Can I use a mains relay on veroboard
  • JonathanAnon
    • Jul 2012
    • 457
    • Ireland
    I've developed a small circuit for switching a mains relay (which controls a lamp) on and off under specific conditions. I need to fit the circuit in to a proper enslosure so that I can use it. But I dont have access to any proper PCB making equipment.
    Now the stripboard is only good for 1 amp current, so my plan is to solder the relay on to the stripboard which will hold the relay physically in place, then solder the wires of the lamp directly to the load side pins of the relay (i.e. so that the relatively large current goes through the lamp's own 5 amp wire and not through the stripboard conductor). Then I plan to fix the circuit securely inside of the plastic enslosure.
    Does this sound okay?
  • mariushm
    • May 2011
    • 3799
    Re: Can I use a mains relay on veroboard
    The width and thickness of the copper traces on the stripboard gives you the current handling capability.
    You can make large traces by adding a lot of solder and making wide traces that way.
    • SteveNielsen
      Retired Tech
      • 2327
      What kind of strip board is it? Have a picture of it? If it's a strip board for experimenting and temporary circuits then it won't be suitable for mounting in a box permanently. Blank project PCBs with solder pads and vias are available in different sizes.
        The relay has terminals for the switch contacts for the load so why don't you solder the wires directly to the terminals that are sticking right out at the bottom of the PCB?
        • JonathanAnon
          • Jul 2012
          • 457
          • Ireland
          Yeah budm, that is exactly what I plan to do.. maybe I didnt phrase it clearly. I was just wondering if there was any reason that I hadnt thought of why this would not work or not be safe.
          Attached is an image of the stripboard that I normally use. I got it from Maplins, a UK store that has branches here in Ireland. They dont specify the maximum current or different trace sizes/widths.
            • 31150
            the real issue is the gap between the strips,
            you need to remove the copper strips between the used ones to prevent any risk of tracking.
            i use stripboard for high voltage a lot, it's pretty simple to peel or grind away atleast one track to each side of the high voltage ones.
            as for the current, you can solder a length of heavy copper wire ontop of the track to lift it upto 10A or more.
            • JonathanAnon
              • Jul 2012
              • 457
              • Ireland
              the real issue is the gap between the strips, you need to remove the copper strips between the used ones to prevent any risk of tracking.
              risk of arcing?
              Yeah, now that you mention it I have seen guys solder wire in line with the strip, as well as boost the strip with solder (as was suggested above). Certainly valid options as well.
                You should also have about 6mm gap/conductor traces between the relay's contact terminals (which is in the hot side of the circuit) and the coil terminals or any circuit in the cold side.
                • redwire
                  • 3912
                  I don't bother putting mains relays on veroboard.
                  Instead, I flip the relay upside down and glue it down with silicone. Then I just solder wires on the relay's terminals.
                  I would worry too much about meeting clearances for mains voltages with Veroboard. It's not designed for high-voltage anything.
                  • JonathanAnon
                    • Jul 2012
                    • 457
                    • Ireland
                    Instead, I flip the relay upside down and glue it down with silicone. Then I just solder wires on the relay's terminals. I would worry too much about meeting clearances for mains voltages with Veroboard. It's not designed for high-voltage anything.
                    I guess what it really boils down to is that if I dont solder the relay in to the veroboard, then I would have to find some other way of fixing it to the inside of the enclosure... like using silicone as redwire does. The control side of the circuit is only 9V 30ma max, so the primary safety concern is that the wires are fixed tightly to the relay and that the relay and wires dont move.
                    • clearchris
                      • Dec 2013
                      • 687
                      For switching mains voltage I prefer to use a din mount relay with screw terminals for the load. No worries there.
                        • 31150
                        30A is overkill for a lamp though!
                        the relay will probably draw more current than the lamp.
                        • clearchris
                          • Dec 2013
                          • 687
                          Depends on the kind of lamp.
                          I like overkill though. Lets me sleep at night when my devices are switching mains.
                          • redwire
                            • 3912
                            Another option is to use a solid-state relay, like a cheap Fotek SSR ~$4.00 it has a case, terminals etc., low current drive, although it requires a heatsink at higher currents >5A.
                            Mechanical relay contacts arc when switching load, which can crash your Arduino or Raspberry Pi due to the EMI, and the relays don't last long or contacts weld closed. I'd add a snubber or cap.
                              In rush current of the lamp due to cold resistance can be as high as 15~16 times of the current flow of the hot resistance of the lamp.
                              • CoinCoin88
                                Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                by CoinCoin88
                                I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                09-15-2025, 03:36 AM
                              • CuriousJohn
                                Burco boiler power problem
                                by CuriousJohn
                                Burco BCPLSAFWM5L 5 Litre Wall Mounted Automatic Water Boiler With Filtration UK 240v
                                Does anybody have any experience with these Burco units at all there is no record of them on the forum lol and a proper service manual would be nice. I invite you all to pesuade me not to botch repair it with a 5v relay, read on.
                                This unit was rescued from a skip 3 years ago, the only fault it had then was no backight display (plus it wanted a new probe set and top seal) but the screen was never an issue you can still see the screen as is and I just use it to get 5 Litres of very hot...
                                12-22-2024, 10:25 AM
                              • valvashon
                                Repair Success! Middle Atlantic UPS2200R-IP
                                by valvashon
                                Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                                Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                                02-06-2024, 12:54 PM
                              • corrize
                                Best way to solder LVDS connector for beginner (and qfn) ?
                                by corrize
                                Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                                I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                                I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                                See the test :
                                https://youtu.be/bNAzC-EvqHs?t=1767
                                With hot air from bellow the board, that's...
                                03-09-2023, 02:57 AM
                              • jm1234
                                9V relay temperature 40C
                                by jm1234
                                Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                05-09-2024, 03:03 AM
