Help finding mosfet interchange
  • cwolford
    • Mar 2017
    • 46
    I have some bad, KHB 5D0N50f If you need the other numbers i can get them, but i think there production run numbers.
    I think this is the data sheet :
    So i dont know how to find a good replacement.
    I typed it in to mouser and It gave me STF5N52K3
    its data sheet:
    https://cdn.badcaps-static.com/pdfs/...1d17453f57.pdf
    seems they are out but digi-key has them
    http://www.digikey.com/products/en?keywords=STF5N52K3.
    Im still new to all this and not sure how close the parameters need to be, are what parameters for that matter.
    Thanks for your time and hopefully your help.
    p.s. If you got the time feel free to help me understand what we are need to compare.
    p.p.s. These run a back light to a tv. they get volt from 450v cap, send to transformer to get ~1000V+
  • capwizard
    • Jun 2016
    • 1991
    Re: Help finding mosfet interchange
    I would use this QPF6N60C 6N60 6N60C 600V 6A Canal N MOSFET.
    https://fr.aliexpress.com/store/prod...386774984.html
    PS: It is a TO-220F, it is easier to mount on heatsink.
      It has 2 Ohms RDS than his original which is 1.5 Ohms, so it will run hotter. I did not look at other the details spec to see what else are.
      https://cdn.badcaps-static.com/pdfs/...9f8cd02cf6.pdf
      • cwolford
        • Mar 2017
        • 46
        Seems the one mouser cross referenced seems bang on all for ID
        original= 5A
        mouser cross referenced = 4.4A
        How big of deal is this?
        thanks
        • Jane
          How do you test MOSFET in laptops ?
          by Jane
          I tried to use this method:
          Testing an N-channel MOSFET:
          Step 1: Discharge the Gate (turn off the MOSFET)
          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
          Step 2: Charge the Gate (turn on the MOSFET)
          Now, place the red probe on the Gate (G) and the black probe on the
          09-27-2024, 03:31 AM
        • Nooy
          VGA MOSfet permanently shorted and loss of MOSfet pad
          by Nooy
          Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
          I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
          02-14-2024, 02:26 AM
        • redbaron1007
          Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
          by redbaron1007
          I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
          Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
          09-09-2025, 11:10 AM
        • AppleLover123
          Asus X712EA 3 volts after the first mosfet
          by AppleLover123
          Hey guys,
          i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
          I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
          Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
          I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
          Now i thought something...
          12-15-2024, 07:49 AM
        • MicroSMD Lab
          by MicroSMD Lab
          I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
          01-10-2024, 06:36 AM
