Vizio 60" smart tv.
  • Brinn
    • Oct 2015
    • 21
    Vizio 60" smart tv.
    Hello I have a 60" smart TV that lost the picture, the sound was still working but now since I unplugged everything. I don't get sound.. but I will say that the sound is intact. The serial number is E601i-A3. This tv was bought in 2012 from Walmart and I called vizio and I was told it was a backlight issue.. Clearly the person I talked to had no idea as I kept telling him the tv turn on but I get a black/dark blue screen and that's an indication of the backlights working.
    This bring me to my actual question. Do you guys think it's a T-Con board or a main board problem? I don not wish to replace both when one might be good or the other way around. Or has anyone else seen this issue and had a different part not working correctly?
    THank you!
  • budwich
    • Jul 2015
    • 3097
    Re: Vizio 60" smart tv.
    Guessing at the problem with out taking off the back and checking things is probably not good. Having said that, if you go to the "tv troubleshooting" portion of the forum, I think you will find some similar problems with this type of set. Odds are good its a tcon problem BUT it could be that the tcon was taking out by a bad panel... again read thru some of those associated posts.
    • Brinn
      • Oct 2015
      • 21
      Thank you for the reply. I searched for something similar and there's no specific solution to my question. I have however replied to the thread that had a similar problem as my tv to see what their solution was or what they think about my best possible choice is. Thank you again.
      • diif
        • Feb 2014
        • 6978
        • England
        Whilst certain models and makes seem to suffer from similar failures going on past history can not replace having a physical look at the boards and measuring with a digital meter.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • ChaosLegionnaire
          by ChaosLegionnaire
          09-13-2022, 09:02 AM
        • iglitare
          Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
          by iglitare
          i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
          Backlight seems to work, Sound (Setup menu after reset) works.
          If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
          Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
          With my small knowledge i would think at least the cables are good.
          Can this happen because of a bad tcon board?
          Or is it always a bad/shorted...
          09-04-2025, 07:13 AM
        • Fly_Among_Stars
          VIZIO E70-E3 Half picture with half TCON
          by Fly_Among_Stars
          I have a VIZIO E70-E3.
          Symptoms: Black screen, no picture, but LED backlights are working.
          I probed the power board and voltages are as listed on the board.
          Main board appears fine, too.
          I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
          There are two separate ribbon cables feeding the LCD.
          If both are connected, the screen is black.
          If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
          04-24-2023, 08:20 PM
        • ggil44
          Vizio M65-E0 No Picture, No Sound
          by ggil44
          Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
          09-03-2024, 08:30 PM
