Question regarding: HAVDD, HVIN, VONE, VOFFE
  • miksi
    • Apr 2016
    • 11
    Hello people!
    My knowledge so far:
    AVDD = positive voltage of analog circuit
    VIN = input voltage
    But what does the "H" prefix mean? I heard two different things:
    1. It stands for HIGH, meaning HAVDD is an upscaled version of AVDD.
    2. It stands for HALF, meaning HAVDD is AVDD/2.
    Both explanations make no sense when I look at my PCB and find the following markings: VIN_12V and HVIN_12V. That obviously tells us explicitly that both points have "12V" and VIN was not just Halfed nor High'ed, so I am confused.
    I also have no clue what VONE and VOFFE mean. I also have two theories about them:
    1. V=voltage (duh!) and "o" means OUTPUT! So both are voltages created by the circuit, not inputted. But then what do "NE" and "FFE" mean?? I also saw both markings without the trailing "E".
    2. Its a voltage that, if present, turns something ON or in case of "VOFFE" it turns something OFF.
    Does anyone actually know what these four acronyms stand for? The terminology drives me insane. Please help.
    Bye bye!
    Re: Question regarding: HAVDD, HVIN, VONE, VOFFE
    Are you talking about T-CON board?
    http://www.ti.com/product/TPS65177
    • miksi
      • Apr 2016
      • 11
      You're right, toying with a TCON board brought my attention tho those four termini! You think they are unique to TCON boards? From the TI.com website and docs I am not able to deduce a distinct definition for HAVDD, HVIN, VONE, VOFFE; they are mentioned in some spots and part of TI's description what their product does, but I still cannot figure out what the different is between VOFF and VOFFE, or VIN_12V and HVIN_12V.
      • mugunthans
        Samsung UN40F6400 No Picture Bad T-Con or Panel!!!
        by mugunthans
        Dear all,
        I have Samsung TV, which reboots continuously and I opened the TV and checked for loose connection - disconnect and reconnect all cables.
        When I power ON and noticed that its entered into Burn mode (RED/GREEN/BLUE) screen and I turned off and checked the cables again but this time it turned into white screen only. No matter how many times I restart the TV the result is same. But Sound is OK.
        Needed your help and expert advise, whether it is the TCON faulty or Total Panel Failure??
        TV Model: UA40F6400
        T-Con Model: BN41-01939B
        05-04-2021, 09:09 AM
      • cagri
        BOE HV650QUB-F70 TCON issue - VGH AVDD HAVDD no voltage - caps seem ok
        by cagri
        I have an Arcelik TV with BOE HV650QUB-F70 TCON board, but I think there's an issue with/around PMIC.
        PMIC: iML8940
        There is backlight and sound, but no picture. I watched a YouTube video and turned it off, half an hour later it was dead.
        Input 12v, fuse ok
        DVDD1V2 = 1.2v
        DVDD1V8 = 1.8v
        DVDD3V3 = 3.3v
        VGL = -7v
        **VGH = -0.3v
        **VCOM0, AVDD, HAVDD = 0v
        SWBK1 = 3.3v
        SW1 = 12v
        VGH to GND resistance is 500kohm as expected
        Readings are same after I disconnected the two cables from TCON to panel...
        07-27-2023, 09:48 PM
      • zen
        Electrohome HVIN-RR75-1 Mains transformer help please
        by zen
        Hi all
        Customer bought a retro stereo unit from Canada & didn't realise it was a 120V unit.
        Need I say more?
        Primary winding blown quite badly, therefore trying to work out the secondary AC supplies, of which there are two.
        AC2 which are the thicker BLUE wires go through a rectifier, then to a 25V cap, which narrows things down slightly.
        AC1 the yellow wires, after rectification go to regulator IC6, which may also be fried.
        The appliance is an Electrohome HVIN-RR75-1...
        10-07-2022, 07:42 AM
      • senakahks
        Samsung UA55HU7000 TV: HAVDD missing
        by senakahks
        I am working with a Samsung UA55HU7000 TV and backlight and sound works (volume up and down sound checked). But no picture. T-Con was replaced with a new one and still the result is same. Even with the old T-Con and new T-Con found that some voltages are missing. I feel the heat of main IC of the T-Con.
        HAVDD: 0V
        AVDD: 0V
        VCC3.3: 3.3V
        VCC 1.15: 1.1V
        What can be further investigates. Appreciate any support.
        09-20-2020, 07:14 PM
      • WackyWeasel
        Medion P16042 (MD 30671) TV from 2014, Samsung panel (?), problems on one side only
        by WackyWeasel
        TV: Medion P16042 (MD 30671) - sold in Austria 06/2014 (German end user manual)
        Mainboard: Medion MSD308BT1
        TCON: Y13_MB7S60TS4LV0.3
        Panel might be a Samsung LSC400HM06 (written near the mainboard)?
        Symptoms: Left side of display working perfectly, on the right side flashing noise & some scintillating pixels (starting pretty much at the half of the screen; see attached pics & video). Sound, Inputs... work fine.
        Some guy in this thread also has this board, there's a PDF with test points: Test points PDF
        I...
        02-03-2019, 07:55 PM
