Please Help I have Hyundai Hometheater Remote Lost
  • sureshbobby
    • Mar 2015
    • 137
    • India
    Dear friends Please help i have lost hyundai home theater 5.1 Remote cant find but i have image
  • mmartell
    • Oct 2013
    • 3189
    Re: Please Help I have Hyundai Hometheater Remote Lost
    Did you look between the sofa cushions ?
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      check the fridge!
      Follow the white rabbit.
      • ron350
        • Feb 2014
        • 296
        Please post a picture of the romote.
        • sureshbobby
          • Mar 2015
          • 137
          • India
          Hi friend am attaching the picture of remote
          • sureshbobby
            • Mar 2015
            • 137
            • India
            Guys do respect others feelings its a memory of my grand mother so I don't wanna throw it to a store room
            • codycowgill
              Lost christmas tree remote
              by codycowgill
              I have a rgb "holiday symphony" 600 led tree that I got for free but it has no remote which basically neuters the tree with just one color option and no music. The original remote is as 433.96 mhz rf remote. Here is the fcc link: https://fccid.io/2APJZ-PDT0093V.
              The manufacturer is Polygroup and are absolutely no help. As they offer no replacements to the most easily lost part. All they gave me was the model number of the remote and said google it and good luck. Of course nobody is selling them. Anyways I provided pictures of the reciever motherboard along with the rgb...
              12-31-2022, 06:22 PM
            • cstout
              DeLonghi AC Remote only accepts 3V
              by cstout
              Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
              The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
              I can't find any schematics...
              06-03-2024, 03:53 PM
            • Mc_Millian
              Toshiba 50lf711u20 fire tv remote not pairing
              by Mc_Millian
              I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
              The Tv model number is: 50lf711u20 Rev B.
              I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
              I've tried 3 different remotes which should be fully compatible with this TV.
              Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
              The power button, along with the volume,back,select, and directional...
              04-07-2022, 12:15 PM
            • edugimeno
              HiSense 55A7500F won't obbey to remote after power on
              by edugimeno
              Hi! I have this TV set that does the following:
              1) I press the red power button on the remote
              2) The TV turns on normally
              3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
              4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
              Then after it's off, it would again accept the TURN ON from the remote and same again
              BUT:
              -The remote does show the correct IR beam while observed thru a phone camera
              -The TV works fine while using the MiRemote...
              03-14-2023, 11:22 AM
            • tmhobadcap
              Pioneer VSX-522-K remote control not working???
              by tmhobadcap
              I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
              At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
              12-24-2020, 01:44 AM
