FX5200 - no DVI signal
  • socketa
    Asbelowsoabove
    • Jun 2014
    • 660
    • samsara
    This card now only works on VGA input.
    The DVI was working, then it sent no signal to the monitor a few times on a reboot, and now no signal.
    Am getting ready to do my first recap of a monitor, video card, and PSU and would like to order all the parts at once (including a basic ESR meter)
    The last 'component' to check out is this video card.
    What could be causing this fault?
    All the caps look good.
    4 caps are Elna 6.3v 1500uf
    2 Green ones are Teapo 10v 1000uf
    The small cap next to the DVI output is also Teapo.
    And the silver one, at the other end of the card, has no name, but has 3, 5, 1000, 6A printed on it's top
    I have another card - (nvidia 7600) which creates artifacts, on both DVI and VGA - so am reasonably sure that that chip is toasted.
    In contrast, the FX5200, has never caused any artifacts or ghosting, so, i'm thinking that the nvidia chip is probably OK.
    • 30941
    Re: FX5200 - no DVI signal
    one of the Elna's has leaked around the legs.
    • socketa
      Asbelowsoabove
      • Jun 2014
      • 660
      • samsara
      Hi again,
      Had a good look around all 8 legs, and couldn't find any signs of leakage - they were all shiny and bright.
      Did notice whitening around the base of the 5-windings choke and a light caking on the inside of some of its windings - but it does not appear to be dry-jointed, because one leg is continuous (using continuity test) with a tiny SMD cap, (on the reverse side) and the other is continuous with a elna cap (on the topside of the board)
      What next?
        • 30941
        this ?
        • socketa
          Asbelowsoabove
          • Jun 2014
          • 660
          • samsara
          Honestly can not see any sign of leakage from any of these caps, also the sides of the caps are clean with no signs of electrolyte.
          Any dark spots on the pads are due to shade.
            • 30941
            hmm.
            maybe a setting in the o.s.
            i know those cards can have seperate images or mirror the primary image to both ports.
            if you boot with dvi can you see the bios messages?
            • socketa
              Asbelowsoabove
              • Jun 2014
              • 660
              • samsara
              Ok It's working - well sort of
              I've found a predictable routine
              Here is the sequence:
              (All of the bios beeps, in the sequence below, are is normal Test OK beeps)
              1. Power down with vga connected
              2. Power up with dvi
              3. BIOS beeps once/blank screen/orange LED on monitor/no words on monitor - not even "no signal"
              4. Swap connecter to vga - monitor displays correctly / monitor LED turns green
              5. Swap to dvi connector - screen goes blank/ monitor LED goes orange
              6. Restart using [windows] [u] [r]
              7. Reboots with no bios beep but video OK
              8. Restart computer using [windows] [u] [r]
              9. Reboots OK, no bios beep / video OK
              10. Shut down computer using [windows] [u] [u]
              11. Bios beeps once / no video / orange monitor led
              12. Plug in vga - video OK | monitor led green
              13. GOTO 1.
              So, there is some odd behavior here:
              Currently, dvi does not work with a cold boot
              And, in respect to this card, the bios behavior seems to be opposite to what one might expect.
              As stated before, this ordeal does not happen with the ati vga/dvi card
              Any thoughts as to what is going on here?
                • 30941
                bios settings?
                • socketa
                  Asbelowsoabove
                  • Jun 2014
                  • 660
                  • samsara
                  No - there is no bios agp settings
                  Also tried it with another card that has the same FX5200 chip - dvi works no problem.
                  So if other cards work OK, then, logically, the problem is with the card itself.
                  From the sequence above, it can be determined that during a non-cold reboot some information is retained somewhere that allows a successful restart.
                  This information is lost when cold booting.
                    • 30941
                    maybe the agp bios is corrupt.
                    there are programs that can read & write them.
                    • socketa
                      Asbelowsoabove
                      • Jun 2014
                      • 660
                      • samsara
                      OK that sounds feasible
                      The card is Gainward G431110lQ0B4
                      Windows identifies the current bios as 4.34.20.27.06
                      So maybe the bios needs to be flashed.
                      But can not find this bios anywhere on the net
                        • 30941
                        you have another card, does it have the same gpu & type of ram etc?
                        • socketa
                          Asbelowsoabove
                          • Jun 2014
                          • 660
                          • samsara
                          Yes
                          Both have:
                          fx5200 GPU
                          DDR RAM
                          Buswidth 128
                          AGP 8x
                          Bios version of the gigabyte graphics card is "Unknown"
                          That's what GPU-Z reports.
                          The gigabyte bios is 63488 bytes and the gainward is 61440 bytes
                          So i saved the current bios and flashed the bios chip(?) (is there a separate BIOS chip somewhere on the card?) with nvflash using a startup disk
                          http://www.guru3d.com/files-details/...lash-5-40.html
                          The flash was not executed.
