“How to test LED screen?”
  • Peter Chiu
    Banned
    • Dec 2012
    • 145
    Re: “How to test LED screen?”
    Appreciated for your information.
    I came to the office at 5:30 am, I need to modifier 220v (input power) V A meter to dc 12v
    and I need to finish this LED tester today, by change to IGBT and some breadboard test and modification.
    The prototype look like this (Pics). I call it Mutualism or Parasitism circuits
    Bacillary, I will use all my junks to build one.
    Yes,LED tester parasite in Samsung 55' LED TV power supply.
    An adjustable DC voltage 0-340v ,LED screen tester, with PFC ,IGBT, with DC 0-600v voltage and 0-10A DC current meter....................(i ordered this one) DC 0-600V 10A Voltmeter Ammeter LCD Panel Amp Digital Volt Gauge meter 12V/24V [ D85-3051]
    PFC: IC used this one
    {Self-talk} Samsung power board BN44-00499A ....%$#%#^%#^....... because I have more than 10 of them.... %$@#%$@^^ ..... Ebay about $5.69.....^$&$&^$.........Yes, I don't know how they pay the shipping ....... ^%#^%....... ^%#^%#^.......
    http://www.ebay.com/itm/SAMSUNG-UN55...item27fc681108
    Won't reply till tomorrow.
      Why would you need PFC? the testing current is less than 1A (100~300mA range is what you will reading) so you should get meter with better resolution. 100mA at 200V (if the LED needs that high) is only 20W.
      As printed on that BN44-00499A, the LED drive volage is 331V @289mA. The outputs are for driving one long strings of LED as you can see that the connector CNL802:
      PIN 1 (D1+) & 2 (D1+) are tied together for the Anode of the LED string #1.
      PIN 3 N.C.
      PIN 4 (D1-) the Cathode of string #1 is connected to pin 6 (D2+) which is Anode of the LED string #2
      PIN 5 N.C.
      PIN 7 N.C.
      PIN 8 (D2-) & 9 (D2-) are tied together, it is the Cathode of the string #2 which is connected 5 current sensing resistors (RL884~888) connected in parallel to the GND return (normally there will be POWER MOSFET connected in series with the sensing resistors and driven by PWM to maintain constant current.
      The meter input will have to be isolated from circuit GND, if the power for the meter is not isolated.
      • Peter Chiu
        Banned
        • Dec 2012
        • 145
        PFC is free, come with power board
        LED 2 groups 4+3=7
        4 strips LEDs each strip has 14 LEDs total on this group LED are 56 LEDs
        3 strips LEDs each strip has 14 LEDs total on this group LED are 42 LEDs
        7 strips LEDs each strip has 14 LEDs total screen are 98 LEDs
        I did light up the screen.
        LX27901 is the LED driver IC ,check menu is really helpful.
        https://www.google.com/search?q=LX27..._sm=0&ie=UTF-8
        2 hours work on meter, I got it work , but I can't read...
        How did you power the meter? from power board 12v ...........................
        Wow..........Time is running out
          How did you power the meter? it has to be isolated power otherwise you will not be able to measure the current. You need two meters, the isolated AMP meter, and the Voltmeter.
          Just think of it as having two FLUKES which runs on batteries so it is isolated, but if you use the power from the board, it is not isolated and I doubt that the meter uses differential probe method.
          You did not put the LCD back in place correctly or contaminate the connections that is why the digits are missing.
          • Peter Chiu
            Banned
            • Dec 2012
            • 145
            You're right again.... I did put up side down...now ...is ok........ Thanks......
            The meter now, I tested on DC12v ..... the transformer is AC 220V to AC 6v, 12v
            But this meter only up to DC199.90V so i order another one.
            Look carefully I maybe put the reflector the wrong way, too .who care ......I need to keep going on.....
              98 LEDs x 3.3Vf (typical) = 323.4V, the board spec is 331V so the LEDS are connetced in series to form one long string of LEDs.
                The meter now, I tested on DC12v ..... the transformer is AC220 to AC 6v, 12v
                Now check the input (measuring ports) to see any of them are tie to the power supply GND.
                So you removed the transformer which is needed to isolated the meter circuit?
                • Peter Chiu
                  Banned
                  • Dec 2012
                  • 145
                  Update:
                  I put meter up side down , it's OK, I will change to other one,late.
                  Shock twice by DC 394 V, now breadboard time....
                    What is that 084 V reading from?
                    https://www.badcaps.net/forum/attach...2&d=1429895219
                    • Peter Chiu
                      Banned
                      • Dec 2012
                      • 145
                      8.4 V (from 9V battery) , I use the Samsung power board DC12v(marked 13V )
                      to power the meter.
                      the cable is AC cable,which I moved away , to have space to hot glue the meter.
                      the 500k potentiometer I found burned out light dimmer exactly 500k ohm with switch so I can on/off the power.
                        Do you have the meter info that you can upload?
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          #32
                          maybe this one using post 21 DC 0-600V 10A Voltmeter Ammeter LCD Panel Amp Digital Volt Gauge meter 12V/24V [ D85-3051]
                          http://www.ebay.com/itm/DC-0-600V-20...-/281631696703
                            If that is the one then the max measured Voltage is only 40V per graph 3, and the current mode return is connected to power supply - which is circuit GND of the SAMSUNG POWER supply board.
                            He also need to watch out where the meter is inserted into the circuit to measure the current.
