CFL filament burnt - jump it?
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    So I recently had a CFL go dead on me. Well, I took it apart, and the electronics look good. Was in an upright position, so the PCB hasn't turned black xD
    I wrote the date on it when I put it in ... it's almost 5 years old.
    But, one of the filaments has burnt out. I bypassed the open filament and the bulb works again.
    Now, for any lamp experts here, Is it ok to have it run like this? I know it won't heat the gas/mercury up as fast, so could this damage the ballast in the long term?
    I measured the current draw and it was about 160mA ... the bulb is rated for 200mA ... go figure. Interestingly, as the bulb warmed up, the current increased! Just by a few tens of mA.
    -Ben
    Muh-soggy-knee
  • kaboom
    "Oh, Grouchy!"
    • Jan 2011
    • 2507
    Re: CFL filament burnt - jump it?
    If you were measuring AC line current, that increase is normal.
    As the tube heats up, more voltage appears across it. Since lamp current is more or less regulated, a voltage increase corresponds to an overall power increase.
    This is reflected by the input current going up- the "ballast" is a form of buck converter.
    What you really did was connect both ends of the (open) filament together, obviously connecting an area with more cathode material "closer" to the circuit.
    You could often do something similar with linear fluro tubes, to get a few weeks/months out of them when they got cranky, by rotating 180 degrees (not end-for-end) in the sockets.
    "pokemon go... to hell!"
    EOL it...
    All style and no substance.
    guilty,guilty,guilty,guilty!
    guilty of being cheap-made!
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Yep, that is what I thought.
      lol, not sure what you meant by making the material "closer" to the circuit.
      -Ben
      Muh-soggy-knee
      • SteveNielsen
        Retired Tech
        • 2327
        When the cathode material fails the cathode separates into two parts opening the circuit. One part will contain more filament material than the other. Shorting the cathode leads completes the circuit again and puts a high potential on the remaining filament material.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          my educated guess is that there is no emitter left and it will finish burning up what little is left.then the ballast will blow up.wont be as spectacular as the f96t12's we have in the shop though.
          • SteveNielsen
            Retired Tech
            • 2327
            I think the other cathode is probably going to fail before the ballast fails, but it depends on how tolerant the ballast circuit is. If it can tolerate the increased power dissipation then when the other cathode fails the circuit becomes open again. Remember, the "good" cathode has a higher voltage across it now. That is going to shorten its life further.
              • 31139
              you just doubled the current to the remaining heater, it's not gonna last.
              more interesting, how is it controlled?
              i have seen 3 types.
              a mylar cap between the heaters << this is really shitty.
              a PTC - this is the correct way to do it.
              and some cheap lamps that use continuous drive (the location for a ptc is linked) < very bad!!
              • SteveNielsen
                Retired Tech
                • 2327
                The cathode current remains the same (Kirchoff's Law) but the voltage has increased which increases the power dissipation (Ohm's Law). The end result is the same, the cathode runs hotter and the emitting material will become depleted faster and fail.
                  • 31139
                  your missing the point,
                  if the heaters fail then you cant vaporise the mercury and the lamp wont start.
                  you can start a lamp with a big spike, but cfl's dont use that method because it's dangerous and the polyester cap is too big.
                  • TechGeek
                    Computer Geek
                    • Jan 2015
                    • 2254
                    -Ben
                    Dude, solder a 10K ohm resistor across the leads. That outta reduce the voltage.
                    Permanently Retired Systems:
                    Kooky and Kool Systems
                    sigpic
                    • SteveNielsen
                      Retired Tech
                      • 2327
                      What point? The one you just brought up that was not being specifically discussed? That's absurd!
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        post pics of the outcome.
                        my guess is the excessive cathode fall will overheat and melt the glass.
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          It's got the cap between the heaters. It's a GE lamp. I've taken apart a number of different CFLs and never seen a PTC. I guess it must be rare.
                          They always have the cap-between-the-filaments. Actually, one bulb (a n:vision) had blown this cap. It had a split in the side of it. I replaced it and the bulb worked again. I think it is still in use as well
                          I think the 10K resistor might burn out, with the kind of voltages that are used here. Also, the "normal" filament resistance is around 2 to 3 ohms (from what I have measured in the past).
                          Yes, I know, but, what if only one heater has failed? That is what I am asking about.
                          I haven't put it back into use yet.
                          By the way, what exactly is cathode fall? I looked it up, but, why would only one filament being used cause "excessive cathode fall"?
                          Yeah I thought it would shorten the life. The HV cap in there between the heaters is 4.7nF. I wonder if I halve that, maybe the current will be reduced to a more normal level on the remaining filament? Either that, or I can put a capacitor in parallel with the filament.
                          Well, the bulb was run while not working for a while. It didn't blow up, interestingly.
                          The circuit closely resembles this:
                          http://cdn.makezine.com/make/blogs/b...kea7wschem.png
                          Except there is no R5 (PTC). I think there is also no C4.
                          Muh-soggy-knee
                            • 31139
                            btw, a tube will last forever other than heaters and phosphor.
                            i have a 30year old atleast UV tube in an eprom eraser with broken heater.
                            i just warm the tube with the hot-air station before i plug it in and it strikes and runs every time!!!
                            (yes, i know i'm cheap!)
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              L - O - L !!!
                              You sir, get the cheapskate of the year award!!!
                              Muh-soggy-knee
                              • TechGeek
                                Computer Geek
                                • Jan 2015
                                • 2254
                                Nice. Another great way to save electronics. You might wanna consider attempting to rejuvenate the heaters or replace them.
                                sigpic
                                  • 31139
                                  i dont have a vac chamber or glass blowing skills.
                                  besides, a new tube is only 5-10€
                                  (but that € is better spent on beer. )
                                  • electomech-fixer
                                    First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                                    by electomech-fixer
                                    I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                                    I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                                    09-15-2025, 01:42 AM
                                  • repair-it
                                    TOSHIBA DLP 52HM95 How to reset timer module on bulb
                                    by repair-it
                                    I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                                    Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                                    10-11-2023, 07:18 PM
                                  • ezenia
                                    LUMIMAN Smart Bulb IC ID?
                                    by ezenia
                                    I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
                                    In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
                                    04-28-2025, 05:56 PM
                                  • dicky96
                                    Zotac GTX 260 burnt component - can anyone identify?
                                    by dicky96
                                    Hi guys
                                    This Zotac GTX 260 had a high side MOFET on one Vcore VRM phase short circuit Drain to Gate (Not short Drain to Source)
                                    This has burnt out the drive IC L3E (ADP3110A) and also an SOT-23 device very close to the driver IC. According to the PCB markings 'Dxxx' this is likely to be a diode.
                                    Basically the VRM has 4 phases, two powered from one 6 way connector and two powered from the other 6 way
                                    I would assume each pair of phases are basically identical, the burnt out phase has SOT-23 devices WW1 plus the burnt one.
                                    The good phase...
                                    12-01-2021, 01:02 PM
                                  • JimBanville
                                    Replacing incandescent bulb on Pioneer LD player with led. Need help :)
                                    by JimBanville
                                    I have a pioneer dvl-909 LD/dvd player from 1998. It has a light on the front panel that lights up when you play a dvd. I removed the bulb and it appears to be a tiny incandescent bulb. Its measures "open"/dead and the bulb is black like it's blown. The socket it fits into measures 5v. I've looked up the schematics and there's no indication of the amperage. I don't want to spend any money on new parts, but I have a pack of like 100, 3v, 20ma LEDs and I have various resistors.
                                    Is there a way for me to determine the amperage going to the old dead bulb with my multimeter?
                                    01-24-2023, 07:49 AM
