Re: What is a mechanical solder sucker?
Well I got all the capacitors in, not sure if I should power up the board, i'm not confident in skills. Do you guys think it looks ok or some things might be shorted once power is applied?
If anyone could help me choose some 680uf 4v capacitors below:
http://www.digikey.ca/product-search...=0&pageSize=25
I don't know exactly what ESR value to look for but I would like the capacitors to be close to 8mmx8mm although there is not much choice in those dimensions. I would need the width to be as close to 8mm as possible so they don't touch each other side by side.Leave a comment:
Actually I guess it's a poly since it doesn't have the vents on top. So my question is can I replace this capacitor with a sleeveless capacitor? It basically looks like an all metal cap but it has the same values.Last edited by johnnyh55; 11-04-2015, 08:47 AM.Leave a comment:
I've used the spring loaded ones for years and never damaged a board. I used to really hate them, but then I discovered that a bit of silicon grease injected into the tip prevents the solder from sticking and makes them work pretty good.Leave a comment:
from what i can res 680uf 4volts 105c TMJ and on the top its written 67 c7Leave a comment:
what is the original cap details?Leave a comment:
yes, if you select it carefully.Leave a comment:
Well according to post #4 in this thread, it's perfectly fine to replace the aluminum electrolytic caps with solid polymer ones:
https://www.badcaps.net/forum/showpo...40&postcount=4
Is that true?Leave a comment:
Actually it's the other way around. Right now I have aluminum electrolytic and I'd like to replace them with aluminum polymer capacitors, would that be ok? I can't find 680uf 4v caps in aluminum electrolytic only in aluminum polymer. I can find 680uf in higher voltage like the ones I have now but the dimensions are usually too big and I don't think they would fit.Last edited by johnnyh55; 11-03-2015, 11:13 AM.Leave a comment:
I would not replace polys with aluminum electrolytics. They have some different properties and the designers of the board decided to use polys for a reason, otherwise they'd have gone with less expensive aluminum caps.Leave a comment:
no
polyester caps arent polarised, electrolytics are.
unless you mean polymerLeave a comment:
Now that I think of it I think these caps will be in the way of the heatsink so I will order some new ones 8mmx8mm. If I replace polyester caps with aluminum caps would that be ok? The only ones that would work from digikey are aluminum caps 680uf 6.3v and they are 8x8mm.Leave a comment:
Well thanks for all your help, I figured out a technique where I apply flux to the solder on top of the vias to be clean and then I align my safety pin and I apply heat with the iron. The the pin goes through almost like butter and I then wiggle it and pull it out and it clears the hole.
Now some of my caps are the right capacitance but too big physically for the ones they are replacing(1800uf 35v instead of 6.3v) or they hit each other side by side, if they don't touch the board does it matter if they don't interfere with other components on the board?
Oh by the way, nothing is soldered yet.
Here is a pick belowLast edited by johnnyh55; 11-02-2015, 05:15 PM.Leave a comment:
soldering a pcb, you can use any flux, but if it's too agressive you need to clean up the mess after.
where flux becomes important is if you need to solder brass, aluminum or something "dirty"
then the different chemical formula's make all the difference.Leave a comment:
Lead free solder is stronger but requires higher temperatures. How well it bonds in a solder joint depends on your soldering skills. You still have to be mindful of temperature and timing or you'll get a crappy joint or damage the board with either. For a beginner the higher heat requirement may pose a greater threat of overheating the work.Leave a comment:
Do you think it will bond better or probably not?Leave a comment:
you can use leadfree solder just fine with a programable temp iron like yours.
it's only a probem for people with $10 irons!
i use 0.7mm myself.
if you want to buy some solder, let use select it for you so it has good flux in it.Last edited by stj; 11-02-2015, 11:01 AM.Leave a comment:
by corrizeHello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
See the test :
https://youtu.be/bNAzC-EvqHs?t=1767
With hot air from bellow the board, that's... -
by myth77Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
Is there any solder mask... -
by flat-eartherI have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries.... -
by petemanukSo I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder... -
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... - Loading...
