I've got a couple Samsung led tv's with the dreaded "tab bond" issue. I've got one of them band-aided and been working fine for months, but I haven't put the back back on. It generates a bit of heat, and a while back I mentioned on the forums about installing a couple cooling fans (when I was trying to educate myself on a different repair). A guy chimed favorably so I'm reasonably sure it can be done, loadwise. The issue I'm taking is noise. I've got 300mmx10mm fans, and 40mmx10mm fans. They both run nice and quiet when I've got them on a 9volt source, but make too much racket on a 12v feed. Is there a 9v feed somewhere in these LED Sammy's that'll take 4 of these? They're .08a fans. If not, is there a way I can tap the 12v feed from the power board and cut it down?
