct fan. It had a fuse inside it that was blown. I replaced the fuse, and got it fixed again.
              By the way, I do have a spare shaded pole motor, and it does appear to be dual speed. Not sure what it came out of (found it in an industrial dumpster), but it's a fairly large one. Also have a washing machine universal motor in anyone cares. Came from the same dumpster and also appears to work fine. In fact, most of the stuff I have gotten from there seemed to work.
              • juergenb
                Nescafe Aeroccino, still fails with new Motor (red flashes only once)
                by juergenb
                i am asking for some Help.
                I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
                The Motor didn“t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
                So i got a few of these from Banggood.
                I swapped the motor and now i have a new fault condition.
                In a working Frother you would press the start button, it will light red and work for a few minutes.
                If you press longer it will light blue and just mixup the milk.
                With the new Motor it just starts...
                03-23-2021, 11:24 AM
              • sbt123
                charnwood w821 mini wood lathe motor problem
                by sbt123
                hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
                10-27-2024, 03:43 AM
              • Per Hansson
                Motor run capacitor physical size vs voltage rating & measurements?
                by Per Hansson
                (TL;DR skip the first paragraph)
                I encountered my first dead motor run capacitor at a customer this week.
                For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
                (Unless a servo motor makes more sense that is).
                But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
                The pump would run but sometimes trip the 10A breaker.
                I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
                Then it could...
                09-20-2020, 06:32 AM
              • mikey5791
                Help identify this motor
                by mikey5791
                Hi all forum members,
                Found this unknown motor discarded in a junk yard and took home for learning experience. By the look of it, I suspect it is taken out from a type of air blower probably running on ac power. I used digital multimeter on ohm/resistance scale and it doesn't read anything on those 2 black wires. So, this motor is not shorted and should be good to run.
                Correct me if i am wrong on the initial test.
                Can anyone kindly advice on how to test run this motor based on visible external two black wires. Fyi, i don't see any marking on the motor body nor smell anything...
                11-24-2023, 07:54 PM
              • cjard
                A motor controller is a power supply, right?
                by cjard
                Hoping someone here will be able to provide a few pointers with this. I've got a motor controller board for a device that moves a caravan. A DC motor on each wheel is supplied with 12v DC or -12V DC depending on whether the remote control is pushed in "forward" or "backward" mode. The control is arranged by having 2 relays per motor that, at rest, are all connected to the negative.. If the motor is to go forwards, then relay 1 activates meaning the motor sees "positive negative" on its terminals 1 and 2. If the motor is to go backwards then relay 2 activates meaning...
                10-14-2020, 01:24 PM
