XL7005A vs XL7005
  • Manuel S.
    Lenovo Yoga 720-15ikb (LA-E552P): DEAD - strange voltage on 5V buck converter
    by Manuel S.
    my Lenovo 720 is dead. :-(
    I guess i have found an issue on the 5V buck converter (**BAC7NH** from Silergy (also called SY8288C 5V)) but i am not completely sure so i want to ask here for some hints.
    Here is a Schematic of the IC: https://prom.ua/p1498216381-sy8288c-...ac-bacxxx.html
    When i attach the supply 19V, i only have 1.8V on the OUT (it should be 5V). The IC is getting hot.
    The EN1 is completely off 0V, EN2 show 1.5V.
    If i inject 5V on the EN1 the OUT goes up to 2.6V (but never reach 5V).
    BS seams SHORT to the OUT....
    03-14-2024, 05:17 PM
  • caspian
    Too much current from a Buck Converter
    by caspian
    Dear members,
    Let us consider the buck-converter circuit of +1.05VS_VCCPP in the PDF. +1.05VS_VCCPP is a 1.05v voltage rail. The schematic says the circuit can provide up to 20A of current. It belongs to a laptop: Lenovo G470. B+ is 19v.
    Now assume we connect +1.05VS_VCCPP to many ICs to provide power for them. The laptop works in a way that mostly less than 20A are drawn from +1.05VS_VCCPP but sometimes the required current exceeds 20A. For example, 25A or 30A.
    PU702 is the controller IC in the buck-converter circuit. It controls the output voltage according to the feedback...
    05-29-2020, 06:41 AM
  • adamski1952
    ps5 shorted after buck converter
    by adamski1952
    Hi.all.
    Working on a PS5 EDM-010 motherboard and i've located a short after the TLV62090RGTR 5v to 3.3v chip directly behind F7002.same chip i think. I've removed the chip thinking that was the problem but the short is still there.I injected 1v at 1 amp on output coil (arrowed in picture) but nothing shows up on my thermal camera. No boardview so I because I dont know which rail it feeds i'm reluctant to up the power injection.I could use some help with this if anone has any ideas. ...
    12-18-2024, 08:25 PM
  • caspian
    Causes of Failure After Buck Converter Repair in Laptop
    by caspian
    Dear members,
    Recently, I watched this nice video:
    www.youtube.com/watch?v=XBAn2Ck8GeE
    I have experienced such a failure many times in laptops.
    He replaced the Mosfets and the controller of a buck-converter in one go. But then after powering the laptop on, the new Mosfets burned again.
    What are the popular causes of the repair failure in this video?
    note: after removing the coil, he measured that the circuit is not shorted after the coil. only the circuit before the coil was shorted.
    03-28-2022, 12:57 PM
  • Thetechdude
    Repair help. Zotac trinity 4070ti 12G 3x
    by Thetechdude
    Hi Guys.
    Here I have a 4070ti with some issues.
    When powered on the led lights which power on (where the zotac logo is) flash green 3 times. Once it has flashed green 3 times it does not post.
    Just to mention I have not worked on many 40x cards before therefore some of my assumptions could be wrong. If you do happen to find that my analysis is wrong or I have missed something feel free to comment.
    Additionally, I do not have a schematic for this exact card model so if anyone is willing to post the schematic it would be much appreciated.
    Resistances:...
    09-07-2025, 07:49 AM
