Achtung! High Voltage!
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Curiosity of people these days... High Voltage, does this faze you?
    Of course I'd rather work on the circuit dead instead of becoming dead from a mishap, I still work on CRTs even while they're powered up, etc.
    Poll is: Do you work on high voltage stuff?
    And yes I put my hand on a charged photo cap once... That felt... weird.
    25
    I work at a power substation!
    0%
    2
    CRTs? bring it on!
    0%
    10
    vacuum tubes, Offline SMPS 100+VDC
    0%
    1
    Live mains (100-240VAC)? Yeah!
    0%
    7
    Car batteries are my thing
    0%
    1
    Only low voltage
    0%
    2
    No, it must be dead before I work on it.
    0%
    2
    The poll is expired.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Achtung! High Voltage!
    I work on Tv's and other power devices with SMPS and other HVE been shocked by 240v quite a few times and by PFC buck voltage hurts yes and makes you go red in the face with fast heart beat lol ever since im extra careful
      • 31058
      it's a rush.
      btw, i'v been hit with about 14Kv
      it's totally different from being hit with 240v.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Bloody hell what did it feel like STJ ?
          • 31058
          nothing, it just throws you backwards and makes your arm tingle.
          the thing you crash into behind you - in this case a shelf is fucking painfull though!
          • rhomanski
            nowhere man
            • 5157
            • U S of A
            I have changed a circuit breaker with power on. Hold the screws with needle nose pliers and turn with your screw driver. Working behind a live breaker panel isn't fun but can be done if your careful. The feeder is the big problem, usually 10 gauge wire. Hard to move with needle nose and the screw.
            I was working on the central computer on a P-3 once. You had to lay on your side next to the power supply and turn two tiny resisters to adjust the voltage to 5 volts. I was running the meter while the other guy was laying down. While I was counting down the volts an arc shot out right beside his face and hit the rack behind him. I jumped up and pulled the breakers. We, uh, replaced that power supply. It left a big old black spot where it hit the rack.
            sigpicThe Sky Is Falling
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              I've been chucked by 240v. Both phases, a neutral and two grounds. (NatGas line and mains) It put me through the wall. Once i came to, the look on the occupants of the neighboring apartment that i ended up in was hilarious!
              That reminds me of a light fixture replacement i did a couple weeks ago. I was replacing 3 sets of dead floro fixtures with LED lights LIVE with 208v. It was a commercial building and to replace the lights with the power off would take killing the lights for another 5 Businesses. AKA Not happening. I was working under the guidance of a licenced electrician BTW.
              Follow the white rabbit.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Lol
                • japlytic
                  • Oct 2005
                  • 2086
                  I've been quite comfortable with high voltages for at least 15 years despite getting the rare shock or tingle - and I have a purpose-built EHT probe.
                  In 2003, I started working on valve/tube equipment (with my first valve radio) and became quite comfortable working with high voltage equipment.
                  Some time later, I bought a secondhand 1000VA isolation transformer, which helped me work more safely on "mains side" circuitry.
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Doesn't faze me much, then again I have a BS in EET and I know how to in most cases work with such safely.
                    sigpic
                    (Insert witty quote here)
                    • redwire
                      • Dec 2010
                      • 3910
                      During high school, I fixed CRT televisions and frequently had my arm in there to make measurements. I also liked frying stuff with car ignition coils. You learn pretty quick what not to do.
                      Recently I worked in substations 25kV-240kV and during switching operations, or rain/snow/fog... I got scared walking through the yard, corona is a bit unnerving.
                      Manually closing a disconnect with 72kV into a 10 mile long power line, there is so much line capacitance that the arcs are super loud until you gradually close the contacts.
                      That was the most scary HV work (utility industry) that I have done.
                      Funny thing is you must put ground chains on power lines when working on them. Mutual (capacitive) coupling from adjacent power lines is enough to charge up a de-energized line, enough to kill a person.
                      I was on a project where they energized a 240kV power line, but some idiot left the ground chains on. So switching into a short circuit! It almost took out the entire grid in the province. Massive overload until the protection relays tripped.
                      • ljintexas
                        LJinTexas
                        • Jan 2015
                        • 669
                        I have taken hits from 120, 240, 277 and had 480 blow up about 10 ft from me..never been hit with 14KV..WOW~!
