Fluorescent desk lamp repair
  • redwire
    • Dec 2010
    • 3900
    Re: Fluorescent desk lamp repair
    This is cold-cathode? I see only two red wires going to the tube, but the fixture's schematic shows four wires.
    Philips Circline fluorescent tubes are all 4-pin hot-cathode (for starting) and they mention run voltage 61-84V for the 20-30W class T9 (12") size. You don't need really high strike voltage when the heaters are on, I've manually lit tubes then with even 24VAC.
    I think it's not a good idea to measure output voltage because it's high frequency AC which many multimeters can't read, chinese multimeters rolloff above 2kHz for example. Also, it should be high voltage with no load (tube not lit) which can kinda damage a multimeter.
    • caphair
      • Nov 2011
      • 1249
      @redwire Yes that’s the one you’ve linked. There are 4 wires that connect to the lamp itself further up and two of them have a capacitor across them.
      What’s a good way to test if the circuit is functioning properly? Can I just ohm check the lamp to determine if it’s not open inside?
      Do you know what voltage I should expect at both transistor pins?
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8684
        The two "ends" of the tube should appear open circuit at the voltages of a DMM, and the two filaments should be like incandescent filaments.
        Oddly enough I had a iinear F15T8 fixture that had a magnetic ballast that I replaced with a CFL circuit. The lamp turns on right away -- however, the CFL circuit does not heat the ends hot enough so basically it's running the lamp CC and though some tubes light, there are some F15T8 bulbs that do not light up in the fixture anymore.
        • redwire
          • Dec 2010
          • 3900
          At the lamp, you should get low continuity at each end (between the two filament pins) and of course nothing end to end. Compare it to the old tube.
          It seems like the oscillator is working because you measure some ACV on the output.
          I would test the 47uF electrolytic capacitor that had blown up before and the film cap at the tube.
          How it seems to work is the filaments at each end draw power through the film capacitor that is across the tube ends. It's just a dumb oscillator going for max all the time. No starter circuit.
          • RJARRRPCGP
            • Jul 2004
            • 6301
            Do the Phillips Alto F15T8s light up in that condition?
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8684
              I don't have an Alto F15T8 lamp, I don't remember what brands of LFL bulbs I had tested with. Chances are one is a GE and other is a Sylvania, both old and only one lights with the CFL ballast while both work with the magnetic ballast. The CFL bulb that I stole the guts from of course would be something like a spiral 13T4 or something like that, but that also did not noticeably heat the filaments on the spiral, unlike with the original automatic thermal starter on the F15T8.
              • RJARRRPCGP
                • Jul 2004
                • 6301
                The ballasts I have for F15T8, are the usual new solid-state stuff, TMK.
                (most likely a higher-than-AC-input-frequency switcher) (And it has to use a cap, TMK)
                I think all the T12 ballasts I have are low-frequency, (60 Hz and the like) they sound like the classic ballasts.
                Arc A770 16 GB
                • caphair
                  • Nov 2011
                  • 1249
                  #28
                  The lamp tests good. The capacitor not sure if it's good or bad but could only measure in ohms and gives a reading of 1.2 ohms across it when disconnected from the lamp
                  I may have previously measured voltages incorrectly. Those reading were DC when I try measuring AC it only reads 1.2vac at the wires going to the lamp
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8684
                    Well that seems suspicious?
                    Capacitors should show up as open or eventually open once it's charged, unless you're measuring its ESR then you want it as low as possible?
                    • caphair
                      • Nov 2011
                      • 1249
                      #30
                      Can I test if it'll light without that capacitor? Don't have another to replace
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8684
                        This is the cap that bridges two pins of the tube (that connects the two heaters together)? Might be able to test it, but without it, it's really running cold cathode now. However with it shorted it would cause other issues...
                          • 30953
                          something i'v wondered about these circuits,
                          how do you set the current/brightness?
                          • caphair
                            • Nov 2011
                            • 1249
                            #33
                            Yes it bridges one of the two filament pins. I tried without the cap but still nothing.
                            Im confused on how you would test this circuit if the output voltage is high frequency. Is an oscilloscope required?
