Slowing Down A Fan
  • USchabon
    • Jun 2016
    • 116
    Slowing Down A Fan
    I have a 10" fan that runs fast, super fast and warp speed. Is there a regulator I could use to lower the voltage it gets so that it draws less and runs slower?
    Main thing is cheap safe and durable since I want to plug it and forget it, but a dial knob and an on off switch that I could run about 4-6 feet from the plug, or 3 feet from the fan would be awesome of under 10-20 bucks.
    Glad to build it too, would be a nice little beginner's project actually.
    • 31281
    Re: Slowing Down A Fan
    depends on the type of motor
    • artstv1
      artstv1
      • Sep 2014
      • 10
      • sarasota
      Install a dimmer switch in the ac line.
      • R_J
        • 9623
        Dimmers are for dimming lights(resistive load) they are not for controlling a/c motors (inductive load)
        • rhomanski
          nowhere man
          • 5157
          • U S of A
          I had an overhead fan in my living room on a dimmer switch, worked fine. Had the same kind on my whole house fan. They used PWM and and never had a problem with them.
          sigpicThe Sky Is Falling
          • kaboom
            "Oh, Grouchy!"
            • Jan 2011
            • 2507
            They do not use "PWM." It's phase angle control.
            Just because you've never had a problem doesn't mean you didn't do a hack job- the proper control is a fan control, not a "dimmer."
            A common "light dimmer" control has only two wires; it derives its trigger signal through the load (it can because incan lamps are resistive) during the "off" time.
            A "fan control" has an extra wire for control power. These do not derive the trigger via the load return; they cannot because the load (fan motor) is inductive, which disturbs the symmetry of the triggering.
            Put a "light dimmer" on a motor and the triac is triggered asymmetrically. Tell me, how does an induction motor deal with the effective DC offset? The motor "rumbles" and hums. If the core saturates, the triac blows, usually one half. Once that happens, you put DC straight into the motor.
            Again, tell me how that'll go...
            Don't post "hack stories" and misguided "advice" to new members and expect some kind of reward; this isn't betanews.
            Oh, I've screencapped this post should it "disappear by accident," as others have...
            "pokemon go... to hell!"
            EOL it...
            All style and no substance.
            guilty,guilty,guilty,guilty!
            guilty of being cheap-made!
              https://cdn.badcaps-static.com/pdfs/...224bd7f185.pdf
              http://www.kbelectronics.com/Fan_Spe..._Controls.html
              We still do not what kind of Fan he has.
              • rhomanski
                nowhere man
                • 5157
                • U S of A
                I didn't tear it apart and check it out. Just read the package. It said it was safe for fans and it had, I'm thinking, 3 wires. It was twenty years ago. It wasn't a hack job.
                • kaboom
                  "Oh, Grouchy!"
                  • Jan 2011
                  • 2507
                  Sounds like the right one.
                  But don't call it a "dimmer," it just adds confusion... I only made a "big deal" over it because our stupid locals think there's no difference and use the part that's "cheeper."
                  It may have the same triac and variable trgr ckt as a "dimmer," but it's not the same thing.
                  Originally posted by budm
                  We still do not what kind of fan he has.
                  You don't put a "dimmer" on a motor, period. You use a "fan control," (or variac, or resistor bank if long ago) and not haphazardly either; never with a "split-phase" motor with a start switch. Run them too slow and the start winding never gets switched out!
                  On PSC or shaded pole motors, they're usually OK. For a single reduced speed, an AC rated cap in series will also work.
                  EOL it...
                  • rhomanski
                    nowhere man
                    • 5157
                    • U S of A
                    It was expensive, became a pain in the a$$ too. I was trying to put door stops and brass plate light switches on at the same time. The only plates were three gang regular holes. I put two rectangular "fan control/Dimmer" with the one switch. I had to drill holes and nibble and finally file it square. Took a couple months to replace all of them plastic switch plates. The house was new and needed a lot of little touches. Towel racks and toilet paper holders too.
                      That is my point since he did not identify what kind of fan he has and people start suggesting using light dimmer without knowing what kind of fan it is before giving the answer such as post 3. Post 2 asked OP the right question.
                      If he indicates the AC in the beginning then he could have gone to the KB link I provided, LUTRON website also indicates not to use dimmer with inductive load, they also make FAN speed controller. If it is DC motor (what type of DC motor)) then another kind of controller (PWM, etc.) will be required. Not completed info does not help.