                            • Peter Chiu
                              Banned
                              • Dec 2012
                              • 145
                              [Music] https://www.youtube.com/watch?v=qRlGFXl_e1E
                              IGBT i used from this board ( pic 1) U can find any one but Vce>450V
                              RJP63F3DPP-M0
                              Silicon N Channel IGBT
                              High Speed Power Switching
                                100K resistor there, really?
                                You should analyze and understand the circuit.
                                • Peter Chiu
                                  Banned
                                  • Dec 2012
                                  • 145
                                  You show me, one guy put 100k resistor and 12 zener diodes..
                                  Adjustable voltage 0-354V with my old meter.and 3.3 ohm current limite R need to modified to adjustable . if you have parts, took about an hour to built it .
                                  He said ,I don't believe, so I change 47k look picture..
                                  [The video is belong to my experiment, I have slightly modified the circuit to maintenance 300VDC, I add a 100K resistor in between B+ and 500K , and i add a 24V x 12 = 294V zener parrallel with 500K.
                                  I didn’t use MOSFET because i don’t have on hand i ‘m using FGA25N120ANTD 1200V 25A IGBT , i think any MOSFET will work as long as the Vds can withstand 400V and above.
                                  I’m Using the transformer is design for valve/tube amplifier, having output 230V and 6.3V, the 6.3V winding i use to power the digital voltmeter for voltage and current as well.. the current actually is 1V meter with 1 ohm resistor in low side sense as shunt.]
                                    Lets see now, 354Vdc output from the main filter cap C1 feeds in to 100K resistor, so at worst case if everything on the right side of the resistor are shorted out to ground return, how much current will be flowing through the resistor? You know simple Ohms law, right? The 3.3 Ohm is not going to do much of the current limiting.
                                    Tell me what you get from your calculation.
                                    Even at 47K, what do you think the current will be?
                                    It really does not matter what you are using in place of the MOSFET at this point, look that resistor (100K, or 47K) you put in the circuit.
                                    • Peter Chiu
                                      Banned
                                      • Dec 2012
                                      • 145
                                      [Problem] votage can change from 0V to 350V (DC) but not enough current?
                                      I short the 47k still no enough current . I can't light up 10w LED, stop at dc 7.5V?
                                      can i use 1 ohm? is that Q2 BE reach 0.7 then current limited circuit is on.
                                      I change to 1ohm still the same ,maybe I need to use IRF740
                                      next will change 470k .Maybe R1 not pass enough current ,
                                      Good news change to 1 ohm IGBT shot right away.
                                        Like I said, did you look at the circuit and understand what that resistor (100K, 47K) does to the circuit? Calculate the maximum current will be allowed to flow?
                                        Simple Ohms law. If you cannot figure that out then you should not even try.
                                        • Peter Chiu
                                          Banned
                                          • Dec 2012
                                          • 145
                                          change IGBT everything is ok then I bypass the 47k .....everything go back to original.....
                                          the problem is the led burn out right away.....and the IGBT shorted again. because like U said, current limit is very important I just turn a little the voltage up a lot,10 turns controller may be need...
                                          47k maybe important to limit the current ,otherwise the circuit is simple but easy to run wide , I think that's why? that guy put 100k and 12 zener diodes.
                                          I do have IRF740 in stock (we fix car amp) will try it.
                                          When my hand turn (from 0 to 350v ) is very easy to over drive LED (led is a diode,run wild).
                                          that's why, they sale the tester 1-180v (they voltage is 240v), can drive 1-100 LEDs and you need to turn knob to change current.
                                          [Tips] To drive LED best is current source.
                                          http://en.wikipedia.org/wiki/Current_source
                                          And I think, I hate him.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • gabrielA7
                                            IMAC A1418 / MB: 820-00430-a / does not turn on, Lights 3 of the 4 LEDs and turns off.
                                            by gabrielA7
                                            Does not turn on, lights 3 of the 4 LEDs and turns off and stays like this, presses the power and repeats.
                                            I saw that the room LED lights up only when the screen is connected, so quiet.
                                            We have all the power supplies, even processor, 1.8V
                                            One thing I found strange, it has a very low resistance in the Vcore is giving 1 Ohm , work with notes and such, I know that this is normal in some processors but with this resistance only take video card so found it strange.
                                            I suspect that there may be some leak in the processor.
                                            Anyway, when I press the power, it...
                                            10-29-2024, 06:48 AM
                                          • stylishconsultant
                                            un60j620dafxza - Samsung No Display Problem
                                            by stylishconsultant
                                            Hi All,
                                            Need help.
                                            I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                            So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                            problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                            might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                            09-04-2024, 03:26 AM
                                          • thetonywarren
                                            TCL 43S435 NO BACKLIGHT ISSUE, LEDS TEST OK
                                            by thetonywarren
                                            I have a TCL 43S435 with no backlights. I contacted ShopJimmy and they said power supply. I got replacement power supply, but still doesnt work. I have confirmed that there is an image with flashlight test. I have also verified that the led strips work when I probe them with LED tester. Any ideas would be helpful. I am also geting a double blink on the status led when trying to turn it on......Nothing on the power supply looks suspect, and caps look ok. Where should I start to test......Thanks!...
                                            04-23-2025, 10:48 AM
                                          • Superbee_dad
                                            Sharp 80” long short flash backlight error - Help
                                            by Superbee_dad
                                            Hello Sharp TV experts
                                            Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                            > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                            > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                            01-24-2025, 11:51 PM
