Anything here worth salavaging?
  • mikay786
    • Aug 2014
    • 765
    So I'm about to dump this Sanyo DSR-3709 video recorder which isn't worth much and is probably faulty. I only paid a couple of quid for it and only for the 2 x hard drives in it.
    Anyhow was wondering if anything in it is worth salvaging aside from the hard drives. Looks to have some decent caps in it especially in the power supply side?
    Rubycon ZL caps and a large cap, theres some switches / leds etc. Worth pulling out?
    • 31281
    Re: Anything here worth salavaging?
    keep the rotary encoder and buttons.
    keep all of it infact.
    stuff i would keep is the entire psu, the buttons, the rotary encoder, any ram,flash,eeproms or cpu's
    and any surface-mount tantalum caps.
    specially the tantalum caps.
    • mikay786
      • Aug 2014
      • 765
      Which ones are tantalum caps?
      I was thinking just the psu and the two brown boards.
        • 31281
        tantalum are rectangular and black or yellow.
        • retiredcaps
          • Apr 2010
          • 9271
          Since the power supply is small, I suggest keeping it intact. It is good to learn how a SMPS works and you can easily make measurements for learning purposes.
          --- begin sig file ---
          --- end sig file ---
          • federalhouse
            **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
            by federalhouse
            I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
            **Background:**
            I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
            **What I've Tried So Far:**
            1. I accessed
            08-01-2024, 07:03 PM
          • ash91
            Hp pavilion 15 not detect hard drive
            by ash91
            Hello gentelmen .... this is my first post and sorry for my bad english,
            so my proplem is my laptop keep losing hard drive even if i but the
            hard disk in the cady (the box that can replace the dvd rom with hard disk)
            when i turn the laptop on the massage that said no boot media found pop on
            the hard disk is fine and to be sure i try another hard
            i also update my bios to the last update
            the 5 volt is present on the hard connector on the motherboard
            the dvd rom work fine when i but a windows dvd in it
            also when i boot from flash...
            06-07-2023, 01:45 PM
          • madura2010
            DAY11AM6E0 hard disk drive and optical disk drive not detected
            by madura2010
            Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
            i checked the connectivity of ribbon=good communication with hard and motherboard
            changed hard disk and checked=3f0 error persist
            sata power=+5v available
            Then checked data capacitors=all good
            Then checked data lines path connectivity to pch=all good
            reflashed...
            03-12-2023, 09:09 AM
          • odie34
            Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
            by odie34
            I am a hobbyist (not a professional) so please be gentle...
            I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
            I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
            02-18-2024, 09:11 AM
          • mkdj
            Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
            by mkdj
            Dear all,
            I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
            Here the steps I have taken to fix the laptop:
            - downloaded latest BIOS from Lenovo Website...
            10-18-2025, 03:43 AM