                      BTW, I did not suggest to use light dimmer either.
                      • USchabon
                        • Jun 2016
                        • 116
                        Hello guys. Sorry about the delay. here is a photo of the motor.
                        • USchabon
                          • Jun 2016
                          • 116
                          BTW, I have no clue what kind of motor that is, that is why I posted a photo
                          • kaboom
                            "Oh, Grouchy!"
                            • Jan 2011
                            • 2507
                            C-frame shaded pole motor- perhaps the most common "modern" small fan motor...
                            EOL it...
                            • USchabon
                              • Jun 2016
                              • 116
                              Cool, thank you for your replies.
                              Just cause I am a bit of a noob and I don't want to make the wrong purchase, what would be the best way to control the speed on one of these (and hopefully be able to turn on/off and control from about 3-4 feet from the fan itself)?
                                Just do the search for 'shaded pole motor speed control'.
                                You may also be able to find one with wireless remote control too.
                                  • Jul 2011
                                  • 6070
                                  Where I work we have a air dryer that the system was going on and off to fast because
                                  The condenser fan was running to fast it has a fan motor very similar to your fan the only difference is that this motor is sealed to keep the dirt out
                                  You can find motor controller for this type of motor
                                  On these controllers you have to adj the min speed pot so the
                                  motor run smooth other wise the motor will not run and may over heat
                                  Here is where you can find one not from Johnstone Supply but the company that makes the controller
                                  I hope this helps
                                  I have use these before and they very good
                                  https://m.johnstonesupply.com/storef...ep?pID=G22-731
                                  • G0RIT
                                    Reebok one GT40s treadmill lift motor runs at switch on
                                    by G0RIT
                                    Good evening I am working on a Reebok oneGT40s treadmill. It had a flashing display which the replacement of D3 rectified. However the lift motor now runs when the mains is turned on and does not stop. If I then select start so the tread motor runs and disconnect the up lead to the lift motor it stops. If I then reconnect the lead the lift motor works as it should with the controls. It will continue to work correctly until the mains is turned off and on again, or the safety device is removed and replaced. It then runs again and only by disconnecting and reconnecting the up lead will it operate...
                                    06-23-2022, 05:57 PM
                                  • tyl85
                                    Imac A1418 late 2013 21.5" fan runs at max speed
                                    by tyl85
                                    Hi, i have this iMac issue
                                    I've checked temperature by using macfans with no results
                                    techtool pro shows me AMBIENT AIR TEMP FAULT
                                    i'm going crazy, the mac runs very slowly
                                    where i can find this sensor on motherboard?
                                    thanks in advance
                                    12-03-2024, 01:09 AM
                                  • pb1911nt
                                    820-4924-A Runs suspiciously slow - what could you measure?
                                    by pb1911nt
                                    Hi
                                    I have now a 820-4924 (with a i7 and 16GB).
                                    I would like to get the device working again for me.
                                    The Problem is the Device comes to me with a "dead" ssd. I tested on a other 820-4924 (i5-8gb) board and the MAC OS Installation stopped working with this SSD.
                                    Well i hope/guess its was a easy peasy Fix - New SSD And its working again.. But No!
                                    I don't know exactly how the procedure should start. But the LCD panel goes dark - then the "chime"(?!) sound comes and only 2 or 3 seconds later the apple comes.
                                    it doesn't...
                                    10-27-2025, 08:48 AM
                                  • DrDos
                                    Unit runs but no speaker output kenwood KR-6030
                                    by DrDos
                                    I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
                                    09-14-2025, 09:57 PM
                                  • larrysito111
                                    dell alienware m17 r5 LA-L761P liquid damage no image on lcd 2red 7blue runs on external
                                    by larrysito111
                                    got here a liquid damaged alienware
                                    the laptop had damage in the area of the kb9542qf2 all sorted and now laptop working and turns on but i have no display
                                    so if i start and connect usb-c display it works otherwise it is giving me the 2red and 7blue
                                    so with the usb-c external monitor is getting to bios and OS
                                    otherwise not
                                    so if it is in the os and i connect another lcd via onboard hdmi it is working no problem 2 lcds (1 usb-c + 1 hdmi)
                                    but still not the internal monitor
                                    (tested 3V and 5V going to the...
                                    06-12-2025, 04:16 PM
