Re: What is a mechanical solder sucker?
Send us a photo of tip and the braid. applying the flux to the braid should be enough. A small amount of solder on the tip will help to wet the wick.
I bought a flux pen but do I apply the flux to the solder to be wicked up or to the wick itself? I tried both but they dont seem to workLeave a comment:
I use a K type tip. Extra flux helps a lot.Leave a comment:
Use solder wick. See post #25.Leave a comment:
So I turned down the temp to 572 but it wasn't melting the solder on the board so I turned it up to 662 and now it seems ok. How do you pickup solder on the board when there is not enough to be picked up by a solder sucker?Leave a comment:
it works just fine in the stand - that's why it's there.
infact i only use wool - none of that wet sponge shit.Leave a comment:
That's true, lol. So I just rub the tip in the wool, or do you think I'll need to remove the wool from the stand and give the tip a good brushing in the wool by squeezing the wool with one hand and turning the iron with the other?Last edited by johnnyh55; 10-28-2015, 09:07 AM.Leave a comment:
888D has wire-wool in the iron-standLeave a comment:
Also every solder tutorial I look at show a component pad on the PCB that is easily noticeable, is it normal that I don't really see a pad on the motherboard, I guess it's there but really small?Leave a comment:
no, you didnt damage anything.
your tip needs a clean using some wire wool probably, then put some solder on it at a REASONABLE temperature.
what iron is it?Leave a comment:
That means, I did damage something? Or I would see it, if I would of damaged something?
So is my tip no good anymore? Should I buy another one, or it's still good, I just need to re-tin and it should be ok?Leave a comment:
damage would be obvious.
but i bet your tip was black and the solder didnt stick very well!!!
you oxidised it with too much heat!
i dont know who wrote 450' because they didnt put their name down ( i wonder why!)
the solder is 60/40 with rosin-based flux - so looking at "real" brands for data.
http://www.rapidonline.com/Tools-Equ...der-Wire-30236
http://www.rapidonline.com/Tools-Equ...er-60-40-30459
so there's your temps.
braid has powdered flux in it and should just work - but most wont work on big lead-free stuff.Leave a comment:
that's an insane temperature now i converted it to 'c
455'c!! you shouldnt be over 350 (662'F)
if you ignore this, you burn the flux.
infact that temp is for lead free solder, if your using 60/40 you may need to go under 300 (572) because the flux is usually different
conversion done here btw. (incase it's wrong!)
http://www.onlineconversion.com/temperature.htm
show us the solder label btw.
https://www.badcaps.net/index.php?pageid=cap_removal
I kind of figure it was too high. So if I lower the temp it should be easier to solder? Maybe I was burning all the flux off way too fast. I have attached a picture of the solder I am using.
Also, desoldering braid should be fluxed right? To help bring the solder in the braid? Because the one I bought isn't flux I think, and when I add solder to the braid it helps wicking the solder on the board. Maybe ill buy the MG Chemicals solder wick and try that instead.
Now by having the iron temperature too hot, do you think I damaged anything?Last edited by johnnyh55; 10-28-2015, 06:50 AM.Leave a comment:
show us the solder label btw.Last edited by stj; 10-28-2015, 06:24 AM.Leave a comment:
Well there is something I am doing wrong, either too much heat(852F) or solder too thick(1.2mm)? When I apply the iron to a solder joint, it doesn't transfer heat to the solder it seems, I always have to add a little fresh solder. There is something I must be doing wrong every youtube video I checked they just touch the capacitor leads and the solder melts after 1 second.
I also notice when I apply heat to the pad and the lead, the heat never seem to transfer to the other side where I apply solder. I always need to apply a little bit of solder to the tip while touching the pad and lead and then it begins to melt on the other side.Last edited by johnnyh55; 10-28-2015, 05:29 AM.Leave a comment:
i also recall another fellow member saying that he uses a paper clip to clear the hole. cant remember his user name tho.
a good joint should look conical, bright and shiny like the ones on the left of the picture. it looks like u put too much solder on the center one. if u got a circular solder blob instead of a conical one, u have to desolder the cap, clear the hole again and try again. or if u are lazy, just try to use the sucker to remove some of the excess solder.Leave a comment:
No. Put enough solder on the soldering tip to make contact with the hole and the pin for heat transfer, as the pin and hole heat up and solder starts to soften turn and push the pin into the hole. Don't wiggle it sideways or the tip of the pin can poke into the metal lining the hole or catch on the side of a solder pad and tear it off. Be patient.Leave a comment:
No. Put enough solder on the soldering tip to make contact with the hole and the pin for heat transfer, as the pin and hole heat up and solder starts to soften turn and push the pin into the hole. Don't wiggle it sideways or the tip of the pin can poke into the metal lining the hole or catch on the side of a solder pad and tear it off. Be patient.Last edited by SteveNielsen; 10-27-2015, 09:29 AM.Leave a comment:
by corrizeHello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
See the test :
https://youtu.be/bNAzC-EvqHs?t=1767
With hot air from bellow the board, that's... -
by myth77Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
Is there any solder mask... -
by flat-eartherI have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries.... -
by petemanukSo I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder... -
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... - Loading...
