Multiple 555 timer question
  • zalmaflash
    • Feb 2016
    • 17
    I want to know if I can trigger three 555 timers (one shot mode for all) from one trigger source on pin 2.
    Timer A, timer B, and timer C to all start at the same time from one one second trigger push. They will then time out at different times (which I can set)
    Yes, I know it will work in my experiment but that was a short time. I want this to work indefinitely (one or two triggers every hour or two) for a couple years.
    To try to make it clearer - a motion detector is triggered. The aux. contacts close for a second or two and triggers all the 555's. Timer A stays on for 5 seconds, timer B stays on for 10 seconds, and timer C stays on for 47 seconds (all made up times and I do know how to set them) Each timer will operate an individual NPN. All timers will be mounted on the same small perf board.
    Will this last without undue stress on any component?
    The operating voltage is 6vdc or 9vdc and adding IN4148 diodes inline to each trigger is my next thought.
    Thanks in advance for any and all input.
    Re: Multiple 555 timer question
    There should not be any stress in the circuit as far as the triggering concerned, and yes, I would use the diode for each trigger line to isolate each timer trigger pin, the Cathode side will be grounded to trigger the timer.
    The stressed parts will be the Output of the 555, it depends on how much load current will be, and what kind of load will be, inductive or resistive loads? Sink or Source the load?
    Sounds like you are going to use the Output of the 555 to drive the Transistor, so that is light load.
    I would also use non electrolytics cap for timer so you do not have to worry about the caps dry out and lose its capacitance.
      • 31131
      it would be cheaper to use an 8pin pic-chip
      • zalmaflash
        • Feb 2016
        • 17
        Thanks guys for the input. I'll give it a shot (one).
        • Longbow
          • Jun 2011
          • 623
          Your idea is not described in a way that encourages comments. It is clear that several 555's can be triggered at the same time, but how many depends upon your V+ and triggering source. Normally, logic triggering is set to be the shortest pulse that will achieve reliable triggering. A one-second trigger will cause you lots of headaches since it will interact with the other timers, as well as preventing proper operation of a timer that is set to less that one second. De-bouncing is always a good idea. Since I have never triggered multiple timers at once I can't say whether there will be any consequences from having them all hooked up to one driver - something tells me you will have to deal with the triggering source to isolate the individual 555's.
          After all, one or more sections will be timing out whilst the others are still in the timing mode. Which brings up the question - you have described monostable operation. What do you want the timer to do after it cycles? How will all the timers in the design return to ready state? Must all the timers be in the ready mode before any of them can be triggered? You have some extra logic functions to perform.
          A block diagram of your design, perhaps?
          Is it plugged in?
          • DeanWy
            WD Sentinel DS5100 (NAS) boot issues
            by DeanWy
            I have a Western Digital Sentinel DS5100 NAS system which has stopped working. It has dual BIOS. I bought the system second hand with an already broken primary BIOS (it rebooted multiple times until second BIOS was used).
            It worked until recently. The system was idle in Windows Server 2012 and a BSOD occurred, I think it was 'critical process died'. Thereafter it didn't boot, it just sat there with no video output and fan speed at 100% (there's a proprietary Windows driver by WD which controls the fan, outside of that it always runs at 100%).
            There...
            07-30-2024, 04:13 AM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
            STM32F103C8, STM32F103R8, STM32F103V8, STM32F103T8, STM32F103RB, STM32F103VB, STM32F103CB, STM32F103TB Datasheet
            The STM32F103C8, STM32F103R8, STM32F103V8, STM32F103T8, STM32F103RB, STM32F103VB, STM32F103CB, STM32F103TB medium-density performance line family incorporates the high-performance Arm Cortex-M3 32-bit RISC core operating at a 72 MHz frequency, high-speed embedded memories (Flash memory up to 128 Kbytes and SRAM up to 20 Kbytes), and an extensive range of enhanced I/Os and peripherals connected to two APB buses. All devices offer two 12-bit ADCs, three general purpose 16-bit timers plus one PWM timer, as well as standard and advanced communication interfaces: up to two I2Cs and SPIs, three USARTs,...
            10-07-2024, 04:40 AM
          • martonmiklos
            Dyson DC45 trigger board burnt brush motor driving SO8 IC
            by martonmiklos
            Hi fellows,
            I am trying to repair a Dyson DC45 battery powered hoover.
            There is a trigger board in it which hosts an Attiny48 and some power stage to drive the brush motor.
            Unfortunately a SO8 component burned to hell in it together with a 0603 resistor and the IC could not be identified.
            The Attiny output looks to be survived the problem because when pulling the trigger it outputs high for a while and then turns off.
            It is likely that it measured the current on the R10 shunt and this is why it is shut down.
            I have attached...
            06-29-2024, 12:21 PM
          • Msb1xr
            Have to turn on 77” LG C1 multiple times to get to come on
            by Msb1xr
            Have to turn C1 on and off multiple times for it to fully come on
            Have to run LG C1 on multiple times for it to fully work
            If I have it off for a while I have to turn the TV on and off and handful of times for it actually display what it's suppose. The times it doesn't nothing comes up like the input or dobly vision logo. Once it's on I can turn it off and back on fine and the picture looks perfect.
            Unhooked everything except antenna. Reset tv to factory settings. Let it sit and when I tried 2hrs later turned TV on and sound comes through but no picture....
            10-13-2023, 04:09 PM
