FCC ID database - Error 522
  • fzabkar
    • Mar 2009
    • 772
    I'm getting the following types of errors whenever I try to retrieve any document from the FCC ID database.
    "Error 522 Ray ID: 27d9b8c19e0919aa
    2016-03-03 02:40:24 UTC
    Connection timed out"
    For example, I am unable to download the following datasheet:
    https://fccid.io/pdf.php?id=2777835
    Would anyone be able to download it for me? The problem appears to be in the connection between CloudFlare and the FCC, but I'm not certain. BTW I have contacted the webmaster at fcc.gov, but there has been no response as yet, nor do I expect one.
    Re: FCC ID database - Error 522
    Same error here too.
      You can search using this one: or you have already tried it?
      https://www.fcc.gov/general/fcc-id-search-page
      I put in Product code search box '27d9b8c19e0919aa' but nothing comes up.
      • fzabkar
        • Mar 2009
        • 772
        Thanks. The fccid.io URL turned up in a Google search. I followed your new URL and found the document.
        FCC ID = YCJGTIMW302
        https://apps.fcc.gov/oetcf/eas/repor...id=YCJGTIMW302
        https://apps.fcc.gov/eas/GetApplicat...tml?id=2777835
          My be that is why it shows 'Welcome to the new FCC.gov. Help us improve by providing feedback & reporting bugs.' and the *.io is no longer active.
          • fzabkar
            • Mar 2009
            • 772
            <sigh> The new search page is accessible via Firefox but inaccessible via Opera. I'm soooo damn sick of all this crap.
            • fzabkar
              • Mar 2009
              • 772
              Today the original URL (https://fccid.io/pdf.php?id=2777835) is working again. <confused>
              • RJARRRPCGP
                • Jul 2004
                • 6304
                Looks a lot like a proxy server error. (A proxy server that connects to another server to get the data)
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                  • 31281
                  it wont be worth a damn once TTIP get's signed anyway.
                  • Sus256
                    HISENSE 65E7KQ PRO - no boot
                    by Sus256
                    Hi all!
                    HISENSE 65E7KQ PRO
                    RSAG7.820.13512 - chassis
                    MT9618BAATAB - cpu
                    RSAG7.820.12059 - power
                    HD650Y3U77 - panel
                    KLM8G1GETF - emmc
                    Replaced emmc.
                    Terminal log
                    UART
                    AC_ON
                    E-B
                    FDE enabled
                    06-01-2025, 02:11 AM
                  • sushilachuthan
                    APC UPS error P13
                    by sushilachuthan
                    one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
                    the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
                    The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
                    We replaced the SCR with new device,, but the device is not power on as expected.
                    Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
                    09-26-2025, 09:00 AM
                  • Maalobs
                    Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
                    by Maalobs
                    I have a 2014 vintage Philips 60PFL8708S/12 that suddenly died in the middle of the kids watching a show.
                    The relevant service manual for the chassis is available here.
                    The TV no longer powers on, and leaving it powered on for a few minutes results in the layer-1 error with 2 blinks.
                    When I short the SDM to ground I get the layer-2 error code 53.
                    The inside of the TV has no damaged components and no swollen capacitors.
                    In SDM-mode when all the power rails are left on despite entering the protection mode, I tracked down and measured...
                    04-02-2019, 01:15 PM
                  • medinfo
                    Mac T2 after update(There was an error activating your device)
                    by medinfo
                    Macbook Pro 2019 T2
                    iCloud OFF
                    MDM unlocked by changing Serial Number
                    worked fine but after latest update see (There was an error activating your device. Please try again).
                    Erased and boot in internet recovery, same error.
                    changed to original serial number (iCloud OFF & MDM ON), same error.
                    tested with others serial number, same error.
                    tested (CMD+R), (Option+CMD+R), (Shift+Option+CMD+R), same error
                    Revived and restored by Apple Configurator and same error.
                    Any help ?
                    12-31-2023, 02:04 PM
                  • rmjimenez455@gmail.com
                    Sumsour station 8586D error H-E
                    by rmjimenez455@gmail.com
                    Hello everyone, next I have the following problem with the Sumsour 8586D 110v dual station I bought it a year ago and it worked wonderfully, now it presents the H-E error on the soldering iron side, the hot air side works correctly..... I disassembled the soldering iron head because the manual tells me that this error is due to ceramic resistance problems, in effect, I measured it and it is open, I bought a new one that is working verified in a soldering iron and nothing.... The same error continues, I proceeded to open the station and check visually, I found a totally damaged 1R00 surface mount...
                    09-07-2024, 09:33 AM
