Need help to ID this transistor
+ More Options
Posts
  • redwire
    • 3910
    Re: Need help to ID this transistor
    It may be basically an Armstrong oscillator, like used in Joule thieves and Tesla coils etc.
    I'm suggesting a partial schematic, rough scribblings. I don't know what the case connects to, or the two shorted pins- do they go to GND or case. Totally blind as far as even the pinout of this mystery transistor.
    Try measure inductance between the two pins, that will tell you if it's merely a transformer winding we are seeing.
    The only other reasons for a short there are melted pcb inner-layer, or a shorted speed-up driver.
    • CapLeaker
      Leaking Member
      • 8179
      O.k. that looks similar to what I see. It also uses a gate to source diode. That diode should be by right's very close to the FET. That would explain the short, or even a shorted ceramic cap. Now this is where things have me going. No shorts anything surrounding that area. Quite a few posts back on this thread, I did take that transformer out and the short persisted. However I just measured the 2 pads and I got 0.3uH inductance, same as if I short the leads. I also had discovered that there was a 3rd layer on the board. That layer is impossible to trace, since it is covered up and blocked from big fat traces on the either side of the board. As far as installing a replacement FET with a different case style, I am thinking to gut the TO-3 and use it to mount a TO-220 or whatever on that. So close, but yet still so far away. Ugh.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Ah so you did find a gate to source zener diode after all? That was the tell tale sign for a "professionally created" mosfet circuit... tells which pins are source and gate...
        Now if that were a schottky diode...
        • CapLeaker
          Leaking Member
          • 8179
          No, there should be a diode but coun't find that sucker yet. It should be close to the FET, but I have almost all smd stuff through on that board and no shorts anywhere. Even if I go with my Leakseeker 89, I always get back to the 2 pads of the TO-3. So almost as the short is intended to be there. At that point, I don't understand the whole thing.
          I did check the mosfet on the newer board, in which the schematic is for and there is no short between the gate and source pin. Unless someone can explain to me how this circuit is supposed to work with the gate to source pads shorted, I am going mad soon.
          • redwire
            • 3910
            The only other way, risky, to ID the short... if there's no other inductors/transformers it could be cause (low R reading)...
            I'd inject the two pads with a bench PSU set very low voltage say 0.3V and 0.5A. So "something" is getting power through it and will heat up. A thermal camera you can spot the short right away, even on less power.
            It's strange the PCB has these two pins shorted AND the removed transistor has these two pins shorted. Coincidence?
            • CapLeaker
              Leaking Member
              • 8179
              I may have to do that this way. I have to see a FET yet that is o.k. with 2 pins shorted?
              • juano777
                • Jul 2017
                • colombia
                #67
                hi any conclution about this? i have the same problem whit that ecu
                • CapLeaker
                  Leaking Member
                  • 8179
                  A short between the 2 pins on the TO-3 FET?
                  • Nick2k
                    • Oct 2019
                    • 3
                    Originally posted by R_J
                    Here is the info plus some other information in PDF But I believe it is for a different model ecm
                    • Nick2k
                      • Oct 2019
                      • 3
                      Hi there,
                      I know it is an old thread but it may help someone.
                      828S14 is not a FET it is a heavy duty fast recovery surge protection diode.
                      Both pins are shorted and measures like a diode from body to any Pin
                      as long as it is not shorted between body and pins its all good.
                      Also on PCB there is a track shorting these two pins and going to little transformer.
                      • redwire
                        • 3910
                        All the TO-3 diodes are dual except for power zeners. Are you sure?
                        Microsemi has 50W zener in TO-3 package with the two pins shorted, and either polarity available. Example Microsemi 1N2816A 18V 50W, standard polarity; anode is case.
                        • CapLeaker
                          Leaking Member
                          • 8179
                          Unfortunately at that time there was absolutely no reference available on what that 828S14 supposed to be. And I believe there is still no reference to this thing available, which makes it absolutely useless.
                          • On2ItDan
                            • May 2020
                            • New Zealand
                            #73
                            Hi Guys
                            Sorry for posting in this older thread but it does relate. This has been a good read regarding the Celect series controls
                            I have got one on the bench at the moment that will not power up. THer is no 5v supply at all. Have replaced the electro capacitors as these fell off due to vibration and age also replaced some open circuit resistors.
                            I have found that there is an SOT-23 packaged device that connects to the small transformer and the 67S01 device. I have circled the area in the attached pictures. THe device is difficult to ID as there is a hole in it. Plus I can not find data on the 67S01.
                            Can someone help to identify the SOT-23 device even if its just marking codes of a good unit we are trying to avoid buying new as theis is an expensive controller.
                            Thanks in advance
                            Daniel
                            • corrize
                              Where to find a very small fpc connector 0.3mm between 2 pins ?
                              by corrize
                              Hello, I search this connector (oxydated).
                              It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                              I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                              I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                              Do you know how to find this connector please ? What is the exact name for find it ?
                              08-06-2024, 05:25 PM
                            • SS454
                              vizio e650i-a2 backlight flashes then turns off
                              by SS454
                              vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                              panel: au optronics T650HVN05.4
                              72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                              link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                              Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                              https://www.shopjimmy.com/vizio-56-0...-power-supply/
                              Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                              08-20-2020, 03:57 PM
                            • DominanceINC
                              MSI Pro Z790-P Wifi 1missing CPU pins
                              by DominanceINC
                              I am a new forum member. I found a broken MSI motherboard with lot of problems. The other problems need schematic. Because, the missing parts what were breaking down with screwdriver and pliers at a standoff.
                              So, its actual problem is a missing Vcore and Gnd pins in the CPU socket. My question is that, can it be used safely without these two pins? Only for testing at first, while the other problems will be solved. I would wish repair them later.
                              The other spots are thermal phaste, because, the under educated installer of the CPU did wipe the contacts of the...
                              07-21-2025, 05:38 AM
                            • magneh
                              Behringer Eurolive B205D repair - help identifying transistor
                              by magneh
                              Hello
                              Got this speaker from a friend , defective. Power led comes on and off , in a loop.
                              Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
                              After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
                              I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
                              Still, I need to replace this transistor....
                              06-18-2025, 02:34 AM
                            • elsomer
                              help to identify transistor msi ms-15ck1
                              by elsomer
                              hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
                              02-17-2025, 05:30 PM
