Need Help Understanding TRIAC In AC Circuit
  • LENOVO-A880
    Not A Bad BIOS
    • Feb 2014
    • 79
    • MALAYSIA
    This is one of the electronic course project which I'm currently doing so first I'll tell you what I think I have learned but not really helpful and then I'll ask a few questions.
    --A TRIAC is an AC device when voltage is applied to the gate, it allows AC to pass through it.
    Own Understanding Of How TRIAC Works In AC Voltage Circuit
    "Don't be afraid to insult me--if I have this wrong. Please just spell it out to me as I'm still learning a bit more"
    1. Situation-A: When the switch on the Primary Side of the step-down rectifier transformer is pushed, current flows through the 1A fuse via the 10K OHM voltage divider. This allows current to apply to the gate. It will conduct both the (+) and (-) half-cycles of AC. And result can be pulses of energy at a rate of 100 times per sec if the line frequency is 50Hz (230V). Forward current start to bias toward the bulb (40W) when junction 3 and 1 is connected on this high speed cycle phase. Then current will flow through the TRIAC and the bulb illuminates.
    2. Situation-B: If the wire between junction 3 and 1 removed, voltage will not be converted through the 10K OHM resistor. The pulses of AC can't be given to the gate. So current will not flow through TRIAC and the bulb will remain dim..
    3. Situation-C: Refer to QUESTION 3...but before that do i get those 2 answers to the situations above correctly...please correct me if I'm wrong
    QUESTIONS
    1. Does simply removing the gate current (3,1) latching of the junction connector sufficiently turn OFF the TRIAC? Why?
    2. Does varying the gate voltage limit in some way how much AC is passed through the TRIAC? And once a device is triggered, the gate voltage doesn't affect the current that flow through the device. Why?
    3. How do I switch the 40W bulb to be triggered by the TRIAC so it will always illuminate?
    "If you cannot do great things, do small things in a great way."
    -Napoleon Hill
    "The chip that functions abnormally will be desoldered, as they say."
    -Charles Stross
    "Why is it you're always too small or too tall?"
    -The Mad Hatter
    • 31142
    Re: Need Help Understanding TRIAC In AC Circuit
    a triac is a pair of scr's in parallel,
    and it's either on or off - there is no variability.
      http://pcbheaven.com/wikipages/The_Triac/
      http://www.ttiinc.com/object/fp_litt...hyristors.html
      Once the TRIAC is trigger on it will stay on until the Zero cross of the AC sine wave is reached (current drops to ZERO) TRIAC also requires minimum holding current for it to stay conductive.
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        Here is a good instructional definition on How a Triac works.
        http://www.electronics-tutorials.ws/power/triac.html
        • Longbow
          • Jun 2011
          • 623
          Incorrect. When a pulse appears on the gate, the triac will conduct in one direction only. It will turn off (block current) when the polarity of the applied voltage reverses. A new gate pulse is required to turn the triac on in the opposite direction. Thus, a string of firing pulses must be present at the gate in order to allow AC to "pass" through the triac.
          Not always. The triac needs a finite amount of time to turn off and may latch in the "on" state if the applied C-A voltage does not allow for the minimum commutation time (turn off time).
          no
          because the triac is a latching switch - physical mechanisms of the 4 layer latching switch appear in every engineering book.
          A string of turn-on pulses must be supplied to the gate. In simple circuits, the pulse is derived directly from the applied AC using a simple RC gate firing circuit.
          Is it plugged in?
          • прямо
            TRIAC circuit
            by прямо
            Anyone is familiar with a TRIAC circuit?
            I came across this schematic, and I built it, but I can't seem to figure it out why I'm getting a low AC voltage output at the TRIAC terminals.
            With 230V AC hot side at the TRIAC MT2, I measured 60V AC between MT1 and neutral side when the comparator output LED indicator is on, and 20V AC when it is off.
            Same result if 230V AC hot side is at MT1, and I measured between MT2 and neutral side.
            My heating element doesn't work with 60V AC. It's not even getting hot and the thermocouple amplifier output is a...
            04-27-2024, 02:12 AM
          • repair-it
            TOSHIBA DLP 52HM95 How to reset timer module on bulb
            by repair-it
            I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
            Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
            10-11-2023, 07:18 PM
          • ezenia
            LUMIMAN Smart Bulb IC ID?
            by ezenia
            I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
            In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
            04-28-2025, 05:56 PM
          • nicktasios
            Macintosh Quadra 840AV PSU
            by nicktasios
            I had my Quadra 840AV (which I recapped and had working) plugged in for some time without using it and randomly decided to turn it on today. Unfortunately it did not turn on. After checking the PSU, I found out I was not getting anything from 12V, only from the 5V rail. After a few minutes, I removed the PSU and plugged it back in the electrical outlet and it suddenly started making a weird sound and soon after smoke started coming out. I quickly unplugged it. I opened it up but on first instance I didn't see anything out of the ordinary really. I later turned it back on and one of the MOVs blew...
            12-22-2024, 05:07 AM
          • Astonished
            Fixing the Charge Circuit of the Batteries of the DC Motor
            by Astonished
            Hi friends of electronics
            What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
            The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
            Please help me fix this circuit.
            (the datasheet of the IC: https://pdf.datasheet.live/28...
            01-28-2025, 06:24 AM
