Solar motor
  • juergenb
    Nescafe Aeroccino, still fails with new Motor (red flashes only once)
    by juergenb
    i am asking for some Help.
    I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
    The Motor didn“t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
    So i got a few of these from Banggood.
    I swapped the motor and now i have a new fault condition.
    In a working Frother you would press the start button, it will light red and work for a few minutes.
    If you press longer it will light blue and just mixup the milk.
    With the new Motor it just starts...
    03-23-2021, 11:24 AM
  • sbt123
    charnwood w821 mini wood lathe motor problem
    by sbt123
    hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
    10-27-2024, 03:43 AM
  • Per Hansson
    Motor run capacitor physical size vs voltage rating & measurements?
    by Per Hansson
    (TL;DR skip the first paragraph)
    I encountered my first dead motor run capacitor at a customer this week.
    For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
    (Unless a servo motor makes more sense that is).
    But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
    The pump would run but sometimes trip the 10A breaker.
    I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
    Then it could...
    09-20-2020, 06:32 AM
  • mikey5791
    Help identify this motor
    by mikey5791
    Hi all forum members,
    Found this unknown motor discarded in a junk yard and took home for learning experience. By the look of it, I suspect it is taken out from a type of air blower probably running on ac power. I used digital multimeter on ohm/resistance scale and it doesn't read anything on those 2 black wires. So, this motor is not shorted and should be good to run.
    Correct me if i am wrong on the initial test.
    Can anyone kindly advice on how to test run this motor based on visible external two black wires. Fyi, i don't see any marking on the motor body nor smell anything...
    11-24-2023, 07:54 PM
  • cjard
    A motor controller is a power supply, right?
    by cjard
    Hoping someone here will be able to provide a few pointers with this. I've got a motor controller board for a device that moves a caravan. A DC motor on each wheel is supplied with 12v DC or -12V DC depending on whether the remote control is pushed in "forward" or "backward" mode. The control is arranged by having 2 relays per motor that, at rest, are all connected to the negative.. If the motor is to go forwards, then relay 1 activates meaning the motor sees "positive negative" on its terminals 1 and 2. If the motor is to go backwards then relay 2 activates meaning...
    10-14-2020, 01:24 PM
