Repairing a breaker
  • pentium
    • Mar 2006
    • 2778
    Repairing a breaker
    I have these two westinghouse breakers that with the moving of a wire from one terminal to another converts it into a 2-pole cutoff switch.
    I use them as a way to allow me to work on the meter I have installed in my room ( I use a LOT of power) as well as to isolate the electrical outlets in my room.
    Recently the one for my Silicon Graphics desksides has been starting to arc and things got serious this afternoon when I started to smell overheating bakelite and opened the switch to see one of the contacts glowing red and arcing uncontrollably.
    I switched the power off and removed the breaker and have went with my dremel and ground all the contact surfaces in the affected area until I no longer saw pitting and a resistance check is giving me 1.3 Ohms. The problem is that I did this once before and it happened again. Is there any way to ensure a good connection this time around? I don't think I can do this again.
    I would also rather not burn the house down.
    EDIT: I can post pics of the breaker on request.
    Find Nedry!
    Check the Vending machines!!
  • Wizard
    • Mar 2008
    • 2296
    Re: Repairing a breaker
    1.3ohms is still no good. Replace breaker. Once burnt it's junk. And heat changes the structure of the rolled, heat treatment of steel and stamped parts is permanently ruined.
    Safety FIRST especially the mains power.
    Cheers, Wizard
    • pentium
      • Mar 2006
      • 2778
      *sigh* I was afraid of that.
      Find Nedry!
      • Krankshaft
        • Jan 2007
        • 2328
        My house used to have blade switches on the mains too they were replaced in the 80s .
        Those things frighten me and I work with mains voltage all the time. I don't like all of the exposed contact area.
        I always think of raising Frankenstein's monster.
        Is that Romex coming out of that recepticle plug ?
        I don't know about you but my inspector would slap me if they saw anything even close to what you have there .
        • Harvey
          • Apr 2007
          • 264
          Hmmm.. looks rather dangerously thin wire to me...
          • pentium
            • Mar 2006
            • 2778
            Nope, it's all up to standard. Trust me, the wiring won't fail.
            15A Romex to be correct.
            Ssh!
            Find Nedry!
            • pentium
              • Mar 2006
              • 2778
              Well I got it down to .7 ohms which is exactly the same as the other pole in the switch which was not damaged. Is that any better?
              Find Nedry!
              • pentium
                • Mar 2006
                • 2778
                damn, editing time limit...
                Another thing I forgot to mention is that pretty much the whole thing uses brass with the exception of the optional breaker heater and the spring-loaded switch assembly.
                Find Nedry!
                • Wizard
                  • Mar 2008
                  • 2296
                  the contact buttons are specially made with different metal, grind this off and it's no good for long term.
                  Cheers, Wizard
                  • pentium
                    • Mar 2006
                    • 2778
                    I don't get you.
                    The contacts and terminals on this thing are solid brass.
                    Find Nedry!
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      throw it out already.
                      not worth the risk.
                      you cannot be sure it will trip when it needs to.
                      do you sleep in a nomex suit?
                      • pentium
                        • Mar 2006
                        • 2778
                        Fine.
                        The problem now is finding two new cutoff switches to replace it.
                        Not only do they have to be somewhat small but they both need to have the ability to be locked out as well as at least have two poles per switch.
                        Find Nedry!
                        • malmal
                          • May 2008
                          How many ohms indicated with the leads touching each other?
                          Dont know if that VOM is good enough.
                          You could put 15 amps through the breaker and measure the voltage drop. IICR the normal max drop should be under 50 mv.
                          Please correct me if the drop is incorrect.
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            It would cost more in set-up and materials than just buying replacements but contacts can be repaired. With our gear if we were out to sea and had to fix a switch or breaker contact like RIGHT NOW then we would electroplate them with silver. It was an approve procedure even for NUC gear. Silver is preferred because it is harder than gold and silver oxide is nearly as conductive as silver.
                            Mann-Made Global Warming.
                            - Dr Seuss
                            • pentium
                              • Mar 2006
                              • 2778
                              I could try plating it in copper some day but for now I think I have found suitable replacemens at the local used construction supplies facility. They even have lock-out slots so I can pass a bar through the switches and keep them either on or off. They are also rated for 20A. Cost: $20 for the pair AND they are Allen Bradley (a brand I know well)
                              Find Nedry!
