I had a ceiling fan that I replaced the pull cord switch (zing ear) because the chain broke inside of it, after that it never sped up properly and ran at maybe 1/3 the proper speed at best, so I assumed I wired the switch wrong, but I later either bought a new one or confirmed it (I have 2 identical fans in separate rooms). and everything is hooked up right inside the fan (capacitor, direction switch, pull switch, no light kit)
Eventually we redid the room and all the outlets and the handyperson stupidly installed a regular lights dimmer instead of a notched distinct speed fan dimmer, it totally stopped functioning (button wouldn't click when depressed) a few weeks later. I already knew only a fool puts a light dimmer on a fan, so I bought a proper fan dimmer and installed it. The fan operated fine for a few minutes, but then I pulled the speed control cord on the fan and immediately heard the dimmer pop, and the fan stopped receiving power.
I took everything apart reconfirmed it was all wired right. Then decided to take the whole fan off the ceiling to clean it / inspect it further. Well it appears the ground to the case is snapped (hidden by the decorative molding). Does it seem reasonable that just the ground being snapped ever since I changed the pull switch is causing the speed issues and fried the proper dimmer? (I probably shook the unit a bunch in weird ways when I changed the pull switch, or years of fan vibration snapped the copper wire for ground).
To make matters more confusing my house often has about 50v between ground and neutral , (60v between hot and ground), so perhaps the ground just made temporary contact with the fan body where it was snapped when I pulled the pull cord...