                            And is my understanding correct that mains ac is converted to dc and then back to higher ac voltage to get the lamp running?
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8684
                              yeah without the cap the heaters wont heat and need a higher voltage to cold cathode start the lamp.
                              You need a faster high bandwidth RMS multimeter if you want faster results, or you could rectify the voltage with a diode and filter with a capacitor, but be careful of loading down the circuit.
                              Yes pretty much these things do a switcheroo from ac to dc and back to ac. The higher frequency is the main reason for doing this, not necessarily the higher voltage.
                              • caphair
                                • Nov 2011
                                • 1249
                                #35
                                So at the output of the tea sudores it would be ac voltage again? Just seeing what I could measure before that point to help see if the transistors are doing anything.
                                Curious how does higher frequency but not higher voltage help with turning the lamp on?
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8684
                                  it's AC again after the transistors but once again it's high frequency.
                                  The higher frequency doesn't help turning the lamp on ... it reduces the cost of the lamp (and has a side effect of faster, smoother startup, usually. Ever used the old mag ballast lamps? the ones that flicker as it turns on? Gone.)
                                  • caphair
                                    • Nov 2011
                                    • 1249
                                    #37
                                    Turns out it was the green cap across the lamp terminals. Didn’t have exact one so momentarily substituted with a 483pf one. Lamp lit then went off and puff of smoke came from the circuit board lol. Guess using the wrong cap for testing wasn’t a good idea? Lol
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8684
                                      Yay magic smoke
                                      483pF? not a standard value, weird.
                                      Original appears to be 2200pF?
                                      • caphair
                                        • Nov 2011
                                        • 1249
                                        #39
                                        Yay magic smoke
                                        At least that's what my capacitor tester said. Yeah original is 2200pf
                                        Would the smaller cap cause the light to go out and cause secondary issues?
                                        • eccerr0r
                                          Solder Sloth
                                          • Nov 2012
                                          • 8684
                                          Would have imagined no cap could possibly do damage, then too small cap would be the same, and shorted thus be the 'safest'... but who knows how the circuit was made.
                                          • eccerr0r
                                            desk lamp stopped working... stars?
                                            by eccerr0r
                                            How many bcn readers does it take to screw in a light bulb into my LED desk lamp?
                                            Answer: None. This is a nonreplacable-LED desklamp.
                                            So this lamp has one of those aluminum stars and an LED on it. It appears to be some sort of BGA or something with pins underneath. Anyway the PSU is 500mA 3.6V-8V meaning this probably was either meant to massively overdrive 1W LEDs or slightly over drive 3W LEDs...
                                            So it seems that typical 1W LEDs on stars are indeed 3.6V @ 300mA to get 1W which would be overdriven at 500mA, and 3W LEDs appear to be 3.6V@700mA which is a...
                                            10-01-2020, 12:45 AM
                                          • aneng
                                            What kind of desk lamp / magnifier do you use ?
                                            by aneng
                                            Hi.
                                            I need to get a bright desk lamp for working on PCBs and I'm wondering what is considered the best type to get for this kind of work ?
                                            I see there are a lot of magnifier type lamps with ring lighting, but the magnification is usually only 5x, which I don't think is going to be enough for SMD work, though it might be OK for larger components / general use.
                                            There are also the long LED strip kind.... which seem like they might be good.
                                            I think that either way, I want to go with a swing-arm type ('anglepoise' type) rather than a gooseneck...
                                            03-25-2021, 04:47 AM
                                          • vestaviascott
                                            Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
                                            by vestaviascott
                                            Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
                                            Here's what happens:
                                            1) Power on
                                            2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
                                            3) Blue status light flashes for appx 4 minutes...
                                            07-29-2020, 06:08 AM
                                          • AJ847.63e
                                            BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
                                            by AJ847.63e
                                            Hi All.
                                            Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
                                            The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
                                            09-18-2023, 06:42 PM
                                          • mikey5791
                                            Help on Samsung Syncmaster T220 dead ccfl lamp
                                            by mikey5791
                                            This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
                                            Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
                                            10-18-2020, 03:17 AM
