Saphire HD 7770 OC version
  • chrle
    • Sep 2013
    • 158
    • slovakia
    hello ,I have saphire HD 7770,and no signal on monitor.
    I boot up with another gpu and windows recognize HD 7770 but no video..
    booting with only HD 7770 = no bios,no post,nothing. blank screen
    Any ideas?
  • Agent24
    I see dead caps
    • Oct 2007
    • 5086
    • New Zealand
    Re: Saphire HD 7770 OC version
    Bad video BIOS? Try reflash?
    -David VanHorn
    • chrle
      • Sep 2013
      • 158
      • slovakia
      I will try to reflash tomorrow.
      • chrle
        • Sep 2013
        • 158
        • slovakia
        I reflashed bios but still nothing.
        any ideas?
        • Agent24
          I see dead caps
          • Oct 2007
          • 5086
          • New Zealand
          I don't know. Unless you have the wrong BIOS or something? I don't know what it means when half the stuff in GPU-Z is detected as "unknown"
          Or maybe something wrong with the card's onboard power supply?
          -David VanHorn
          • chrle
            • Sep 2013
            • 158
            • slovakia
            I downloaded bios from http://www.techpowerup.com/vgabios/i...&model=HD+7770
            • chrle
              • Sep 2013
              • 158
              • slovakia
              in GPU-z says amd radeon R 7 200 but this is HD 7000 series..
              strange
              • chrle
                • Sep 2013
                • 158
                • slovakia
                new pic
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5086
                  • New Zealand
                  No idea, maybe it has a hardware fault.
                  -David VanHorn
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    When the GPU or memory clocks are not running, that can also mean that either power is not getting to the GPU or GPU needs a reflow.
                    I had a similar problem with a Radeon 9700. No display or anything, but with a PCI-E video card, the PC was detecting the Radeon 9700 video card but just refusing to run it.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5086
                      • New Zealand
                      Yeah, power supply is what I was thinking too.
                      Check the VRM circuits - are they outputting anything? I assume you don't have a schematic. Find all the ICs likely to be VRM controllers\DC-DC controllers etc and look up the datasheets, find out where the outputs are and see if voltages are present and make sense.
                      -David VanHorn
                      • sikocan
                        Lenovo X1 Carbon 9th Gen Black Screen
                        by sikocan
                        I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
                        SN: PF3G1REP
                        MODEL: 20KW-00J1AU
                        PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
                        Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
                        06-24-2025, 09:01 PM
                      • Vesko356
                        by Vesko356
                        08-11-2023, 03:27 AM
                      • TJ65
                        Samsung Galaxy Tabpro S BIOS and Micom Version doesn't match
                        by TJ65
                        i made out of two broken Samsung Galaxy Tabpro S one that works partially.
                        The one Mainboard had a broken screen output but working hdmi (usb c adapter) output and the other didnt start at all.
                        I switch the bios chips and now the tablet starts but very very slow and it takes some trys to get it starting.
                        The problem is, that the micom Version doesn't match with the bios version, see picture.
                        How can i update the Micom Version? The Samsung bios update wont work.
                        With https://github.com/tavinus/SamsungBIOSTools i could extract the newest bios update...
                        01-09-2025, 01:35 PM
                      • TheUser
                        Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                        by TheUser
                        Hello to everyone ,
                        This is my first post here, and i would like to share with you a small story in case you can help me.
                        Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                        All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                        I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                        02-10-2024, 02:07 PM
                      • thslr2020
                        [REQUEST] Modify BIOS version of dumped image(Panasonic CF-RZ6)
                        by thslr2020
                        Hello.
                        I keep tried unlocking FIVR lock(XTU, Throttlestop) to do undervolting, but failed. What I tired is...
                        1. Unlocked hidden menu >>> Disabled CFG lock, Overlock lock, SGX
                        2. Replaced CPU microcode to 2017, 2018 version (pre Spectre, Plundervolt)
                        3. Disabled Intel ME, Hyper-V & Vt-d
                        4. Removed microcode update of Windows(mcupdate_GenuineIntel.dll)
                        5. Try from fresh Win 8.1(boot with USB)
                        Even I already did all of above, XTU and Throttlestop is still locked. So I think what I can do is downgrade the BIOS version, but...
                        06-14-2023, 12:09 AM
