Identify Crimp Terminal
  • jedwar10
    • Aug 2009
    • 43
    I'm trying to identify the crimp-on terminal connector used on this wire so I can replace it with a new wire. It is out of a wiring harness connecting my 06 Chevy Equinox door electronics to the car chassis. ie: power door locks, Speakers, power windows etc...
    I would appreciate any input I can get. I've been searching though my newark catalog and on digikey.com but it's tough without any markings on it other than U3.
    Any help would be greatly appreciated.
    Thanks,
    Jason
    P.S. If this is in the wrong section of the forum I apologize.
    • 31046
    Re: Identify Crimp Terminal
    looks a bit familiar - show the plastic shell.
    • jedwar10
      • Aug 2009
      • 43
      A few pics of the plastic casing it snaps into as well as the reverse of the plug. Hopefully these help. Also a shot of the female side that it snaps into.
      At this point I'm leaning toward some sort of Delphi brand connector. I've found a few that are similar but not an exact match.
      I appreciate the assistance with this. A new harness is about $200.00. If I can find the right parts it should cost less than $10 to fix it myself.
      • rhomanski
        nowhere man
        • 5157
        • U S of A
        Why not search digikey for an environmental splice and reuse that pin? I would probably contact the dealer first. After that perhaps Napa or some such. Also try a couple body shops and stereo installation shops. Digikey, Mouser and the like probably won't stock it. GM used to use weatherpack pins for almost everything in the 80's.
        sigpicThe Sky Is Falling
          • 31046
          i'm surprised there is nothing written on that - not even a batch number!
          complex bastard, probably Tyco, otherwise could be from Molex or Amphenol (AMP)
          • jedwar10
            • Aug 2009
            • 43
            Didn't know about the environmental splices. That's certainly a possibility.
            At this point I'm also considering exposing the wire near the connector and soldering an extension directly to the connector since it has a little play room in the plastic housing.
            Thanks to everyone for the suggestions.
            • SteveNielsen
              Retired Tech
              • 2327
              I have opened up the crimps on the pin and crimped it back onto a new wire and soldered it as well. I don't think a solder joint alone is strong enough for this application.
                • 31046
                lead free solder is strong.
                • SteveNielsen
                  Retired Tech
                  • 2327
                  True, lead free is much stronger.
                  • jedwar10
                    • Aug 2009
                    • 43
                    I'm going to try and open one of them and re-crimp a new flexible wire in. Plus add a bit of solder where the strands touch the connector.
                    I'll probably get time for that over the weekend.
                      Lift Master garage door opener with WiFi capability application through your phone
                      by sam_sam_sam
                      I had a lot of trouble with the WiFi connection from my router inside of the house into a ( new ) metal garage I had to run a 150 ft cat6 patch cord so the WIFI connection would be strong enough for the WiFi connection on the garage door opener would work correctly ( my son has a work out area in the garage as well and he was having to put his phone near the door to be able to stream music ) ( so I was going to eventually put WiFi out there anyway )
                      This garage door opener WiFi is very touchy if you lose the power it does not remember the password for the router which is weird or...
                      01-21-2023, 08:31 PM
                      Linear Garage Door Opener Control board took a crap install a new control board back normal
                      by sam_sam_sam
                      I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
                      02-08-2025, 06:52 AM
                    • thesame
                      DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                      by thesame
                      Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                      The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                      02-27-2024, 04:31 AM
                    • silver60618
                      Lenovo Legion 7 - Help Identify IC
                      by silver60618
                      Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
                      I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
                      Any help would be appreciated...
                      07-02-2025, 12:16 PM
                    • chth96
                      How can I identify varistor which have been blew up?
                      by chth96
                      I mistakely pluged 100v japanese retro game console to 220v outlet.
                      So It seems that glass fuse and varistor have been blew up.
                      I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                      Is there any way to identify varistor type in my sega saturn PSU?
                      Any reply would be appreciated.
                      EDIT:
                      It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                      11-26-2023, 08:52 AM
