I always can't find my parts, I am A messy man. If I can't find it I reorder it is more fast than looking for it. I used shoe box problem is I have 10 of those I still can't find. I try use spreadsheet that is too much work and I forgot to input the quantity.
PS: I have 3 Compartment Organiser Boxes fill with old junks.
PS: And piles of piles PCB, when I need it. It is very hard to dig into PCB piles.
Here's all mine. Chinese take away tubs, some slightly larger with anti static bags in and some with multi compartments. Used with an excel spreadsheet so I know what I have and where it is.
smd parts need stickers on the strips or the reels depending on how many you have. mine are in strips . like 30 or something .. might be better to pop them out into a small jar but might get messy that way . i cant see them without my glasses on and under the magnifier glass .
For the Used parts only , i always leave them in their boards , and trace them when needed with schematics (the parts section ) . It's the best way i think .
But i guess , it's much easier when you have a successful business to find any part you'll need without going online .It's very rare for me to need online sites .
i use matchstick boxes (safety matches) for small parts. cheap, super cheap.
6 (or was it 8) tiny boxes fit into one larger box (those with 250-300 sticks inside) which is wide enough to fit a label.
dry by design, thick double cardboard walls, won't open by itself if it drops off the table
They're expensive on Amazon, here I can buy about 30-40 tiny boxes or 4 large ones for 1$
Save the striking surface has 50% red phosphorus on it. I've had play with this Smoking Fingers Trick when I was a kid. and Match heads can make A bomb (Armstrong's mixture).
Why don't use the storage bin that fishing hooks and lead waiter are they work real good you can buy them at Walmart or Home Depot that what I put all caps in .047uf to 47000uf
Well um pictures will have to wait as the bunker went from tidy to untidy in about a day. had a lot of repairs come in this week, for parts storage though I use double sided multi craft carriers / small organiser's that I get from one of the local discounter stores. Otherwise I have a large board repository which is split between working and boards for parts.
