Need help identifying smd
+ More Options
Posts
  • caphair
    • Nov 2011
    • 1249
    Re: Need help identifying smd
    So the processor is the problem. Can't be corrected without replacing the processor?
      Or the processor detects fault or what ever the exact problem is so it shutdown that control line, I do not the details of how this unit is designed to function, that is why you did see the Voltage on the Collector of Q12 did the toggle LOW and HIGH due to activity of the processor output that feeds Q33 Base.
      • fzabkar
        • Mar 2009
        • 772
        Code:
                VCC   5V = power on
                +  0.22V = standby
          display |   |
            o----+ Q12 |
          5V = OFF \|  |
          0V = ON  |----+
               <|  |      hi = OFF
              |    \|  ___  lo = ON
              |  Q33 |--|___|---o
              |    <|     from micro
                GND
        KTC3875-GR / BR3DG3875M, KEC / Blue Rocket Electronics, NPN transistor, 60V 150mA, hfe = 200-400, marking HALG or ALG:
        https://cdn.badcaps-static.com/pdfs/...ef4b37225e.pdf
        https://cdn.badcaps-static.com/pdfs/...2ec8d6d3bf.pdf
        • caphair
          • Nov 2011
          • 1249
          So just for reference, how does a processor turn an LCD display on?
          Does it first send backlights signal then once that's on it turns LCD display on?
          Doesn't make sense why if it's on it stays on but soon as it's turned off it won't come back on unless you keep trying
          • fzabkar
            • Mar 2009
            • 772
            Can you give us the part numbers of the major ICs and the model number of the device?
            • caphair
              • Nov 2011
              • 1249
              #26
              I'll provide part numbers of major ICs when I'm home but it's an Absolute DD-3000ABT
              • fzabkar
                • Mar 2009
                • 772
                Is there a PDF manual for this thing?
                • caphair
                  • Nov 2011
                  • 1249
                  #28
                  I don't know I couldn't find one
                  • fzabkar
                    • Mar 2009
                    • 772
                    What about an FCC ID? Sometimes there are useful documents in the FCC database.
                    • caphair
                      • Nov 2011
                      • 1249
                      #30
                      Don't see an FCC ID unfortunately
                      • caphair
                        • Nov 2011
                        • 1249
                        #31
                        Where would the main processor most likely be located, the circuit board with DVD drive/psu or circuit behind the LCD assembly?
                        • caphair
                          • Nov 2011
                          • 1249
                          #32
                          Ok here's the area where Q12, Q33 are. There's another transistor Q60 that feeds 1.5v to base of Q33 through R193. It's base isn't connected to anything though, how does that work?
                          It's emitter connects to R154 which goes out to a pin that I traced to a chip right under the DVD drive. I'll post a pic of that next as my phone only allows one pic per post. I'm not sure if this is power for the DVD drive or linked to power on for the LCD?
                          • caphair
                            • Nov 2011
                            • 1249
                            #33
                            R154 connects to pin where I marked with a red line. There's no trace going to it on the board though?
                              The Base of Q60 is connected to R324, another end of R324 goes to the VIA to connect to what ever, the board may be more than 2-layer board.
                              • caphair
                                • Nov 2011
                                • 1249
                                #35
                                The end of R324 that connects to base of Q60 has 1.95v when the display doesn't turn on. The other end of R324 has 5v
                                When the display come on, base of Q60 drops to .70v 5v stays same on other end of R324. Is it normal to have that big a voltage drop across a resistor?
                                I wish I could figure out what's not switching every single time.
                                  You can esily find out if the Transistor are switching as it should or not by check the DCV between E and B, and E and C.
                                  if E and B changes state then E and C will also change state.
                                  You should look up on how Transistor operate.
                                  • caphair
                                    • Nov 2011
                                    • 1249
                                    #37
                                    Ok I have a question. When the display doesn't come up on Q60 there's 1.92v on the base and 1.25v on emitter and collector. When display comes on there's a difference of those voltages on the collector at .67v
                                    Does this show something wrong with that transistor or something else?
                                      'Q60 there's 1.92v on the base and 1.25v on emitter and collector'
                                      You need to check the Voltage between the E pin and B pin, and between E and C pin. What are they?
                                      • caphair
                                        • Nov 2011
                                        • 1249
                                        #39
                                        B and E .65v
                                        C and E 0v
                                          Originally posted by caphair
                                          B and E .65v
                                          C and E 0v
                                          As I explained before, as you can see, the E-B junction of the transistor is bias ON, so the Voltage between E and C will be close to 0V (Transistor is turned ON , saturated condition).
                                          https://learn.sparkfun.com/tutorials/transistors
                                          https://en.wikipedia.org/wiki/Bipola...sistor_biasing
                                          http://www.electronics-tutorials.ws/...r-biasing.html
                                            Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                                            by sam_sam_sam
                                            I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                                            I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                                            I tested the battery cells there are installed right now and they are testing good with no issues that I...
                                            02-04-2025, 08:08 PM
                                          • DynaxSC
                                            Extreme High Current & Low Voltage Short Killer ??
                                            by DynaxSC
                                            Hi Folks
                                            I'm looking for a extreme high current short killer solution for a reasonable cost.
                                            I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                            After taking off the socket, the shorts dissappear again.
                                            The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                            10-15-2024, 10:13 AM
                                          • harp
                                            high voltage high resistance marking resistor
                                            by harp
                                            Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
                                            08-26-2024, 01:42 PM
                                          • karatzdi
                                            Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                                            by karatzdi
                                            I know some might say... just buy another one. Sell it as parts..!
                                            So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                                            Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                                            Spent some time downloading the Service...
                                            06-11-2024, 08:38 AM
                                            AD7276, AD7277, AD7278, AD7274, AD7273​ Datasheet
                                            The AD7276, AD7277, AD7278, AD7274, AD7273 are 12-bit/10-bit/8-bit, high speed, low power, successive approximation analog-to-digital converters (ADCs), respectively. The parts operate from a single 2.35V to 3.6V power supply and feature throughput rates of up to 3 MSPS. The parts contain a low noise, wide bandwidth track-and-hold amplifier that can handle input frequencies in excess of 55 MHz.
                                            The conversion process and data acquisition are controlled using CS and the serial clock, allowing the devices to interface with microprocessors...
                                            10-07-2024, 05:32 AM
