Achtung! High Voltage!
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: Achtung! High Voltage!
    Originally posted by xelectech
    I once watched a spark jump about 3/4" from the flyback area of a crt into the tip of my thumb, then out the tip of my index finger 1/2" to the chassis - the higher the frequency (I think it was 15-something Khz) the closer to the bone the current travels, my hand felt a little weird for days afterwards.
    When I was 15-16 I had an inop TV set that I only kept in my room so I could draw an arc from the flyback to an insulated screwdriver for entertainment. I could draw an arc about 5/8" max. Never got bit by it but for a kid I was being damn careful.
      • 31017
      I agree with the last part, which accounts for how Nikola Tesla was able to hang out
      in his room with all that sparking going on - wonder what frequencys he was working with...
      Experiments with Alternate Currents of High Potential and High Frequency.pdf
      search for it!
      • xelectech
        retired tech
        • Nov 2014
        • 238
        As you probably know, the bigger the crt the higher the high voltage - the one I had was one of those big ole console models, I think maybe 25"...what better entertainment is there, and that ozone smell, so fresh so pure
          • 31017
          24-26Kv on those.
          • xelectech
            retired tech
            • Nov 2014
            • 238
            Originally posted by stj
            24-26Kv on those.
            Even a little higher on some, 30-32Kv, enough to generate x-rays, though that fact was never publicized.
              • 31017
              lead-glass on the face and shielding at the back mitigates that.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8151
                Got 3 strings of 600VDC from my solar panels that feed a 10kw inverter every day. I also worked on 3 phase systems and RF tube amplifiers up to 10kw (radio station). If you get zapped working on one of these, that's the last mistake you ever made. TVs, radios, Ham Radio gear, low voltage stuff I don't count anymore.
                • kaboom
                  "Oh, Grouchy!"
                  • Jan 2011
                  • 2507
                  @capleaker:
                  "One flash and you're ash."
                  "If it's not grounded, it's not dead."
                  "pokemon go... to hell!"
                  EOL it...
                  All style and no substance.
                  guilty,guilty,guilty,guilty!
                  guilty of being cheap-made!
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8151
                    I haven't heard those ones before
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      #30
                      No I try to always de-energize all circuits before I work on them*
                      Not the least because it's just as likely to damage the equipment itself otherwise when working on it!
                      *But I admit to sometimes not following my own rules
                      • SteveNielsen
                        Retired Tech
                        • Jun 2012
                        • 2327
                        I learned an awful about about safety in the Navy and for all the right reasons; survival of the person and the equipment. Plus it really pisses the Navy off when they have damaged or lost either, and there is no such thing as an unavoidable accident in the Navy. They can ALL be prevented somehow and usually by being careful. The only time a sailor is allowed lose control is on liberty call and that's why they have Shore Patrol out there with them.
                        • DynaxSC
                          Extreme High Current & Low Voltage Short Killer ??
                          by DynaxSC
                          Hi Folks
                          I'm looking for a extreme high current short killer solution for a reasonable cost.
                          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                          After taking off the socket, the shorts dissappear again.
                          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                          10-15-2024, 10:13 AM
                        • SoporteHR
                          LG 42PQ30R TV power supply does not work high voltage. (Liteon PS-7411-1-LF Rev. 2.1
                          by SoporteHR
                          Greetings to all, I hope you are well.
                          I consult you because I have a problem with this power source.
                          The TV when it is connected to the electrical power turns on the blue light but does not give an image. the source is heard a hum.
                          When I disconnect the power from the TV plates and power it up by itself, the hum goes away.
                          I have the STB voltages of 5vdc. The microcontroller is powered with said voltage and the main board LED lights up.
                          but not the 12v or 17v ones, nor the 300vdc high voltage voltages, nor the VS or VA....
                          06-20-2023, 04:30 AM
                        • harp
                          high voltage high resistance marking resistor
                          by harp
                          Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
                          08-26-2024, 01:42 PM
                        • conghuyms
                          MSI RX580 Vcore voltage is too high, please help me !!!
                          by conghuyms
                          I have an MSI Armor RX580 8GB V1.3 graphics card. Currently, all power rails are present, but the voltage supplied to the GPU Vcore, which should normally be around 0.9–1V, is measuring at 1.4–1.5V. The GPU gets very hot, and the MOSFETs supplying the Vcore phases are also extremely hot, with a noticeable whistling noise.
                          I’ve already replaced the UP9505P controller IC with a new one, but the issue remains the same.
                          Since the UP9505P is a new IC, could it require firmware programming like some high-end graphics cards such as the RX5700XT?
                          What should I do...
                          08-02-2025, 11:38 PM
                        • harp
                          Low voltage very high current rails distribution
                          by harp
                          Low voltage very high current rail distribution
                          I have some mains toroid transformer220v/12v, and thinking to add a few one-two turns fat coil in parallel, like in picture. Red are working windings, purple (top and bottom) is rails who connect all low voltage windings.
                          Question is, how to connect that device to be as much more efficient in spot welder operation to distribute and pulls currents to all winding equaly, minimalize voltage drop?
                          output on half E-F
                          output on C-B
                          connect A-B and C-D, output on A-F
                          otherwise?...
                          10-27-2023, 02:45 PM