                          • 31058
                          the 14k was DC, it's a lot safer because it throws you back.
                          AC can paralize you so you cant let go!!
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            lots of hv and lots of zaps from it.still repair crt's.those always seem to get me.but no big deal.i dont want a taste of my amplifier power supply.4800v@1.5a!
                            it powers a 3cx3000a7.
                            • SteveNielsen
                              Retired Tech
                              • Jun 2012
                              • 2327
                              I haven't been zapped that much or with that much but I've made sparks and blown out a couple of multimeters working on tube guitar amps output circuits. I've worked on live CRTs and thankfully haven't been bit by them. One memorable zap was working in a TV shop in the 70s and touching an RF test point in an old tube set. Left a nice little burn on my finger. Other than the odd ac mains zap I've been careful or lucky, probably both. I turn things off unless I have to work on live gear.
                              • xelectech
                                retired tech
                                • Nov 2014
                                • 238
                                I once watched a spark jump about 3/4" from the flyback area of a crt into the tip of my thumb, then out the tip of my index finger 1/2" to the chassis - the higher the frequency (I think it was 15-something Khz) the closer to the bone the current travels, my hand felt a little weird for days afterwards.
                                • Topcat
                                  The Boss Stooge
                                  • Oct 2003
                                  • 16956
                                  I've been bit by enough flybacks to not be fazed too much. also done some high current 3-pahse industrial install back in the day.
                                  <--- Badcaps.net Founder
                                  Badcaps.net Services:
                                  Motherboard Repair Services
                                  http://folding.stanford.edu/
                                  Team : 49813
                                  Join in!!
                                  Team Stats
                                  • xelectech
                                    retired tech
                                    • Nov 2014
                                    • 238
                                    I was once up on a ladder checking out a 3-phase breaker box and didn't have a tester with me. I saw another maintenance guy (the new guy) down on the floor and asked him if he had a test light with him, he said yes and tossed it up to me.
                                    It was a 480 volt 3phase supply-box so to make sure I asked him if the tester was good for all voltages and he said 'sure'. I put the leads across one phase and it blew up in my hand !! I said 'I thought you said it was good for all voltages', the guy goes 'well the guy at the auto parts store said it was'. Still kinda cracks me up when I think about it.
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      Can't say it fazes me. But fascinate? - Certainly.
                                      Got shocked several times, but none of them seriously.
                                      First one was with a TV PSU board. The APFC bulk cap had not discharged at all due to a fault in the PSU. I was a bit of a rookie back then, so I thought it did like with other PC PSUs and didn't check the voltage. It did cross my mind, though. As soon as I dragged my hand across the board (was checking some parts with a multimeter), I pulled my hand quickly. Felt like getting a bee sting.
                                      Second time was when repairing a PC PSU and was working on it with the cover off. Normally, I first plug in the power cable to the PC and then to the wall. But for some reason, I had the power cable plugged in the wall already. When I tried to plug the cable in the PSU, I was using one hand to hold the PSU plug on the exposed wire end - the exposed wires were all resting in the palm of my hand. Funny enough, I only felt a slight tingly sensation in my hand and nothing more. I guess my hand must have been very dry, since it was winter. Didn't realize what was happening until after I was done testing the PSU.
                                      3rd time: installing a 208V plug for a machine at the shop where I used to work at. Told my boss/owner of the shop not to touch any of the turned-off circuit breaks. And what did he do? Turn them on because he needed to use some plug somewhere. Not knowing that, I went to work on the plug. First stripped the neutral wire and bent it into shape to fit on the plug screw. Next, I stripped the live wire and did the same thing. No problem again. Finally, I grabbed both the L and N wires to bring them closer together so I could fit them on the plug and... OUCH! 208V going through my thumb and exiting my index finger. Luckily, it was all only on my right hand. The floor was concrete and the shop was ground-level too, but I had shoes on, so no problem.
                                      And most recently, I fixed a lamp for a family friend. Went to install back in her apartment, but we couldn't figure out which switch was for the light (there were 3 of them, and some of them were 3-way switches, so no telling which one is the ON and OFF position) and much less which breaker (15 breakers of "lights and plugs" isn't very helpful ). Normally, I bring my multimeter, but I had just forgotten it this time.
