Bipolar Capacitor In A Pinch
  • Krankshaft
    • Jan 2007
    • 2328
    While browsing Google this morning they led me to something interesting in a capacitor article on Wikipedia.
    It said that a bipolar electrolytic is just two polarized capacitors wired in series opposition.
    With that said I have an example to present.
    Lets say I needed a 47uf 50V Bipolar cap however I don't have one on hand but I do have 2 47uf 50V Polarized lytics.
    Does that mean that I could wire these caps together one caps positive lead with the others negative (I assume that is what series oppositon means) and they would function just like a 47uf Bipolar?
    Or is this like the transistor back to back diode analogy where its only for explanation purposes and in practice it would not work?
  • tvtech
    • Oct 2006
    • 48
    Re: Bipolar Capacitor In A Pinch
    I second that,done that many times when I needed a bi-polar capactior.
    • starfury1
      • May 2006
      • 1256
      If I remember it correctly? I'd have to check!
      it can be done using 2 in series to create a "bipolar" Electrolytic
      Remember that capacitance will half (I think, it does normally)
      and from memory
      Its a positive to positive or negative to negative
      this is "series opposition"
      I am not sure but possibly one is a better option then the other
      if you think about it it will make sense, that if one side is positive and the other negative the center were the caps tie together will be on one side more positive on the other more negative to the two outside legs
      (Think or resistors in series and the voltage drop across each one)
      its case of whats more or less + - with respect to what?
      The characteristics of the 2 cap will determine the mid point Voltage.
      (which I think is neither here nor there in the case of small AC signals but Id probably be incline to use 2 from the same type,series)
      There was a around post here about it in regard to a psu.
      Yes that was my understanding is that what you buy pre made is the equivalent to this anyway.
      like I said I have to check this for accuracy but think its correct.
      HTH
      Cheers
      • tony359
        Bipolar capacitor for vintage Apple CRT monitor
        by tony359
        Good day all,
        I have a question about some old monochrome Apple monitors.
        Inside those monitors there is one bipolar capacitor. From the schematics I have it's part of the horizontal linearity circuit.
        A friend replaced a bipolar 4.7uF 25V capacitor with a Nichicon bipolar 4.7uF 25V. The cap popped after about one hour. The new capacitor was much smaller than the original one but that's not a surprise as the original one was from 1980. (I am not sure whether the original was was actually 4uF and was replaced with a 4.7uF?)
        The new capacitor:...
        08-12-2024, 03:27 AM
      • brispuss
        Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
        by brispuss
        Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
        Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
        I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
        12-28-2022, 02:58 AM
      • AlexForTheWin
        Help Diagnosing ASRock Taichi X570 Motherboard
        by AlexForTheWin
        Hi all! I'm a newbie to to the forum and electronics repair in general.
        I picked up a nonfunctional ASRock Taichi X570 motherboard that someone threw away. My main goal is it to repair and use it. But even if it's not possible, I'd like to learn about the process.
        I'd very much appreciate some guidance.
        Here are the steps I've taken to diagnose the board:
        I first tried powering the board without a CPU or memory. The lights turned on. As you'd expect, the board wouldn't boot.
        Hoping the board worked, I bought a compatible CPU on amazon. I wanted...
        12-16-2022, 11:37 PM
      • budwich
        Lithium 12v tool battery charger... no negative connection?
        by budwich
        I have a drill and battery but no charger so I bought a "universal charger" 120ac in ... 12vdc out (not really universal in lithium world). Anyway it has three contacts, positive, negative and "T" (temperature sensor). I connected those contacts to the contacts on the battery. No charging happened and only the status light is on (green solid) which the label indicates "100% charged".... but the battery isn't near that at around 9v and dying. There doesn't appear to be any difference whether the battery is connected or not. I got suspicious and pulled the...
        03-18-2025, 09:12 AM
      • BoardHoarder
        XBR-65X850D Backlight/Power On Help
        by BoardHoarder
        Currently trying to save a 65” 850D that definitely has a main board issue. Power supply has standby voltage and PS ON pin shows 3.5VDC but main has no signs of life…..no light under Sony logo and no optical port lit up. 12VDC is created by main board but no input triggers from main = no TCON 12V and no BL ON voltage present. I know about the trick of pulling the main to trigger the test pattern from the TCON but I get no backlight. If I jumper the 3.5VDC to TCON ON and BL ON, I can shine a light on the panel and see solid green, red, blue and white cycling. The 4 + backlight pins on the power...
        02-09-2024, 11:00 PM
