short on mainboard for early 90's mass spectrometer
  • cashkennedy
    • Aug 2011
    • 668
    Re: short on mainboard for early 90's mass spectrometer
    I swaped the dc/dc converter with the spare parts machine, and machine is running fine.
    IDK if I ever mentioned that it was a HP / Agilent 5972, the spare parts machine was a 5971 (05972, 05971), mainboard 05972-69020, 05972-60020, 05971-60018 .
    Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
      • 31281
      invertors (DC to DC convertors) are high stress designs.
      that's why on tv's the psu and invertor are the most common failures.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5085
        • New Zealand
        As a certain arcade machine technician said: "The components that work the hardest, fail the most"
        -David VanHorn
        • 2Stupid4U
          Acer Nitro 5 An517-51 mainboard short circuit - Boomer needs help
          by 2Stupid4U
          Laptop data:
          NTB Acer An517-51 FHD
          i7-9750H
          16GB replaced with RAM Crucial Ballistix SODIMM DDR4-3200 32GB K2 SW
          1TB SSD
          RTX2060
          Bon soir dear online techies, enthusiasts, modest helpers and whomever I might have forgotten!
          Search gave me no hits so this is my first post.
          My Acer 5 Nitro mainboard had a short circuit when I tried to plugin a USB device. Some smoke rose from the port and it became super hot a that point of entry/exit. Warranty was of about a month.
          Since I am on a low budget I cannot afford to buy...
          08-29-2023, 01:03 AM
        • DynaxSC
          Extreme High Current & Low Voltage Short Killer ??
          by DynaxSC
          Hi Folks
          I'm looking for a extreme high current short killer solution for a reasonable cost.
          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
          After taking off the socket, the shorts dissappear again.
          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
          10-15-2024, 10:13 AM
        • Stigsolbjerg
          Gardena lawnmowerrobot mainboard, short out battery
          by Stigsolbjerg
          hi again
          this time its a mainboard from a mowerrobot, when i connect battery it shorts it, so the bms shuts down battery.
          when take the mm in beepmode and measure from the positive to the negative battery terminal on the board it beeps shortly like 0,25 sec, and when i reverse the probes it beeps again shortly 0,25 sec.
          when i mesure on the cap thats missing in pic nr 2, the bottom solderpath goes to the negative, the upper one is 1,2 ohm to negative is this a short?
          hope Capleaker is still around
          05-27-2024, 02:33 PM
        • Stephen
          MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
          by Stephen
          I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
          02-06-2025, 12:03 PM
        • adelfr2009
          HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
          by adelfr2009
          I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
          After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
          09-28-2025, 10:21 PM
