What is this?
  • capwizard
    • Jun 2016
    • 1991
    What is this?
    What is this?.................
  • srhofmann
    • Aug 2016
    • 135
    • usa
    Re: What is this?
    Thermal limit switch, probably in a furnace.
    • capwizard
      • Jun 2016
      • 1991
      Re: What is this?
      That's fast, Yes, re-settable Thermal limit, Roll Out switch, I've spent an hour to research!
      One more question, how is the temperature rating? Thank you.
      PS: Its not for fun, I really need one, I've it broken.
        Re: What is this?
        Can you still read the print on the body? or if you have the wiring diagram of the furnace, it should be on the cover some where?
        • capwizard
          • Jun 2016
          • 1991
          Re: What is this?
          This was a service call, I took some picture and leave, and forgot about print on the body. now I can only use the color code to find out, otherwise I need to go black again. Thank you.
          • srhofmann
            • Aug 2016
            • 135
            • usa
            Re: What is this?
            Got the make model and serial number of the furnace? Your local parts house should be able to get it with that info.
              Re: What is this?
              They are normally closed switches and goe open when over safety temperature occurs so it will kill the power to the Gas valve.
              So, yes, the make and model will help.
              • capwizard
                • Jun 2016
                • 1991
                Re: What is this?
                Thank you very much, "Got the make model and serial number of the furnace?" This is a central air conditioner unit, I cant find the model no. From outside case of furnace, cant see any brand name on it, I too shame to ask for original manual.
                This is what I found it.
                Amazon: Carrier Bryant Payne HH18HA452 Roll Out Switch 250 Degree Temperature Rollout Switch with Manual Reset.
                Ebay: Furnace L290F Limit Switch 1NT08L, HH18HA490A, 9731V 290°....................this one..same color.....
                PS: Goodman/Janitrol Furnace:
                https://janitrolrepairparts.com/gas-valves/
                • srhofmann
                  • Aug 2016
                  • 135
                  • usa
                  Re: What is this?
                  There should be a stamped metal plate with all the info on it. It's usually located near the burners or the control board. You can't just guess at which switch to put in and just because they look the same doesn't mean that they are.
                  If it's an air conditioner/water chiller/heat pump there should be a label on the outside of the unit.
                  • capwizard
                    • Jun 2016
                    • 1991
                    Re: What is this?
                    Ok, I will go back ask for original user manual if they still have it or take more clear pictures, because cooling unit is inside the 2nd floors ceiling.
                    PS: this is not the original problem, which is after I took out 2 thermostatics, furnaces fan till random on and off, my next step is to clean this (Goodman Janitrol Amana B13709-08 limit switch 7" L160F-30 B13709-08).....
                      Re: What is this?
                      https://www.badcaps.net/forum/attach...5&d=1483550281
                      What are printed on that white 8.5 x11 paper?
                      • capwizard
                        • Jun 2016
                        • 1991
                        Re: What is this?
                        Instructions, How to turn on and off the gas pilot light.
                        PS: The switch broke but inside circuit still in shorted condition so furnace is working......probably (silicone)s it back......original is the best................you know.....I did not touch that switch......
                        • capwizard
                          • Jun 2016
                          • 1991
                          Re: What is this?
                          Thanks to srhofmann:
                          This is what I found it, which is wrong one
                          Found the model NO.
                          GMP075-4
                          https://cdn.badcaps-static.com/pdfs/...e2ee1acf8b.pdf
                          Is this the right one? B1370154 350 F
                          Goodman Amana B1370154 Flame Rollout Switch 350° OEM - NEW **Free Shipping**
                          http://www.ebay.com/itm/Goodman-Aman...igHyVKD116BzMA
                            • Jul 2011
                            • 6070
                            Re: What is this?
                            Is the thermostat calling for heat all the time if
                            YES then check these items
                            Dose the fan stay ON all your the time when you put the fan switch to
                            (Run or ON-not on AUTO) if dose stay ON all the time then you ether have a bad fan switch on the thermostat or a bad fan relay
                            Or you could have a bad fan motor run cap or a ( bad fan motor winding ) on low speed this does not happen very often but I have seen it before to see if this is the case change to a higher fan speed and see if it dose the same thing or not
                            If NO
                            Then check the furnace to see why it is not calling for heat
                            • capwizard
                              • Jun 2016
                              • 1991
                              Re: What is this?
                              Thank you for your advice I really appreciate it.
                              • srhofmann
                                • Aug 2016
                                • 135
                                • usa
                                Re: What is this?
                                B1370154 350 F looks like the right part number to me. Just as a double check make sure that it is in series with the other roll out switches. Wouldn't want to put a roll out switch (350F) in instead of a primary limit switch ( approx 200F).
                                Let us know how things go.....
                                P.S. Thanks for the link to the manual.
                                  Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                                  This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                  09-06-2024, 05:30 AM
                                • Natob82
                                  Micro Momentary Push Switch?
                                  by Natob82
                                  Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                                  12-21-2022, 05:22 AM
                                • grimacelord
                                  NEC TurboExpress On/Off Power Switch Replacement Help
                                  by grimacelord
                                  I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                                  I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                                  I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                                  11-09-2023, 09:49 AM
                                • SluggerB
                                  Help making a switch work the opposite way with a relay
                                  by SluggerB
                                  I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                                  I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                                  It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                                  02-07-2025, 07:57 PM
                                  Modifying a 4 Position Universal Rotary Cam Changeover Switch LW26-20 for more cams
                                  by sam_sam_sam
                                  Panel Mount 4 Position 8 terminals Universal Rotary Cam Changeover Switch LW26-20 20A
                                  ( needs more cam circuits for the machine to work correctly again )
                                  https://www.ebay.com/itm/275321870186
                                  To
                                  3 Position 16 Terminals Universal Rotary Cam Changeover Switch LW28-20 20A
                                  ( not 4 positions but the right amount of cams circuits )
                                  https://www.ebay.com/itm/274660439950
                                  I going to take the 4 position cams selector switch and remove the cams that are on it and remove the cams off of the 3 position selector switch and swap them around...
                                  03-18-2023, 05:12 PM
