Dear friends Please help i have lost hyundai home theater 5.1 Remote cant find but i have image
Please Help I have Hyundai Hometheater Remote Lost
Tags: None
Re: Please Help I have Hyundai Hometheater Remote Lost
check the fridge!Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit.Comment
Guys do respect others feelings its a memory of my grand mother so I don't wanna throw it to a store roomComment
by codycowgillI have a rgb "holiday symphony" 600 led tree that I got for free but it has no remote which basically neuters the tree with just one color option and no music. The original remote is as 433.96 mhz rf remote. Here is the fcc link: https://fccid.io/2APJZ-PDT0093V.
The manufacturer is Polygroup and are absolutely no help. As they offer no replacements to the most easily lost part. All they gave me was the model number of the remote and said google it and good luck. Of course nobody is selling them. Anyways I provided pictures of the reciever motherboard along with the rgb... -
by cstoutHello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
I can't find any schematics... -
by Mc_MillianHello everyone,
I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
The Tv model number is: 50lf711u20 Rev B.
I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
I've tried 3 different remotes which should be fully compatible with this TV.
Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
The power button, along with the volume,back,select, and directional... -
by edugimenoHi! I have this TV set that does the following:
1) I press the red power button on the remote
2) The TV turns on normally
3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
Then after it's off, it would again accept the TURN ON from the remote and same again
BUT:
-The remote does show the correct IR beam while observed thru a phone camera
-The TV works fine while using the MiRemote... -
by tmhobadcapI have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked... - Loading...
