APC 1500VA upgrade to external battery - any issues?
+ More Options
Posts
  • shiftline
    • Dec 2015
    Hi guys,
    I have an older APC 1500VA UPS like the one pictured below. right now it has the dual 7AH sealed led acid batteries.. and i'm using it as a backup on an aquarium.
    I Also happen to have a beast of a 147aH sealed led acid UPS battery (UPS12-540mr) laying around unused.. Could i wire the little UPS to the terminals to this giant battery?
    Now would the charge circuit have any issues going form 14ah to 147ah? or will just just take ages to charge? (which is okay).
    I dont foresee my self having a very high load off the UPS.. i more just want it to have a very long run time for some water pumps. I can wire some of them directly to the battery and the 24V ones through the UPS.
    Cheers!
    Deven
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: APC 1500VA upgrade to external battery - any issues?
    it wont have too much trouble charging... It's the long runtime part. Lots of modern UPSes have a very limited runtime. They could cook if they run to long. If you want to do this, i recommend an older, all metal unit. They are less built down and have better cooling.
    Follow the white rabbit.
    • shiftline
      • Dec 2015
      Thanks for the tip.. Ill see if i can find one.. alternative maybe i can upgrade the internal heatsinks/fans
      Runtime would likely be long but the load shouldnt be too high
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • mkdj
        by mkdj
        Mark and model: ASUS X571
        Tests already made:
        - I have removed...
        07-14-2025, 09:16 AM
      • techfreak9356
        Vostro 3400 (LA-K033P) won't charge battery, everything else ok
        by techfreak9356
        09-14-2023, 11:10 PM
      • DaLZy
        Extremely Strange Issues with charging and battery on Zephyrus G14(GA401)
        by DaLZy
        I have recently come into possession of a G14 that cannot detect or charge it's battery. Initially both windows and the bios agreed that the battery was on "0%" but the laptop was able to run without AC power. I was able to get the laptop to detect the true charge of the battery(26%) in windows for a moment but it wouldn't charge or update the percentage when the battery drained. I attempted a few more EC resets and battery reconnections and now the battery shows at 0% in bios and 100% in windows. Additionally the machine is extremely laggy when plugged into AC. When on ac power in the...
        01-27-2025, 12:38 AM
        NVDC charger configuration...
        11-05-2024, 03:28 PM
