Yiboyuan SS-3 universal charger
  • Gabriel
    • Jan 2010
    • 620
    • Norway
    Bought this from eForChina and as always I like to see whats inside. I'm going to try to make a board for it myself with charging management ic and just keep the housing.
    The back cover actually says 'forbid not to recharge the battery' hehe
    The white powersupply came with the charger, as you can see under the 'Made In China' sticker is a Samsung logo and it's 'Mode in P.R.C'
    The AC pins in just pressed in and hold firm by the plastic housing, they are not soldered to the board and I could pull them out.
  • Gabriel
    • Jan 2010
    • 620
    • Norway
    Re: Yiboyuan SS-3 universal charger
    Rest of the pictures, soldering looks quite bad.
      I would not say quite bad, it is really bad.
      • Gabriel
        • Jan 2010
        • 620
        • Norway
        Hehe yes, bad choice of words on my part.
        It looks like they used wave soldering with some parts manually placed and soldered.
        Does charger board sens + - by itself ? I see no polarity marking for pogo pins.
          • 31084
          what does ic1 say on it on the psu?
          i'm trying to source an SP6853 right now.
          • Gabriel
            • Jan 2010
            • 620
            • Norway
            It is marked '71d3b'
              • 31084
              not it.
              • Gabriel
                • Jan 2010
                • 620
                • Norway
                The Yiboyuan charger terminates charging at 4.266V - a little higher then expected.
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  just wound up with some of those from ebay.
                  sold as oem originals.seller was mayunstore.
                  funny they dont say samsung on them like the ones in the pics.probably to avoid customs confiscation LOL.
                  while the one you have has a cutout on the board for isolation most will fail hipot at 500v or less.2 blew up at 1 amp.rated 2a.
                  at 600ma it was out of usb specs.
                  total garbage!
                  • japlytic
                    • Oct 2005
                    • 2086
                    You might know this, but a number of things can include a bit of "engrish" in the price!
                    I think covering up the Samsung logo with a "Made in China" sticker is most likely a way to try to avoid detection by Customs as a counterfeit.
                    • motormayhem
                      Lenovo T460 Only Charges on One Charger
                      by motormayhem
                      Laptop Question
                      I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                      A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                      05-12-2023, 01:46 PM
                      NVDC charger configuration...
                      11-05-2024, 03:28 PM
                    • flat-earther
                      how to prevent a connected charger from draining battery when not charging?
                      by flat-earther
                      I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                      So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                      but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                      So the battery is backfeeding the charger and being drained.
                      How can I prevent...
                      08-07-2025, 01:04 PM
                    • flat-earther
                      ASUS X54H laptop thinks it's always charging even with charger unplugged
                      by flat-earther
                      The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                      Windows also shows ''Plugged in'' when charger is not connected.
                      This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                      Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                      If I let battery run out and say it has 3% Windows will...
                      06-24-2025, 09:32 AM
                    • Johndill
                      Dell Inspiron 7567 LA-D993P odd charger issue
                      by Johndill
                      Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                      There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                      I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                      Here are the tested scenarios:
                      1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                      2. With the laptop off, plug in charger (LED says on) & the front charging...
                      11-16-2022, 10:55 PM
