Hello and what is this
+ More Options
Posts
  • dsc
    • Aug 2015
    • 53
    I've been lurking in the background learning tons of stuff for my ever growing hobby.
    Finally I have come across an item that I can't identify so I'm stepping up to the plate and asking everyone here if they can help me out.
    Currently I'm working on a wheelchair, one of the motors keeps tripping a fault signal. I opened it up to find two of these little beauties, one of which is destroyed.
    The simple question is just what the heck is it? Each one is secured to the housing and the other end is attached to either the positive or negative wire at the brush.
    Any help would be greatly appreciated.
    DC
  • tw2005
    • Oct 2011
    • 6458
    Re: Hello and what is this
    could be a capacitor, found this post https://community.klipsch.com/index....repair-thread/
    refer to C1, no idea on much more or if that's correct, check the photos out
    • redwire
      • 3902
      I believe those are an AVX axial lead ceramic capacitor (SpinGuard SA), popular in the late 80's-90's.
      A1C = AVX, 100V, X7R dielectric
      472 = 4700pF or 4.7nF
        • 30977
        i still use those - it's just an axial multi-layer ceramic cap.
        you put them across the power pins of digital chips.
        • dsc
          • Aug 2015
          • 53
          Sweet, thank you.
          I had assumed that it was there to reduce the arching of the brushes but honestly have not seen one before.
          Now to find one around here.
            • 30977
            it wont do much to suppress arcing - it's to small.
            it's mainly to supress RFI.
            if you want to supress arcing you need large polyester caps.
            • dsc
              • Aug 2015
              • 53
              Ah got it.
              This is the first time I've ever done any work on a wheelchair, my main work is golf equipment.
              My friend sends her thanks for the help.
              • schnauzer2021
                Chasis bond to neutral to overcome oven tripping problem
                by schnauzer2021
                I have a 6 years old Rowenta table top oven. The oven have both convection and grill function.
                Last Christmas I used it to roast a turkey with the convection mode for about 4 hours without any problem. When I switched to grill mode to deep browning the turkey for the final half hour, the power trips after a while.
                I have not been using the oven since then. Last week, when I try to use the oven again, both convection and grill mode trip the power supply a few minutes after turning it on.
                As I was too busy with my work, I leave it to the repairman...
                09-13-2021, 02:40 AM
              • spleenharvester
                Beko Tumble Dryer DTLCE80021W cutting out/tripping RCD
                by spleenharvester
                This dryer is several years old and has previously had a new motor cap. Currently it's behaving erratically - sometimes it finishes the cycle fine, other times it cuts out after a random period of time (just stops with no LEDs as if it has finished normally), and occasionally it trips the RCD. There's always steam coming off the clothes at the time it cuts out.
                Going to pull it apart tomorrow, before I lob a new heating element at it is there anything else worth checking? It's £70 for a new heating element and the whole machine only cost £180 to begin with...
                Cheers
                12-16-2024, 03:36 PM
              • alltvrepairs
                LG55UH615T Tripping after backlight replacement. Uses LGP55LIU-16CH2 power supply
                by alltvrepairs
                This TV uses 2 bottom edge LED strips. 1 was faulty but replaced both. However I have still noticed that the RHS of the TV switches on and then TV starts to recycle power getting to the LG logo and start over. If I disconnect the RHS LED strip will work with half screen lit. I have swapped LEDs and same problem.
                The power supply uses MAP3516 chip. Have replaced it twice, Checked all components as greatly suggested in this post https://www.badcaps.net/forum/troubl.../101580-lg55uh...
                01-08-2024, 03:21 AM
              • jimbofz
                samsung plasma ps50 c580g1k slow tripping relay
                by jimbofz
                Hi ,this appears to have 2 faults
                black lines on raster and faulty main board ?
                let me explain futher
                at switch on the relay does a few slow clicks with red led blinking and repeats every 10 seconds .i ran the psu into 2x 100w lamps and it runs fine all day supplies good .
                i removed y sus and x sus checked for dry joints and checked all igbt anf fets all ok
                next i removed buffer and checked for any s/c buffer ics all ok
                so i unplugged feed to main board from logic board and linked test points pin 3 and 4 ,
                tv still trips but now i get plain...
                03-15-2021, 02:18 AM
              • beetle1303
                Electric oven tripping circuit breaker after turned on for 3-5 minutes
                by beetle1303
                My electric oven was working fine all the while from purchased 2 years ago. I have been using it weekly for about a year, but stopped using for a year now since then.
                When I turn it on again yesterday, the tripped the circuit breaker and whole house no power supply. I reset the circuit breaker, and retried. Same thing happened.
                This is what happened:
                - Turned on the oven power supply, set temperature to 200c, everything worked for a few minutes, then the power tripped. Oven was warmed/hot.
                - Reset circuit breaker, retried, same thing happened.
                05-03-2020, 09:18 AM
