I have a dilemma. I am building a circuit to switch 2 separate "loads"...one with a switched ground and one with a switched positive. I am using an ATTINY to switch a pair of 2n7002 Mosfets. I have attached a schematic. I am using a resistor to step down the voltage from +12 to ~ 4v to run the ATTINY. The question I have is if Q2 would run consistently in this setup or if you have a better idea of what to run? I am using the 2n7002 to sink < 1 amp in both directions. Ultimately I have another circuit monitoring the output of these pins checking for -12 on one and +12 on the other. The circuit works but I had to swap the Source and Drain of Q2 to get the functionality that I want. I am hoping this is proper use, and not an undocumented feature that will soon fail. Does anyone have any insight?
EDIT : I think I have a bug in my schematic I will follow up in a moment.
EDIT2: Lol. Lets make this easy. I need to switch +12v from a +4ish v signal (the attiny going HIGH). Any ideas on what I could do this with?
