I have these two westinghouse breakers that with the moving of a wire from one terminal to another converts it into a 2-pole cutoff switch.
I use them as a way to allow me to work on the meter I have installed in my room ( I use a LOT of power) as well as to isolate the electrical outlets in my room.
Recently the one for my Silicon Graphics desksides has been starting to arc and things got serious this afternoon when I started to smell overheating bakelite and opened the switch to see one of the contacts glowing red and arcing uncontrollably.
I switched the power off and removed the breaker and have went with my dremel and ground all the contact surfaces in the affected area until I no longer saw pitting and a resistance check is giving me 1.3 Ohms. The problem is that I did this once before and it happened again. Is there any way to ensure a good connection this time around? I don't think I can do this again.
I would also rather not burn the house down.
EDIT: I can post pics of the breaker on request.
<----Computer says I need more beer.