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                Copper would work if you have the right alloy. I don't know what alloy that would be though. There are hard and soft alloys of copper. You would need one of the hard ones. I did once fix some eroded copper the contacts in a Chrysler starter solenoid by brazing over it using a bronze rod and then grinding it back down. That was tricky to do but turned out to be a permanent fix.
                                - Dr Seuss
                                • pentium
                                  • Mar 2006
                                  • 2778
                                  What about electrolysis?
                                  Find Nedry!
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    I think you mean electroplating like I mentioned before about silver.
                                    Electrolysis is a process to separate things, not put them together.
                                    You'd need to study some chemistry, buy some chemicals, get a tank, build an agitator, have a suitable DC power supply, and to know how to play with the chemicals to get the alloy you want.
                                    For the silver plating we did we just ordered the kit already designed for our application. The closed thing to chemistry we had to do was measure amounts per the directions in the kits.
                                    - Dr Seuss
                                    • pentium
                                      • Mar 2006
                                      • 2778
                                      Okay then, I'll just install the new switches.
                                      Find Nedry!
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        That makes more sense.
                                        I wasn't trying suggest you repair those. Not practical.
                                        I was just pointing out that if there was enough of a need to it could be done.
                                        - Dr Seuss
                                        • BigTroll
                                          help with home a/c and circuit breaker
                                          by BigTroll
                                          while I was gone today the women called me and said the a/c isn't working and the breaker is buzzing so she turned off the breaker. The a/c is a old 1993 model York so its nearing the end of its days, on really hot days the a/c will trip the breaker.
                                          I visually checked the cap and contactor and they looked okay, I also pulled the 250v ac fuses and switched the main ac breaker on and got no buzz. I did get buzz when I put the ac 250v fuses back in and flipped on the breaker nothing but buzzing. could it be a shorted wire or did the circuit breaker just finally give up the ghost?...
                                          09-05-2020, 07:53 PM
                                        • notallbad
                                          Rockworth breaker burning out motor
                                          by notallbad
                                          Got given this breaker to fix, armature had failed so replaced and the same thing happened.
                                          Its a 240v heavy duty breaker as opposed to site 110v.
                                          The 1st armature was bought from aliexpress and advertised as 240v but burnt out within 2 minutes light use taking the 13amp fuse with it and the 2nd bought from ebay (german seller) started to get very hot and begin to smoke so hopefully saved it by shutting it off quick at the first sign of smoke but have now tested the x2 safety cap and its not reading 0.22uf, much lower.
                                          Theres very little to it really on the...
                                          08-16-2024, 04:46 AM
                                        • Kezi Gamer
                                          Marshall stanmore multi room
                                          by Kezi Gamer
                                          Hi, recently i have encountered problem with my Marshall stanmore multi room speaker, speaker itself works fine using app from my phone but knobs on actual speaker doesn't work. First thing that came up to me is that maybe something is shorted on the top board and after disassembling the speaker and checking with multimeter I could not find anything wrong, also on the panel multi, and next song button are working and nothing else. Any help is very appreciated​...
                                          03-24-2025, 08:37 AM
                                        • petehall347
                                          correct way to wire this breaker
                                          by petehall347
                                          ok i have this new mcb 40 amp breaker but its not marked which is line in and load and live and neutral .everywhere i look they are wired differently . i know single ones its line in at the bottom and load at the top . the data sheet doesn't say .it only has a diagram on it ....
                                          07-10-2024, 01:37 PM
                                        • beetle1303
                                          Electric oven tripping circuit breaker after turned on for 3-5 minutes
                                          by beetle1303
                                          My electric oven was working fine all the while from purchased 2 years ago. I have been using it weekly for about a year, but stopped using for a year now since then.
                                          When I turn it on again yesterday, the tripped the circuit breaker and whole house no power supply. I reset the circuit breaker, and retried. Same thing happened.
                                          This is what happened:
                                          - Turned on the oven power supply, set temperature to 200c, everything worked for a few minutes, then the power tripped. Oven was warmed/hot.
                                          - Reset circuit breaker, retried, same thing happened.
                                          05-03-2020, 09:18 AM
