APC ES 650 circa 2004
  • WeaselXP
    • Oct 2015
    • 107
    I got to thinkin' that there had to be some old 'lytics in this unit, and even though it hasn't given me any trouble, I opened it up. Found a CapXon 10uf 400v, 2 Jamicons one that was 330uf 25v and a 47uf 63v. That ain't gonna work for me. Replaced the 10uf with a Rubycon BXC series and the 330uf with a Rubycon ZLS. The 47uf I used a Nichicon BW series I had. May not have accomplished much, but I feel better about it.
  • WeaselXP
    • Oct 2015
    • 107
    Re: APC ES 650 circa 2004
    More pictures.
    • Alfieh
      NAD C320BEE repair possibly bad capacitors
      by Alfieh
      hey Im very new to repairing electronics with capacitors as well as using a multimeter so I need so help/guidance fixing this issue
      recently I was handed a family members old NAD C320BEE that they had in their loft for storage for a few years but when powered on it went into power safety mode due to a problem on the protection circuit somewhere before it went into storage I was told it worked fine I found lots of people online talking about how the capasitors are known to be pretty bad in this model and can cause this issue the only problem being I don't have much experience sorting...
      11-19-2024, 04:55 PM
    • yuzupatogik
      Help with replacing Capacitors on Altec Lansing ATP 3
      by yuzupatogik
      I have this old (2004?) Altec Lansing ATP3 and i would like to replace the capacitors. I have identified 34 out of the 36 of them as Samxon GR of various capacities and voltages.
      I can't find datasheets for the Samxon in any of the following variants:
      10000uF 25 v - this one i really want to replace because i suspect it is what causes a dull hum regardless of the volume knob position or if the source is plugged in. I am eyeballing the Rubycon 25PK10000MEFCGC18X35.5 for this purpose. So if i pay a 10x the price part for shipping i might as well go ahead and...
      02-14-2025, 04:11 PM
    • slybunda
      Elite Capacitors? (450v 47uf power board Toshiba Vestel TV)
      by slybunda
      anyone heard of these caps before? at first glance i mistook them to be Elna caps but closer look and it was elite. not sure if they are known failure prone brand.
      also they are 47uf and 450v. why are they so large in height? i can get replacement 450v 47uf caps that are a quarter the height. what am i missing here?
      if i were to replace them what should i be looking for?
      they are on the power board of a toshiba (vestel) tv power board.
      pic attached...
      11-13-2023, 06:33 AM
    • Cartel
      FORD 1996 ECU RECAP: Aluminum - Polymer worth bothering?
      by Cartel
      I will be pulling my crown vic ECU and recapping it. 3 in total, 47uf 16v x2 and a 10uf 63v
      I hope they havent puked yet. I was thinking of replacing them with Aluminum - Polymer thru hole caps. probably 47uf 25v and 10uf 80v
      They arent cheap. Anyone have any experience with them? Am I wasing my money on premium caps?
      Nichicon PLV series
      thanks
      06-01-2025, 04:58 AM
    • Eh546
      Polk PSW125 capacitors choices for a beginner.
      by Eh546
      I was looking to repair my Polk PSW125 subwoofer plate amplifier, i've checked around the web and it seems to be a capacitors problem.
      Took apart the amp, and made a visual inspection, everything's seems fine, fuse ect no burn marks, but i noticed 3 caps that were a little bit bulged. One 400v 150uf, one 50v 47uf, and two 63v 47uf.
      I noted each caps voltages and uf anyways, and made a list on digikey. Some recommended Nichicon and Panasonics ones (FR and FM) serie. So I tried to stay with the Panasonics FM-A serie.
      I would like to know if the caps i selected...
      12-21-2023, 07:28 PM
