Help me identify this flash
  • kepes
    • Sep 2014
    • 18
    • Hungary
    Hi!
    I have an ADATA C-906 DashDrive 8GB white pendrive(AC906-8G-RWH).
    It's broken, but i want to identify the flash on it, to know if i can read it with an eeprom writer(Minipro TL866CS). And i also would like to know if it is possible to make files out of the raw .bin file.
    Thanks for any ideas and help!
    It doesn't have any marks...
    It is a TSOP48 package.
    The only numbers on it are the following:
    TOP:
    60075154
    5300541046
    BOT:
    1206692345
    • 30985
    Re: Help me identify this flash
    it wont go in the minipro, it's a serial flash.
    • kepes
      • Sep 2014
      • 18
      • Hungary
      I have a TSOP48 adapter.
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        its serial, as TSJ says. it wont work. if you can get a serial programmer and your on linux the bin file will mount as a vfat FS.
        Follow the white rabbit.
          • 30985
          use another usb-key or an XD-card adapter as an interface.
          • kepes
            • Sep 2014
            • 18
            • Hungary
            First of all i would need the exact type of the flash...a serial programmer is also avaible, but the pc doesn't handle it well...this why is use the minipro with adapter.
            Other usb-key is not available...
            The type is needed to start the reading, after it is done i can move to linux.
              • 30985
              does the controller chip have a part number?
              • kepes
                • Sep 2014
                • 18
                • Hungary
                Yes, it is: Silicon Motion SM3257EN
                  • 30985
                  get a datasheet.
                  and check the usb plug soldering/contacts.
                  • Peter Chiu
                    Banned
                    • Dec 2012
                    • 145
                    I know how it work. have an answer for U...
                    Don't be too excited....First listen to this .....and calm down
                    Ольга Куриленко
                    https://www.youtube.com/watch?v=vp_h649sZ9A
                    • Peter Chiu
                      Banned
                      • Dec 2012
                      • 145
                      Sorry, I make a mistake.... that kinda music can't clam down.....
                      Yes,It is this one
                      https://www.youtube.com/watch?v=rNsgHMklBW0
                      نرم افزار پروگرامر. آداپتور پروگرامر 2000. پروگرامر TNM 2000. پشتیبانی انواع فلش،سریال اییپرام ،ایپرام ،میکروکنترلر،
                      خوش آمدید به تهران نوین تک
                      به فروشگاه تهران نوین تک تنها نماینده فروش و پشتیبانی کلیه محصولات TNM به صورت اینترنتی مورد تایید شرکت طرحان نوین مدار خوش آمدید .
                      با خرید هر دستگاه پروگرامر TNM2000,5000 یک عدد کابل اصلی USB مخصوص بگیرید.
                      با خرید هر دستگاه TNM5000A,E یه عدد کابل ریو هدیه بگیرید
                      http://www.tnmelectronics.com/2000.html
                      https://cdn.badcaps-static.com/pdfs/...878c8d2c81.pdf
                        • 30985
                        that's only 40pin
                        you mean this:
                        http://www.tnmelectronics.com/English/5000.html
                        • Peter Chiu
                          Banned
                          • Dec 2012
                          • 145
                          .........%$#%$#%$#^#%....YES i do have one(TNM2000+) very good on TSOP 48 NAND, OR gate Flash chips programmer...........^%##^%##%&.......because it's the most cheap I could found in 3 months.....%$#%$@%$.....about $180 without the adapters.......%#@%$@#@......I do have TL866A not enough chips in Nand flash they supported.......%$@%@%$@....... then go a head.....
                          http://www.ebay.com/itm/TNM-2000-USB...-/321207236799
                          http://www.aliexpress.com/store/prod...048105724.html
                          With adapter , they can do 56 & 48 pins...%$@#%$@#%......I think ...is an Indian smart person develop the tester.....%$@%$%@........ Yes, they are good at Maths
                          Tips: It's very good for..... Data recovery.....
                          • Peter Chiu
                            Banned
                            • Dec 2012
                            • 145
                            Most common way to do it is buy another AC906-8G-RWH swap the 8GB Flesh and try to read from USB to Ur computer..........If not............then programmer
                            • ekozeko333
                              [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                              by ekozeko333
                              I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                              🔥 The Problem Started After Suspected ESD/PD Fault
                              I experienced a power issue or ESD event through a USB-C charger
                              After that, the NX20P5090 power switch was visibly burned and was replaced
                              Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                              🧠 What I’ve Done So Far
                              Flashed...
                              06-21-2025, 02:48 AM
                            • corrize
                              Nikon D800 camera - flash don’t work and capacitor don’t charge
                              by corrize
                              Hello, I'm stuck in troubleshooting…
                              The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                              In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                              When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                              10-01-2022, 10:02 AM
                            • EdwardGeo
                              Help to identify ATMEL SPI Flash - ATMLH184
                              by EdwardGeo
                              On flash, I see marking: ATMLH184, but according to datasheets of this vendor, this marking only explains Year, etc...
                              So I can't make it read by programmer, it also can't identify it. How can I find a datasheet?...
                              04-16-2023, 04:26 PM
                            • abajor
                              Canon VIXIA HF S10 A read data from inernal flash memory.
                              by abajor
                              Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
                              Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
                              The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
                              I think my best shot is to figure out a way to read the internal flash memory outside...
                              07-20-2024, 12:04 AM
                            • Ihandyrepair
                              4 red flash led 65X950G boot Sony and android logo but then black
                              by Ihandyrepair
                              HI guys
                              I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                              here is the issue
                              I have Sony and android logo. but then 4 led red flash lights front of the tv
                              I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                              but then I get black screen and 4 red flash light at the front LED
                              but I get 3 led flash on the LED driver board.
                              I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                              so I tried...
                              07-11-2024, 01:45 AM