                          These are the messages that were returned in the console:
                          Adapter : GeForce FX5200 (10DE, 0322, 10B0, 0427) H:N B:01, AGP, D:00, F:00
                          Note: EEPROM does not contain board ID, skipping board ID Check
                          Warning: Firmware image PCI subsystem ID (1458.3103) does not match adapter PCI subsystem ID (10B0.0427)
                          ERROR: PCI subsystem ID mismatch
                          The old bios version info is still displayed during boot
                          Also opened the ROM file with NiBiTor, but didn't see any thing there with regards to Booting and DVI
                          I changed the "text display time" setting, using this app and then flashed, with success (just to make sure that nvflash worked OK)
                          There is a round dot on the nibitor user interface, that can be red, orange or green - it indicates integrity.
                          The dot is coloured green for the original bios - which indicates that the bios is not corrupted. (i'm picking that the bios must also contain a checksum of itself)
                            • 30941
                            can you put the bios you want to flash here.
                            • socketa
                              Asbelowsoabove
                              • Jun 2014
                              • 660
                              • samsara
                              Zip file including the original Gainward, and the Gigabyte that didn't flash.
                                • 30941
                                the pci id's are at offset $54
                                use a hex editor.
                                patch the 4 bytes in the one you want to flash so it matches the original.
                                  • 30941
                                  here:
                                  btw, i hope it didnt have any checksums
                                  • socketa
                                    Asbelowsoabove
                                    • Jun 2014
                                    • 660
                                    • samsara
                                    Thank you - no it didn't
                                    i can see what you did, and why - nice one!
                                    Brings back memories from a tut that i started, re the hex pairs and reverse order.
                                    Would there be any problem flashing with the gigabyte rom file, since it it larger?
                                    Also, comparing the two files in hexedit, i can see that the bunches of 00 00... (for example) occupy different offset ranges
                                    Ive checked the bios's datasheets
                                    Gainward - 25P05AV (can only find sheet for M25P05-A)
                                    Gigabyte - SST25VF512
                                    They are both 512kb
                                    Since the BIOS chips are not exactly the same as each other, do you think that it still would be ok to attempt the flash?
                                      • 30941
                                      the bioses are fine, the dumping program simply left off the empy area of the flash.
                                      personally i hate that, IMO a 512k dump should be 512k even if it's half full of "FF"
                                      • socketa
                                        Asbelowsoabove
                                        • Jun 2014
                                        • 660
                                        • samsara
                                        OK, flashed the bios, but same problem persists
                                        So flashed it back to the original bios rom file
                                        Then removed the card and put it in a 32 bit computer
                                        Works fine on cold boot, with normal bios TOK beep.
                                        So the problem only happens when the card is in the other box.
                                        Maybe the card is not fully compatible with 64 bit mobos?
                                        • AstutePauciloquent
                                          Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                                          by AstutePauciloquent
                                          Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                                          I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                                          11-23-2023, 11:02 PM
                                        • howardc64
                                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                          by howardc64
                                          Failure Symptom
                                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                          Where is the short?
                                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                          05-27-2025, 02:56 PM
                                        • JayPoorJay
                                          Converting +/- 5v to a Usable Hz Signal
                                          by JayPoorJay
                                          Good morning.
                                          I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
                                          This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
                                          The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions...
                                          08-07-2022, 08:35 AM
                                        • Scruit
                                          What is a normal composite signal range for a C64?
                                          by Scruit
                                          Hello all,
                                          Working on my first C64 / Breadbin / 250407. Purchased as non-working. Getting black screen.
                                          More detail below, but for those that want to get right to the question.... Here are a few waveforms comparing the Pin15 output on the VIC chip (luma/sync) to the pin 4 on the AV socket (composite signal).
                                          https://imgur.com/gallery/PpqcqPY
                                          My question is: Is the composite waveform range of 0.1v-1v too low for a c64?
                                          More detail:
                                          Symptoms are that that I get...
                                          04-28-2022, 05:33 AM
                                        • Ellos
                                          Samsung s21 sim recognized but no signal
                                          by Ellos
                                          I'm just starting out with smartphone repairs and picked up a Samsung S21 to work on. Everything functions perfectly except there's absolutely no cellular signal. The SIM card is recognized, WiFi works fine, but zero network signal.
                                          I've tested my SIM in another phone and it works perfectly with good signal, so it's definitely the phone.
                                          From what I've read online, this issue is usually caused by the network chip needing to be desoldered and reballed since one of the solder balls might be cracked.
                                          I think I've located the SOC that...
                                          06-27-2025, 01:31 AM
