Transistor Identification
  • pbr333
    • Jan 2014
    • 14
    • usa
    I'm trying to find a replacement for these 2 transistors. They are in a shift control module that belongs in my wife's SUV. The one labeled badtrans seems to be shorted (tested in circuit). If I can find a replacement I'll remove from circuit and test it to be sure. Any help would be appreciated.
    thanks, pbr333
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Transistor Identification
    Might have to reverse engineer from the circuit. What brand car?
    A lot of car manufacturers obscure component identification...
    • pbr333
      • Jan 2014
      • 14
      • usa
      chevy 2001 Tahoe. I believe this motor control circuit in where polarity to motor is switched to achieve transfer case gear change.
      • pbr333
        • Jan 2014
        • 14
        • usa
        I attached circuit diagram and pic of module.
          • 31015
          they are probably fets
          so pull the working one and stuff it in a component tester.
          • fzabkar
            • Mar 2009
            • 772
            D412 is the circuit reference for a diode. The part looks like a dual diode that connects between each motor terminal and the positive supply.
            The relays do the switching, not the semis.
            The pinout for the relays is in the following datasheet:
            https://cdn.badcaps-static.com/pdfs/...856b3dfc11.pdf
            • Techie_hobby1
              Help please with identification of few components for troubleshooting (Solar Water Fountain circuit)
              by Techie_hobby1
              Need some help please with a few components on this small board so that I can troubleshoot the circuit.
              The PCB is a Single sided board fairly simple circuitry has a +ve and -ve Solar cell power input, a 7.4v 1500mAh (dual 18630 cell) power in which the Solar panel charges the cells, and lastly the Output goes to a DC connector...
              J1 is actually 1P1T Switch (in ON position completes Battery cell circuit
              J2 - to DC Output
              J3 is Battery cell connector
              however I am struggling to identify if:
              Y1 (SOT-23) are NPN Transistors, MOSFET's or 11v Zener's....
              07-24-2025, 12:43 PM
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • Haaheim
              Bias matching replacement transistor - Parasound 2250
              by Haaheim
              Hi guys!
              I am currently working on a Parasound 2250 (class AB), which had one defective channel. Components in the signal paths have been replaced, including an output transistor (2SC3519).
              According to the manufacturer, bias is adjusted by measuring 1-3mV across the output resistors. The original ones are completely fine around 1.5mV, but the replacement is not. Initially, I got a couple from eBay, assumed they were fake (they were) and was able to source a replacement locally. This exhibits similar behaviour, being around 0.6-0.8mV on its emitter resistor....
              05-13-2022, 12:45 PM
            • nobbnobb1
              Bose Acoustimass 10 IV Subwoofer No Sound. Help with burnt component identification?
              by nobbnobb1
              I picked up this used Bose Acoustimass 10 IV speaker system. Speakers seem to work fine, but the subwoofer does not make any noise. So I took apart the unit and found some obviously failed (burnt) components:
              - 1x 3.14 A @ 250V main circuit fuse
              - 1x bridge rectifier GBU601. there's actually two of these on the board, one is obviously burnt and the other does not seem to have any anomalies like shorts. However I figure may as well replace both.
              - 2x diode. This is tricky because the only markings I see on it are: "617 402". No current rating or anything else....
              11-16-2024, 09:56 PM
            • Alimash
              op amp circuit function?
              by Alimash
              I am repairing a ups which doesn't turn on ,it has the following ICs:
              SG3525 used to drive inverter mosfets.
              couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
              A LM358 and TL074 for control mechanism and of course the uController.
              The SG3525 is shutting down every time the ups is turned on.
              I want your help to know the function of LM358 and TL074 in the system.
              I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
              Yesterday, 07:45 AM
