Need Source for Refrigerator Motor
  • Longbow
    • Jun 2011
    • 623
    Getting it Done
    Silly questions: no doubt the right person would have access to any number of scrap units that might fit into the refrig. It isn't a mental stretch to guess why those units ended up in the scrap heap in the first place. Sure, everyone gets lucky sometimes. The motors might spin up and work OK for a while. But actual testing involves more than just spinning up the motors at room temperature.
    The main question is whether the OP is willing to be an on-site testing lab for scrap parts with unknown histories. As scientifically interesting as it is, we know that motor failures mean spoiled food, and a watery mess on the floor. So at this point we are back to the original valid reservations for installing a repaired or scrap part. How much is your spoiled food worth? How much of your time are you willing to waste on locating a cheap replacement part? After all, a motor is just a motor - right?
    Is it plugged in?
    • keeney123
      Lauren
      • Sep 2014
      • 2536
      Re: Need Source for Refrigerator Motor for free
      So I guess it depends on how fast the first one failed as to whether I would want to repair the part, what part of the motor failed, how much money I make in a paycheck, if I could source the parts. As I say it is complicated. If the part failed at less than 5 years it would peek my interest to why and do I have to do this every five years. If the part that failed is the bearings most likely it can not be source. There is no good reason for this other than the manufacturer wants the customer to throw the thing in the junk yard so they can sell you a new one instead of selling you some $0.50 bearings. If I make minimum wage then I would not have $120 to spend every 5 years just so I can have a fan for my freezer. By being able to repair my equipment I hold cost down, not just for myself but everyone else. These companies are less likely to dictate the price and when the device will fail. Whether one likes it or not, one has to fight to improve life for humanity. If one is unwilling to do this then one's life in humanity will grow worse. Personally I do not like that outcome. You have your own choice to make on this. I have no control of that. It would however be good if you did not ask for free advice on very technical skills that have taken years to acquire and then complain about the help you received for free. If you want or don't want to know, I think you are the problem.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        a drop of good 0w20 syn oil in each pad every year should keep it going forever.
        thats what i do.
        maintenance does not bother me.and i have fans from the 20's in everyday use.
        when i clean the fridge i do it.
        • keeney123
          Lauren
          • Sep 2014
          • 2536
          thats what i do.
          syn oil definitely will improve it. The 20's fans were made to be oiled. I believe the new fans have bushings are made out of different material.
          • juergenb
            Nescafe Aeroccino, still fails with new Motor (red flashes only once)
            by juergenb
            i am asking for some Help.
            I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
            The Motor didn´t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
            So i got a few of these from Banggood.
            I swapped the motor and now i have a new fault condition.
            In a working Frother you would press the start button, it will light red and work for a few minutes.
            If you press longer it will light blue and just mixup the milk.
            With the new Motor it just starts...
            03-23-2021, 11:24 AM
          • sbt123
            charnwood w821 mini wood lathe motor problem
            by sbt123
            hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
            10-27-2024, 03:43 AM
          • d00m178
            Philips toothbrush 4100 (HX369BK) - motor getting hot
            by d00m178
            trying to fix Philips toothbrush 4100 (HX369BK)
            The battery started draining quickly.
            After disassembling it, I discovered that the motor gets very hot when brush is off, which is apparently causing the battery to lose charge.
            The motor is connected to contacts M1 and M2.
            When I turn on the brush, 0.4V appears on these contacts, and the motor starts running as expected.
            But when I turn off the brush, the voltage changes to 3.8V—exactly the same as the battery.
            The motor gets so hot you can't touch it. And after 5 minutes, the battery drains to 0V.
            (To...
            Yesterday, 03:11 PM
          • Lvsitano
            Asus X532FL 3.2V at source and gate
            by Lvsitano
            I am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
            First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
            I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
            First...
            06-26-2024, 02:13 PM
          • mikey5791
            Help identify this motor
            by mikey5791
            Hi all forum members,
            Found this unknown motor discarded in a junk yard and took home for learning experience. By the look of it, I suspect it is taken out from a type of air blower probably running on ac power. I used digital multimeter on ohm/resistance scale and it doesn't read anything on those 2 black wires. So, this motor is not shorted and should be good to run.
            Correct me if i am wrong on the initial test.
            Can anyone kindly advice on how to test run this motor based on visible external two black wires. Fyi, i don't see any marking on the motor body nor smell anything...
            11-24-2023, 07:54 PM
