[REQUEST] Modify BIOS version of dumped image(Panasonic CF-RZ6)
  • thslr2020
    • Jun 2022
    • 7
    • South Korea
    Hello.
    I keep tried unlocking FIVR lock(XTU, Throttlestop) to do undervolting, but failed. What I tired is...
    1. Unlocked hidden menu >>> Disabled CFG lock, Overlock lock, SGX
    2. Replaced CPU microcode to 2017, 2018 version (pre Spectre, Plundervolt)
    3. Disabled Intel ME, Hyper-V & Vt-d
    4. Removed microcode update of Windows(mcupdate_GenuineIntel.dll)
    5. Try from fresh Win 8.1(boot with USB)
    Even I already did all of above, XTU and Throttlestop is still locked. So I think what I can do is downgrade the BIOS version, but Panasonic does not provide the BIOS image file and gives only installer(I checked with 7z, but there was no perfect image file).
    Is there any way to modify the BIOS version to spoof the installer for downgrade?
    Here is my dump and version is showing as V2.00L30 in BIOS.
  • thslr2020
    • Jun 2022
    • 7
    • South Korea
    Re: [REQUEST] Modify BIOS version of dumped image(Panasonic CF-RZ6)
    Attached are dumped and editied BIOS with official installer. (L30 is latest)
    • thslr2020
      • Jun 2022
      • 7
      • South Korea
      Solved by patching BIOS installer with IDA Free.
        by Vesko356
        08-11-2023, 03:27 AM
      • jason0503
        need help to modify a bios dumped from set-top box
        by jason0503
        The set-top box has a TV silicon tuner IC MXL608, which has a programmable channel selection filter (6MHz/7MHz/8MHz), and the default value is 8MHZ, but the manufacturer sets the set-top box to 6MHZ. How can I change this value by modifying the dumped bios? I tried using UEFITool.exe, but it doesn't work. The BIOS of the TV box is different from that of the computer. I don't know how to modify it or what tool to use. I downloaded the data sheet of MXL608, which mentioned that when the value of SYMBOL is set to 2.85, BW=6MHZ. When the value of SYMBOL is 3.75, BW=8MHZ, but I can't find the corresponding...
        12-14-2024, 01:26 AM
      • TJ65
        Samsung Galaxy Tabpro S BIOS and Micom Version doesn't match
        by TJ65
        i made out of two broken Samsung Galaxy Tabpro S one that works partially.
        The one Mainboard had a broken screen output but working hdmi (usb c adapter) output and the other didnt start at all.
        I switch the bios chips and now the tablet starts but very very slow and it takes some trys to get it starting.
        The problem is, that the micom Version doesn't match with the bios version, see picture.
        How can i update the Micom Version? The Samsung bios update wont work.
        With https://github.com/tavinus/SamsungBIOSTools i could extract the newest bios update...
        01-09-2025, 01:35 PM
      • glovecaps
        by glovecaps
        11-25-2024, 04:23 PM
      • Bloodhoundje
        by Bloodhoundje
        03-16-2024, 03:12 PM