                                      So, what did I do? Drawing back from the 3rd experience above, I put my shoes on and wired the Live wire to the lamp before the ground and neutral. Why? Because the lamp fixture has a metal body. Had I wired the ground, that could have been bad news for my right hand again. So after wiring L, I test-connected the neutral on the light figure. Lights turned ON, so I *was* working on a live wire the whole time . Anyways, I went down and started playing with the mysterious switches on the wall until I turned off the light. Next, I used my right hand as the "test subject" and put one finger on ground whilst quickly touching the live wire with the other. No shocks, so no power. Wired everything, and that was that.
                                      Actually, the other way around.
                                      The skin effect states that electrons tend to travel closer and closer to the surface of the conductor as the frequency increases.
                                      In other words, if you make the frequency really high, you won't get shocked/zapped at all. Rather you will get a burning feeling in your skin, because... well, that's what's going to happen to it.
                                      • xelectech
                                        retired tech
                                        • Nov 2014
                                        • 238
                                        xelectech: same here 8^) - but I never worked on high voltage high current circuits
                                        and I'm pretty sure I don't want to, dangerous enough as it is...
                                        (snip)
                                        xelectech: I think the explanation is this; in a body, the bone marrow is a better conductor than the skin (unless you're all sweaty) and I guess there's some kind of capacitive coupling involved, the higher the freq., the more coupling, that allows the majoity of the current to follow the easier path. At least that's what I seem to remeber one of my electonics instructors saying, I could be wrong.
                                        I agree with the last part, which accounts for how Nikola Tesla was able to hang out
                                        in his room with all that sparking going on - wonder what frequencys he was working with...
                                        • DynaxSC
                                          Extreme High Current & Low Voltage Short Killer ??
                                          by DynaxSC
                                          Hi Folks
                                          I'm looking for a extreme high current short killer solution for a reasonable cost.
                                          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                          After taking off the socket, the shorts dissappear again.
                                          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                          10-15-2024, 10:13 AM
                                        • SoporteHR
                                          LG 42PQ30R TV power supply does not work high voltage. (Liteon PS-7411-1-LF Rev. 2.1
                                          by SoporteHR
                                          Greetings to all, I hope you are well.
                                          I consult you because I have a problem with this power source.
                                          The TV when it is connected to the electrical power turns on the blue light but does not give an image. the source is heard a hum.
                                          When I disconnect the power from the TV plates and power it up by itself, the hum goes away.
                                          I have the STB voltages of 5vdc. The microcontroller is powered with said voltage and the main board LED lights up.
                                          but not the 12v or 17v ones, nor the 300vdc high voltage voltages, nor the VS or VA....
                                          06-20-2023, 04:30 AM
                                        • harp
                                          high voltage high resistance marking resistor
                                          by harp
                                          Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
                                          08-26-2024, 01:42 PM
                                        • conghuyms
                                          MSI RX580 Vcore voltage is too high, please help me !!!
                                          by conghuyms
                                          I have an MSI Armor RX580 8GB V1.3 graphics card. Currently, all power rails are present, but the voltage supplied to the GPU Vcore, which should normally be around 0.9–1V, is measuring at 1.4–1.5V. The GPU gets very hot, and the MOSFETs supplying the Vcore phases are also extremely hot, with a noticeable whistling noise.
                                          I’ve already replaced the UP9505P controller IC with a new one, but the issue remains the same.
                                          Since the UP9505P is a new IC, could it require firmware programming like some high-end graphics cards such as the RX5700XT?
                                          What should I do...
                                          08-02-2025, 11:38 PM
                                        • harp
                                          Low voltage very high current rails distribution
                                          by harp
                                          Low voltage very high current rail distribution
                                          I have some mains toroid transformer220v/12v, and thinking to add a few one-two turns fat coil in parallel, like in picture. Red are working windings, purple (top and bottom) is rails who connect all low voltage windings.
                                          Question is, how to connect that device to be as much more efficient in spot welder operation to distribute and pulls currents to all winding equaly, minimalize voltage drop?
                                          output on half E-F
                                          output on C-B
                                          connect A-B and C-D, output on A-F
                                          otherwise?...
                                          10-27-2023, 02:45 PM
